Is it worth upgrading R6 mk1 to mk2 for wildlife/birding/BIF?
Started 1 month ago | Questions
steeldrake Junior Member • Posts: 43
I struggle to decide if i should spend a reasonably big amount of money to upgrade my R6 to mk2, I know the differences in specs but one thing really bothers me and if any of you have experience (or even can share example raws) on this, i would be happy:
I do lot of wildlife and BIF (birds in flight) with R6 and RF100-500, sometimes with RF1.4 extender. Still depending on subject and situation i often need to crop quite alot. Now 24 is not much more that 20 but i read a lot of info and experiences that the IQ and details are much better in mk2. Perhaps due to different AA filter or something similar.
So will you get a much better highly cropped image from Mk2?
I sometimes use Topaz gigapixel and it creates often anomalies in e.g. bird feathers. I also wonder if a more detailed original picture would generate less artefacts...
And finally if you have the experience, is the AF and animal/bird tracking really noticeable better in mk2?
Thanks for any help in the difficult question ;).
 steeldrake's gear list:steeldrake's gear list
Sony RX100 VI Canon EOS R6 Mark II Canon EF 100mm F2.8L Macro IS USM Canon RF 24-105mm F4L IS USM Canon RF 70-200mm F2.8L IS USM +3 more
Canon EOS R6
Gam3r01 Contributing Member • Posts: 572
Re: Is it worth upgrading R6 mk1 to mk2 for wildlife/birding/BIF?
5
I highly doubt you would get your moneys worth on that upgrade, especially given your use case. You would need a substantial bump in resolution (R5) to see a big enough difference IMO.
I also have been seeing relatively similar results from the R6I and R6II, so if anyone has comparisons of the two that says otherwise Id be interested to see them. Ive been given the impression the IQ difference is not that impressive.
 Gam3r01's gear list:Gam3r01's gear list
Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 16mm F2.8 STM
spec68 Contributing Member • Posts: 530
Honestly, if you have the $ wait for the R5 II. Then you'll have plenty of MP to crop. I use the R5 for birding and I'm really excited about  the R5 II's rumored specs (yeah, OK rumors!), mostly the 61mp BSI sensor. That should really up the R5's low light abilities plus allow for even tighter cropping.
But if that's not for you the R6II looks like a worthwhile update with a few more MP and better AF system.
OP steeldrake Junior Member • Posts: 43
I fully agree but as even canon says mkii gives as much details as 5d series 30M sensor i would really like to hear from someone who has really done the cropping on both. And would love to see raws to compare.
ntrongd Junior Member • Posts: 29
I'm in the same situation as you but what really makes me desire is the better rolling shutter of the R6 II, not sure if it is really pronounced in real world.
MaStErPsX
MaStErPsX Regular Member • Posts: 203
No, same IQ for me, but 4MP is better than nothing  (20%)
Yes, better subject detection
 MaStErPsX's gear list:MaStErPsX's gear list
Canon EOS R6 Mark II Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4.0-7.1 IS STM Canon RF 85mm F2 Macro IS STM +6 more
drsnoopy Senior Member • Posts: 1,216
In terms of cropping, the difference wil be marginal.
You would get considerably better results with an R5, or even consider adding an R7 body for your birding.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
It is very marginal. On the real pictures you will not notice any relevant difference. You can try it by yourself: download any RAW file from R6II (from a DPR sample gallery for instance, crop it down to 20Mpix and print both the original and crop on A3. You will see literally no difference in resolution or sharpness.
Comparing the DPR studio test scene tells that this rumor is not true.
No.
Well, this is the issue with Topaz and its way too much overcooked output. But since the actual resolution of both cameras is hair tight, also the outcome from Topaz will be the same. Try Adobe Super Res, it gives much more natural output, especially but not only color wise.
The AF on R6 is already very good and reliable itself. R6II brings something on the top but it is rather a fine tuning improvement than a generation leap. Many videos available on this topic on YT.
As other said, if you want a real step forwards, the R7 might be the answer. It has significantly better reach due to 1.6x crop, on the top it has notable higher resolution and the same improved AF as R6II.
The R7's logical downside is MUCH worse per pixel noise than the R6 which spoils its resolution advantage from let us say ISO6400 up.
So if you shoot wild life under a good light situation, then R7 would be a benefit. If you often use ISO6400 and higher, it will not bring anything in terms of better detail resolution.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
MaStErPsX
No, it's not the same AF, many report said R7's AF it's not as good than R6 or R5 (so it can't be as good than R6 Mark II)
https://youtu.be/aT1TFLPgHK0?t=2468
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,242
5
I would suggest to better invest in a second body, namely the R7 for your purpose!
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS Ra Canon EOS R5 +30 more
Llop Forum Member • Posts: 50
Agree on the R7 recommendation, much better reach, more cropping leeway and overall noise level should be similar to the cropped R6 images but more detail (the more light the better).
The only relevant advantage of the R6 Mark II for this use case (ergonomics aside) would be IMHO the improved rolling shutter.
Otherwise the other option currently available to gain significantly more detail is the R5 as already mentioned
Canon_Guy
True up to ISO3200, not true from ISO6400 up. Check out the link I posted.
Just to confirm if I understood correctly, the link compares R6 20 Megapixel images vs R7 32Megapixel images, is that right?
What I meant is when you reach limited you get more detail with the R7 i.e. if you compare a the R6 1.6 crop (7.7 Megapixels) vs the full 32 Megapixels of the R7 (same distance to subject, same focal length)
Franz Kerschbaum
Exactly. If you resample the high ISO  R7 pic to the R6 7 MP resolution the R7 pics are actually better noice wise. The R6 does not have such an outstanding sensor but benefits from its low res. That gets allways mixed up also in comparison to the R5!
With R6 AF often struggles in these scenarios 1. while shooting fishing Ospreys the background changes quickly when following the bird and water splashes all over when the bird hits water. 2. trying to focus to a bearded tit in the middle of reeds. Any comment whether mk2 is any better?
R2D2 Forum Pro • Posts: 26,531
I think first you need to verify that all of your settings are optimized for the kind of shooting that you’re doing.  It takes a while to develop a good setup and good technique.
Diving ospreys are indeed HARD.  Follow that sucker as perfectly as you can, keeping it in exactly the same location in the viewfinder (don’t let it wander or you’ll get subject motion blur).  Keep your shutter speed up.
Remain aware of your depth of field.  You’ll often have enough DOF so that you can let off of the autofocus as the bird hits the water (so that the focal plane doesn’t wander due to the splash).  Back button focus helps with this, but you can also program a button to Stop Focus if that’s your thing.  We’re fortunate that an osprey’s dive is so vertical!
I haven’t been out in the bush birding with my R6ii yet (my R5 is assigned this duty).  From my experience shooting people (and sports) with the R6 and R6ii, I’d suspect that the mk2’s AF would be slightly improved for birding.  The way I shoot, the increased options for AF areas don’t really come into play for birding (for people, bigtime).
A couple of techniques that may help with birds (literally) in the bush: Turn off Exposure Simulation in dark habitats.  This brightens the image that the AF has to work with and improves subject recognition and acquisition.  Second, put the camera in 1.6x Crop Mode.  This also helps with (especially eye) AF recognition and acquisition on distant and/or partially obscured subjects.  I keep “Aspect Ratio” programmed to the “Set” button for easy access.
See if any of this helps the next time you’re out.  Best of luck!
R2
Thanks. Yes, I know all this, I am pretty experienced in this type of BIF and have configured BBF (actually 3 button BBF) for my R6, and do prefocusing on estimated place of hit if applicable etc..  I was just wondering if there is any difference R6 vs R6 mkii - but i assume it is hard to see as - like you say - this type of BIF in hard.
R2
That R7 is a very sensible suggestion.  Another suggestion would be to look for a good used R5 body.  For deeper cropping you will really need more MP - either 45MP full frame or 33MP crop.  Going from 20 to 24MP will make very little difference.
OK, good! Sounds like you have the technique down pat.
I haven’t taken the R6ii birding yet (as I have an R5), so I can’t compare with the R6 for birding. I have shot sports with the R6ii though, and I think it does a little better than the R6 in that regard. The biggest difference between the two though is the AF configurability.
R2
BirdShooter7 Veteran Member • Posts: 9,127
I got a chance to take the R6 mk2 for a spin yesterday and it is very nice but so far I’m not feeling compelled to upgrade my R6.  The AF seems a bit better, four more MP are nice to have but the difference from 20 isn’t exactly leaping out at me.  There are a lot of nice little things that are improved and if I didn’t already have an R6 the choice would be easy for me.  At this point my R6 easily qualifies as “well used” so resale value is going to be at the low end of the range.
Anyway, I was mostly photographing flying ducks and  the R6 mk2 did an excellent job.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
