User Experience is Top Metric Again
Started 1 month ago | Discussions
Klaus dk
Klaus dk Veteran Member • Posts: 9,755
Someone says ...
Jozef M wrote:
What if someone says to you: 'Canon is too expensive, camera bodies and lenses, and no third party lenses ...'
Jozef.
Someone says it all the time, so there's nothing new in that, but it's not as straightforward as it may seem. And the R system seems to be selling quite well, so maybe not everyone agrees.
"Expensive" is a relative term. I agree some Canon products cost more money than I'm willing to spend, but I don't agree that they're too expensive. Some competing products have marginally better specs, and lower prices, but specs aren't everything, and UX is one of the things that sets Canon apart from other manufacturers.
Another thing is, that with a Canon R system, all things play well together and that is also worth paying for, IMHO.
As long as my needs are covered by native RF lenses, I see no need for third party RF lenses. RF-S lenses clearly places APS-C as an entry-level tier, and I think it's a shame. It seems Canon has abandoned that market segment, perhaps because they don't want to cannibalise their FF market. I assume Canon is better at assessing their market than I am, but I suppose they could open the RF protocol to third parties if they saw an advantage in doing so.
R cameras apply digital lens correction for RF lenses to the VF and live view feed in real time, and also to both jpeg and raw files when shooting. If the same should apply to third party lenses, who's going to be responsible for flaws in that process?
It's been quite normal to see Sony cameras perform in unexpected ways regarding vignetting correction of third party lenses. By restricting access to the RF protocol, Canon has avoided that.
Good luck and good light.
 Klaus dk's gear list:Klaus dk's gear list
Sony RX100 II Canon EOS R Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 24-105mm F4L IS USM +7 more
koenkooi Contributing Member • Posts: 920
Re: Someone says ...
Klaus dk wrote:
R cameras apply digital lens correction for RF lenses to the VF and live view feed in real time, and also to both jpeg and raw files when shooting. [...]
An R camera does not apply anything to RAW files, your RAW converter of choice on your computer/phone/tablet will apply corrections, if you choose to. For some RF lenses, Canon doesn't allow you to turn those off in DPP4, but LR/DxO/C1 and others are still very much opt-in for optical corrections.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
SNJops
SNJops Regular Member • Posts: 362
Klaus dk wrote:
Jozef.
In terms of paying for everything working together you get that on Sony as well even with 3rd party lenses. Zeiss, Voigtländer, Tamron, Tokina and Sigma all have licenses to make glass for emout so no compatibility issues. Even reverse engineered options from Samyang work well and any issues are resolved with firmware updates.
For me the ability to use 3rd party lenses enhances my user experience of the Sony platform. For example I have a manual focus 50mm f1.2 lens from Voigtländer which gives me a different look from my 50mm f1.2 GM and because it mounts natively I don’t need any adapters.
Sony’s 3rd generation of cameras their ergonomics where definitely inferior to Canon and Nikon. 4th generation for me personally Sony is as good. I have held an R5 and R6 and I find them as good in the hand as my A7RIV, others will disagree but that was my experience. When holding Canon cameras with larger adapted lenses however is a different story, I held an R6 with an adapted Sigma 85mm f1.4 HSM and it was awful in the hand. Way too heavy and unbalanced, can only imagine how much worse a 70-200 or 100-400 EF would feel to hold. Speaking for myself only.
 SNJops's gear list:SNJops's gear list
Sony a7R IV Sony FE 55mm F1.8 Sony FE 85mm F1.4 GM Sony FE 200-600 F5.6-6.3 Sigma 24-70 F2.8 DG DN +4 more
José B
José B Forum Pro • Posts: 20,482
Re: User Experience is Top Metric Again
CamerEyes wrote:
Let's face it - dynamic range, high ISO noise and all those traditionally explosive areas of argument regarding which camera is better is now generally history.
With DR and IQ across camera brands just marginally different, the other area of debate is which has better AF. Again, the differences right now across camera brands are marginal.
To me, Canon remains a preferred choice because of superb ergonomics. The way it handles, the way it feels on my hands. Can be subjective. But the grip on Canon cameras - including smaller bodies such as the R10, remain superior to my view.
Specs matters. Megapixels count (literally, especially). Ergonomics to me is more valuable than ever, especially as lenses become bigger / fatter / heavier.
Then there's the menu system. While Sony's menu layout and intuitiveness has improved over the past few years, Canon's menu remains the simplest to navigate.
Are we at the stage of photography when cameras across brands are becoming more similar in "technical" capabilities?
I shoot with both Canon 5Ds and Sony APS-C A6600 systems. Got into Sony mirrorless system mainly due because of travel. I started buying more lenses into the Sony and so now I shoot everything from portraits to sports. The handling of the A6600 (it has a deeper grip than the older A6xxx series) is more comfortable to hold especially for my biggest lens which is the 135/1.8 GM.
Having said the above, I tried the A7IV at a store last week. On it was the 24-105/4 G----it felt really tight on my right hand. Somehow my A6600 + 135mm felt more comfortable. The ergo of the R6MKII is more to my liking. Thus between these two cameras without a doubt I'll get the Canon.
 José B's gear list:José B's gear list
Canon EOS R6 Mark II Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5DS Sony a6500 +16 more
David Hull
David Hull Veteran Member • Posts: 6,831
Jozef M wrote:
David Hull wrote:
Jozef.
If you are buying Canon, you are not worrying about "expensive." Canon has not been the low priced alternative for quite some time. If you are worried about TP lenses, once again, there are alternatives.
It isn't like Canon is the only option out there. You must make a decision and, yes indeed, all these things are factors.
Edit: in writing this comment, I have in mind something like the R5 and "L" glass. As one other poster points out, Canon offers great cameras in all price ranges. It’s a bit like complaining that a Lexus is too expensive – well, that’s why there is a Camry.
So you are saying here that it is correct, the statement that Canon is too expensive for what it is worth. Very good. The competition is cheaper and equally good, especially in the lens field.
The cheaper-priced cameras do not have a well-built and cheaper lens catalogue.
If you want to defend Canon at all costs, dismissing any negative criticism, you will end up in the slavish follower approach, all those who say a bad word about Canon are against me and I will destroy you. This is not smart, David.
You can also say: 'Come on Canon, give us some cheaper prices for your L-glass, these prices are a bit too excessive.'
This is all I have to say about this subject.
Jozef
You are trying to make the argument that Canon is "too expensive for what it's worth" i.e., overpriced. You are also trying to make the argument that other manufacturers products are just as good while being cheaper.
So, if all this is true, just buy the other product and be done with it -- price is your driver. Unfortunately, though, this doesn't seem to be the case. By your own admission, there is apparently something you like about that Canon "L" glass that the others don't offer. You just don't like the price.
Unfortunately (for us), Canon seems to want premium prices for their premium stuff. Fortunately (for Canon) enough people are bellying up to the bar that they can get those prices.  Canon is not the only company like that -- vote with your wallet if you are unhappy, then. -- as you say there are other options.
 David Hull's gear list:David Hull's gear list
Canon EOS R Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +1 more
Jonathan Thill Regular Member • Posts: 188
SNJops wrote:
Klaus dk wrote:
Jozef.
While it is nice that Sony is currently not blocking 3rd party glass they do block some features with 3rd party glass just like the rest of the industry.
There are loads (80ish on BH) of great Manual AF options in the RF mount from 3rd parties. No adaptor needed.
I agree I am not a fan of the extra length from the adaptor on bigger lenses, but I do like the VND adaptor with manual Cine lenses.
 Jonathan Thill's gear list:Jonathan Thill's gear list
Canon EOS R3 Canon EOS R7 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +4 more
Steve Balcombe Forum Pro • Posts: 15,571
Ironically, the EOS R system product which I have personally been least satisfied with (in many respects, not all) is the one which is an absolute bargain and cheaper than almost anyone expected - the R7. I so wish they had gone for a higher spec sensor and a more R5/R6-like body, at whatever price would have made that possible. 50% more would still be only £2k.
Klaus dk
Re: So
You're (mostly) right. What is added is some kind of lens ID, which points to a corrections recipe in DPP.
your RAW converter of choice on your computer/phone/tablet will apply corrections, if you choose to,
— and if they're available. It took some time before some hero added them to lensfun.
... making the 24-240 a bit wider at the wide end, but also making the corners very dark.
David Hull
Klaus dk wrote:
Jozef.
Well put.
Same for me. I would probably feel differently if there was some third-party lens that I felt I really needed, but Canon pretty much has me covered. I do mostly travel stuff these days. A 24-105 L F4 and a 15-35 L K2.8 are all I carry with my R5. I have the older R and a second 24-105 as backup.  Thats all I ever take.
FWIW: If you like APSC, there is nothing stopping you from using "L" lenses that were designed for full frame. I would think that you will have better photos since the photo area occupies the sweet spot of the lens. Unfortunately, there is the added cost and weight of the "L" stuff. We went through this with the EF-S series, they never put an "L" on any of them, but some were quite nice. The EF-S 10-22 for example.
It's been quite normal to see Sony cameras perform in unexpected ways regarding vignetting correction of third-party lenses. By restricting access to the RF protocol, Canon has avoided that.
David Hull
expro wrote:
Agree all three brands are the same now. Just depends which you prefer to own/use and have the cash for.
I’ve owned canon for thirty years and have zero interest in other brands as they always have had an offering that suited me.
Yea, that brings up another point. When the Canon R mount came out along with the Nikon "Z mount" I realized that I would be rebuilding my kit.
Was now the time to switch systems? I came to a similar conclusion -- I decided to remain with Canon and bought an R. There are a lot of things that would have to be changed out, flashes came to mind for one thing, but another was the system knowledge that you have from 30 years of experience.
I always expected that Canon would eventually match the performance of the Sony sensors and for all practical purposes they have.
charlyw64 Contributing Member • Posts: 717
And for me that would have priced me out of the system. The R7 was the only one even remotely fitting my needs and price - if you can afford full frame then it's ok to price the APS-C performance camera out of the hands of those that can't cough up that much money you obviously so casually can spend.
But it isn't the "APS-C performance camera", that's the whole point. It's a mid-range body at a very keen price, and as such it appeals to a lot of people including yourself. What it's not, is the high-end crop body that others were waiting and hoping for. The R7 name is a big hint that there will never be one, which is making many people look at Olympus and Fujifilm.
By the way, I don't have a lot of time for your 'inverted snobbery'. For most of my working life I didn't have the disposable income for anything more than a basic SLR body (which I never upgraded) and a very small set of non-L lenses. But now I'm lucky enough to be able to choose better gear and I make no apology for that. That said, "only £2k" wasn't intended to suggest this is pocket change, only that it would be a good price for a truly high-end APS-C body like the £2,500 Fujifilm X-H2S with the benefit of Canon's AF technology. Even the OM-1 with its even smaller M4/3 sensor is over £2k.
m100
m100 Senior Member • Posts: 2,048
I do not like the way the swing out screens wobble when I use them.
For pro use doing fast product photography with the camera mounted on a tripod I like a tilt screen.
To make money using a camera I do not need a FF and for sure a smartphone camera will not do.
I find tripod stabilization a must.
Dr. says listen to this every morning.
https://www.youtube.com/watch?v=bEeaS6fuUoA
 m100's gear list:m100's gear list
Canon EOS M6 II
I beg to differ, it is faster than any APS-C ever made by Canon, it has a more comprehensive and capable autofocus than any APS-C ever made by Canon. There is nothing the 7DII does better (besides having an optical viewfinder - but even I had to concede that they have become unaffordable to produce) except maybe weather sealing.
You are too hung up on the name - which is rather short sighted.
Then be specific, what is missing besides an IP-67 water sealed rating? What would you have added to justify the cited price? I have always shot with DSLR as soon as they became affordable, starting with the 10D, culminating in the 7DII which I used for 8 years. The offerings by Olympus and especially Fuji are horrible in usability and partly in image quality (too small sensor for Olympus and don't get me started on the x-trans malarkey in the Fuji, they themselves are not so keen on that, else their medium format cameras would have had that same CFA - you could offer them as a giveaway in a supermarket promotion alongside a roll of toilet paper and I wouldn't jump ship to those)...
The OM-1 has an IP53 rating, as do a few of the lenses; the Fujifilm has no rating.
I answered that in the post you originally responded to, but I guess any suggestion that there is a world beyond the R7 is dealt with by selective memory.
Canon could learn a lesson or two about usability from the OM-1, but clearly you have never used one. I haven't personally used the X-H2S, but in the part of my post which you conveniently cut, the only specific comment I made was about the price.
If you had used an OM-1 you wouldn't be so critical of the sensor. Its readout speed makes the R7 look antiquated, and the difference in size between Canon APS-C and M4/3 is only a 1.25x additional crop - which is why, if you look at actual images, the OM-1 is right up there.
The Olympus cameras are unusable for me, to finicky, bad EVF (for me, all I ever tried did trigger migraines, the R7 I tested extensively and luckily that viewfinder is bearable). I hope Canon does not follow those unbearable chimeras, I never liked Olympus "usability"...
The readout speed is of no consequence to me, I don't intend to ever use the fully electronic shutter. Gimmicks like Pre-Burst or focus stacking (especially the latter is a horrible waste of developers time for the firmware, focus stacks don't work).
For me the image quality doesn't stop at the rolling shutter, it is defined by a lot of features and for those the Olympus cameras and lenses suck and are much more expensive than the Canon. Besides that, I expect OM Systems to fail quite soon, they have lost their appeal to many...
There is so much arrant nonsense here that I will step out of the discussion at this point.
