…Said the quiet part out loud
Started 1 month ago | Discussions
MAC Forum Pro • Posts: 18,487
Re: …Said the quiet part out loud
Alastair Norcross wrote:
FF lenses can lose their luster on crop - RLight has no experience with that lens on crop
But I do, on my R7, and it performs very well. Much as I love the EF-M 32 on my M6II, I wouldn't buy an RF-S version for my R7, because the RF 35 is so good already. What it loses in aperture (2/3 stop), it gains in minimum focus and IS. I can handhold the 35 on my R7 down to 1/2s. With my 32 on my M6II, I don't go lower than 1/125.
the R7 + RF 35 isn't exactly a small setup like the m6II + 32 f1.4
I agree on the ss you discussed
I'm not convinced on the sharp across the frame wide open on that lens without stopping down a bit,
Well, here are a couple of samples I just took wide open. First the whole frame:
And now a 100% crop of the upper left corner:
The focus was on the symbol above 'SIGNET'
And another, full frame first:
And 100% crop from upper left corner:
Focus was on the colon
Looks pretty sharp at F1.8 right at the edge. Certainly good enough for my purposes.
thanks for these, yes, looks fine
and the backdrop blur I want is ff equivalent of 50 fov f2.2 not having to stop down a bit
but as far as sharp across the frame at f1.4 (50 fov f2.2 equivalent), I'll stay with my m32 f1.4 and m6II since I'm not buying a crop R camera, which I think is for reach with long lenses, wildlife and sports
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
justmeMN Forum Pro • Posts: 10,705
MAC wrote:
Canon knows AI focus is a key to smoke the competition - they are large enough to use research dollars to stay in the lead ...
DPR writes:
"The R50's most compelling feature is probably its autofocus system. It's a relatively simple-to-use but powerful system that combines a series of subject recognition modes with tenacious tracking."
That's pretty cool for a bottom-of-the-line camera.
https://www.dpreview.com/articles/7537526501/hands-on-with-the-canon-eos-r50?slide=2
OP RLight Senior Member • Posts: 4,414
Nice, SMAC (Sid Meyers Alpha Centauri)…
Hive or University? Or Morganite?
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
m100
m100 Senior Member • Posts: 2,048
Why do you down size test photos ?
Dr. says listen to this every morning.
https://www.youtube.com/watch?v=bEeaS6fuUoA
 m100's gear list:m100's gear list
Canon EOS M6 II
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
I didn't. The tests are the crops. The point was to show how sharp the lens is wide open at the edges (we all know it's sharp in the middle, we don't need yet more photos showing that), when used on an RF mount crop camera. The crops are 100%. The downsized full frames are just to show you where the crops are taken from. No need to clutter things up with bigger images than necessary.
Alastair
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
m100
I didn't. The tests are the crops. The point was to show how sharp the lens is at the edges (we all know it's sharp in the middle, we don't need yet more photos showing that), when used on crop. The crops are 100%. The downsized full frames are just to show you where the crops are taken from. No need to clutter things up with bigger images than necessary.
The test photos on this website used to show lens performance for me is some of the most useful stuff on here.  Thanks for going full size.
Canon EOS M6 II
Alastair Norcross
I can post the full size versions of the full frames too, if you’re interested.
Alastair
m100
Thanks !
Test photos from lenses that do not cost a lot that are sharp in the corners at f/1.8 ?  Much interested.
Canon EOS M6 II
What is your assessment of the RF 16 @F8 vs the M11-22 @ 11mm @ F8?
Sittatunga Veteran Member • Posts: 5,406
MAC, there you go, resampled whole images and 100% top corners, M100 v R. DPP4, all corrections and DLO.
11mm/8
11mm/8 Top left DPP4
11mm/8 Top left DxO PhotoLab5
11mm/8 Top right DPP4
11mm/8 Top right DxO PhotoLab
16mm/8
16mm/8 Top left DPP4
16mm/8 Top left DxO PhotoLab5
16mm/8 Top right DPP4
16mm/8 Top right DxO PhotoLab5
do I have this right?
the EF 16-35 f4 IS L wins at 16 mm f8 - although heavy
the M 11 -22 at 11mm is 17.6 mm (FOV) but comes in second place @ F8
and the RF 16mm f2.8 doesn't have IS and comes in third at F8
https://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=1573&Camera=1508&Sample=0&FLI=0&API=4&LensComp=967&CameraComp=812&SampleComp=0&FLIComp=0&APIComp=3
https://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=949&Camera=979&Sample=0&FLI=0&API=3&LensComp=967&CameraComp=812&SampleComp=0&FLIComp=0&APIComp=3
https://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=949&Camera=979&Sample=0&FLI=0&API=3&LensComp=1573&CameraComp=1508&SampleComp=0&FLIComp=0&APIComp=4
MAC wrote:
That's not what the samples I posted say. I didn't include the 16-35mm that day.
Sittatunga wrote:
MAC wrote:
your EXIF says 16-35 with the R
MAC wrote:
Sittatunga wrote:
MAC wrote:
Apologies, mea culpa, I did these December 2021 and assumed with the 16mm series starting with f/2.8 they were all from the RF lens. I somehow used f/6.3 with the RF lens instead of f/8. I thought those 16mm shots looked a bit good, but you have to look very carefully to see the differences if you're looking at a real print instead of pixel peeking. The extra field of view from the DxO lack of cropping really does affect corner resolution though, and DPP4 seems to give the same field of view from the two lenses at 16mm, almost to the pixel.
Here's the field of view,
RF 16mm DPP4
RF 16mm/6.3 top left DPP4
RF 16mm/6.3 top left DxO
11mm/8 top left DPP4
EF 16mm/8 top left DPP4
RF 16mm/6.3 top right DPP4
RF 16mm/6.3 top right DxO
11mm/8 top right DPP4
Sorry it's too late to edit the original. For the DxO and DPP4 framing comparison, here's another image.
Alastair Norcross
Thanks !
Here you go. Nothing interesting, I'm afraid. Remember that the focus was on the upper left corner in each image:
Alastair
Fjzk Regular Member • Posts: 220
Thanks for posting these photos, Alastair. Love this lens in my RP, very happy to know it will work this well should I ever buy a crop R camera.
 Fjzk's gear list:Fjzk's gear list
Canon EOS M50 Canon EOS RP Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +8 more
