Sigma fp rotary dial bug
Started 1 month ago | Discussions
dr.noise
dr.noise Veteran Member • Posts: 3,779
I rarely use my Sigma fp so it's basically like new and nothing could have worn mechanically up to now.
But the dial on the back of the camera suddenly started to behave erratically. Instead of changing the value up it could randomly change it down, and vice versa.
I wonder if someone has met this problem, and maybe there is some way to fix it without sending the camera to repair.
I'm thinking about maybe injecting a small drop of 99.7% isopropyl alcohol under the wheel to clean it from the inside, could it be harmful?
This dial was a disappointment from the start. It is so flimsy and cheap and rotates too easily.
 dr.noise's gear list:dr.noise's gear list
Sigma DP2s Sony DSC-RX0 Sigma SD10 Olympus OM-D E-M10 II Sigma fp
victorgv
victorgv Senior Member • Posts: 2,123
Re: Sigma fp rotary dial bug
Just fast rotate it a few times it should clean oxidation or dirt
 victorgv's gear list:victorgv's gear list
Sigma DP1 Sigma DP2 Merrill Sigma dp2 Quattro Sigma sd Quattro H
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
dr.noise,
It's like the dials on the dp Q, with the camera turned off spin the dial quickly a few times and it will clear off any oxidisation which happens from lack of use or,maybe, as a result of moisture from the fingers getting in there.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
Scottelly
Scottelly Forum Pro • Posts: 18,026
Ceistinne wrote:
dr.noise,
I thought the fp was supposed to be weather sealed. AmI wrong about this?
S
Why would there be oxidation? Wouldn't the contacts be gold plated?
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
dr.noise
OP dr.noise Veteran Member • Posts: 3,779
Fixed!
As suggested by Victor and Ceistinne, several quick rotations while depressing the wheel did the job. Seems to be working ok now. Thanks much!
bizi clop
bizi clop Contributing Member • Posts: 640
This is a bug that Sigma should really fix. Do any Sigma camera with a rotary dial exist that doesn't eventually develop this problem?
 bizi clop's gear list:bizi clop's gear list
Canon PowerShot G2 Sigma DP2 Merrill Canon PowerShot SX50 HS
victorgv
Unless they use optical or magnetic sensor instead of
https://1.img-dpreview.com/files/p/TS560x560~forums/57530859/e269c888ab89441d86ecfb631fff6085
from dp2q
Johan Borg Veteran Member • Posts: 3,433
Which may be why they changed it for the fp L. Mine did the same, so instead of having it repaired I opted for the dial conversion service:
https://www.sigma-global.com/en/news/2021/06/03/14184/
 Johan Borg's gear list:Johan Borg's gear list
Sigma dp2 Quattro Sigma fp Sigma 45mm F2.8 DG DN
dr.noise
Oh! Sounds like I need it too! Will check with local Sigma service.
