Setting an ISO minimum of 400 seems to have no effect in Auto ISO
Started 1 month ago | Questions
Brian Greenstone Forum Member • Posts: 74
If I set my ISO speed range to a minimum of 400 it seems to have zero effect when shooting in Auto ISO mode as you can see in the screenshot. It still picks ISO's below 400.
Also, I have HDR PQ enabled which has a base ISO of 400 and it's not giving me any indication of this.  But if I switch to C-Log 3 then Auto ISO won't go below 800 which is the base ISO for that, and if I manually try to select anything less it indicates it with an "L".
So, two questions:
1.  Shouldn't Auto ISO honor my ISO speed ranges?
2.  Shouldn't HDR PQ mode behave like CLog3 mode and limit the minimum ISO to the base ISO, and indicate the lower ISO's with an "L"?
 Brian Greenstone's gear list:Brian Greenstone's gear list
Sony RX100 VII Canon EOS 7D Mark II
Steve_tEkGuY Contributing Member • Posts: 599
Re: Setting an ISO minimum of 400 seems to have no effect in Auto ISO
So, two questions:
Its silly but only the MAX settings apply to the Auto portion. There is no minimum for auto not like Sony or perhaps other manufacturers,
The ISO speed range values are only used when using manual ISO
@tekguyphoto
 Steve_tEkGuY's gear list:Steve_tEkGuY's gear list
Canon EOS R5 Canon EOS R6 Mark II Sony FE 28-70mm F3.5-5.6 OSS Sony FE 28mm F2 Canon RF 35mm F1.8 IS STM Macro +8 more
