User Experience is Top Metric Again
Started 1 month ago | Discussions
CamerEyes Regular Member • Posts: 266
7
Let's face it - dynamic range, high ISO noise and all those traditionally explosive areas of argument regarding which camera is better is now generally history.
With DR and IQ across camera brands just marginally different, the other area of debate is which has better AF. Again, the differences right now across camera brands are marginal.
To me, Canon remains a preferred choice because of superb ergonomics. The way it handles, the way it feels on my hands. Can be subjective. But the grip on Canon cameras - including smaller bodies such as the R10, remain superior to my view.
Specs matters. Megapixels count (literally, especially). Ergonomics to me is more valuable than ever, especially as lenses become bigger / fatter / heavier.
Then there's the menu system. While Sony's menu layout and intuitiveness has improved over the past few years, Canon's menu remains the simplest to navigate.
Are we at the stage of photography when cameras across brands are becoming more similar in "technical" capabilities?
 CamerEyes's gear list:CamerEyes's gear list
Sony a7C Canon EOS R7 Canon EOS R6 Mark II Canon EF 50mm f/1.2L USM Canon EF 50mm F1.4 USM +12 more
Canon EOS R10
David Hull
David Hull Veteran Member • Posts: 6,831
Re: User Experience is Top Metric Again
Pretty much, IMO. Canon has one more thing going for it which is superb customer service. You hope this stuff never breaks down but occasionally it does and when it does, Canon has some of the best service support I have ever encountered.
A few years ago, the function knob fell off on my M5 about two weeks before I was leaving for Europe. There was no time to send it to NJ, get it fixed and get it back even if we expedited it. There were 2 weeks left on the 1-year warranty. The guy I spoke with in NJ told me to save the knob at home, use the menus on the touch screen and send it in when i get back -- don't worry about the warranty.
Turn around is quick and they keep you posted as to what is going on.
 David Hull's gear list:David Hull's gear list
Canon EOS R Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +1 more
charlyw64 Contributing Member • Posts: 717
Pretty much spot on. For my photography (I abhor HDR and mostly photograph were I am in - partial but sufficiently - control of the light) the ergonomics have always trumped the spec sheets. Nikon could have made a professional grade camera for $100 and I wouldn't have switched system, similar with Sony and Olympus because their ergonomics to my hands are horrendous. Fuji likewise, I don't get the retro vibe they go after, if I want retro I look at my shelf where my first camera (inherited from my farther who died much too early) but that too I wouldn't want to pick up today except to marvel how we managed to photograph anything with that kind of camera.
OP CamerEyes Regular Member • Posts: 266
Another excellent point, the after-sales support of a brand does define camera ownership experience!
In the few very instances I had a Canon camera repaired within warranty and outside of warranty, customer service in this side of Asia has been largely positive!
Jozef M Senior Member • Posts: 2,197
What if someone says to you: 'Canon is too expensive, camera bodies and lenses, and no third party lenses ...'
Jozef.
 Jozef M's gear list:Jozef M's gear list
Sigma DP3 Merrill Canon EOS 30D Panasonic Lumix DC-G9
There are plenty of lenses to go around, all EF lenses work without any big problems... Adapted lenses have big advantages, for one they are less expensive, a lot are available used in good condition and the adapters with control ring or filter are excellent ideas. The latter even gives you an incentive never to switch to RF lenses, and for that adapter the Meike version is even better because the VND-filter is better quality and a lot less expensive... The bodies are very competitively priced, so much so that even though 8 years of inflation happened the R7 is lower priced than the 7DII it for the most part replaces...
Steve Balcombe Forum Pro • Posts: 15,571
Never say never, but it's possible I will never give up my EF 16-35/4L IS.
I've never been able to do an actual back-to-back vs the Canon VND, but the Meike I recently picked up is very good.
I have seen a back to back test of the two and the Meike is clearly the better VND. It suffers from lower variability of the color cast (although at low filter settings it does have a noticeable warm color cast but it stays consistent across the whole range of filter strength - unlike the Canon which goes from neutral to decidedly weird) which means you can use it with a single white balance taken best at middle strength. The Meike VND also does not exhibit the typical cross polarization vignetting that runs through the frame unlike the Canon:
https://www.youtube.com/watch?v=l061YS30Qno
For the price I think the Meike is a nobrainer. I now have found another one that I hope to test out some time this summer, the JJC, which comes with polarizer and VND out of the box, because I am mainly interested in the polarizer this means I am drawn to this one as it costs about the same as the Meike which only comes with the VND and clear filter and you must buy the polarizer separately.
That was very interesting, thanks for the link. I made my decision based on the cost and a couple of favourable reviews, so it's good to see it supported by CVP too.
I was originally planning to go with Breakthrough Filters, and even placed an order, but they were chronically unable to supply the product so I gave up and cancelled. More than two years later the adapter is still showing as "Coming soon" on their website" 🙃
I've spent my money now, but it will be interesting to see what JJC can do for an even lower price.
ZX11
ZX11 Veteran Member • Posts: 6,156
Jozef.
I point them to manufactures that make cheap cameras and even cheaper lenses.  Plenty of choices out there for all budgets.  But, there are hidden downsides to using cheap tools made by cheap labor.
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
ZX11
All the cameras are capable for basic photography. Canon support and build quality attracted me to the brand. Plus, I like the closed system Canon has implemented.   The parts of the kit just work and are backed by Canon.
No worries as I know who built it.
charisgratia Regular Member • Posts: 224
ZX11 wrote:
Jozef.
The cheapest as well as most expensive cameras I've owned have been Canon. Same for lenses. There's a camera/lens for every budget with Canon.
ZX11
charisgratia wrote:
ZX11 wrote:
Jozef.
Yes but,...I am referring to getting a cheap body or lenses from other brands with all the features and, on the surface appearing to, has all the same specs for cheaper price.
Canon putting more build cost into quality materials (that don't matter when new), cost of quality design versus just a clone copy, and quality labor (resulting in less copy to copy variations).
Something for everyone while the basic photography mission is met.
ZX11 wrote:
charisgratia wrote:
ZX11 wrote:
Jozef.
Ok. Got it!
expro Senior Member • Posts: 2,273
Agree all three brands are the same now. Just depends which you prefer to own/use and have the cash for.
I’ve owned canon for thirty years and have zero interest in other brands as they always have had an offering that suited me.
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
David Hull
Jozef.
If you are buying Canon, you are not worrying about "expensive." Canon has not been the low priced alternative for quite some time. If you are worried about TP lenses, once again, there are alternatives.
It isn't like Canon is the only option out there. You must make a decision and, yes indeed, all these things are factors.
Edit: in writing this comment, I have in mind something like the R5 and "L" glass. As one other poster points out, Canon offers great cameras in all price ranges. It’s a bit like complaining that a Lexus is too expensive – well, that’s why there is a Camry.
David Hull wrote:
Jozef.
So you are saying here that it is correct, the statement that Canon is too expensive for what it is worth. Very good. The competition is cheaper and equally good, especially in the lens field.
The cheaper-priced cameras do not have a well-built and cheaper lens catalogue.
If you want to defend Canon at all costs, dismissing any negative criticism, you will end up in the slavish follower approach, all those who say a bad word about Canon are against me and I will destroy you. This is not smart, David.
You can also say: 'Come on Canon, give us some cheaper prices for your L-glass, these prices are a bit too excessive.'
This is all I have to say about this subject.
Jozef
KEG
KEG Veteran Member • Posts: 4,909
Jozef.
Hasselblad and Leica are more expensive.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
KEG wrote:
Jozef.
That's what my mother used to call a "backhanded compliment".
Rock and Rollei Senior Member • Posts: 2,900
It's always been true. You take more and better pictures with a camera you enjoy using than with one with superior performance that you don't enjoy using. And the technical differences between cameras have never been as stark as people on these forums make out - it's almost as though the "digital" in the site's title refers to opinions, something is either 100% perfect or 0% useful, never anywhere in between.
I often say that Sony is a top consumer electronics company, whereas Canon is a top camera company. For me, Canon cameras have always made it easy to get the right results, whereas Sonys, even when technically superior, have always been more of a PITA, from menu structures, viewfinders (I've yet to find a Sony camera whose viewfinder doesn't trigger my residual balance disorder, although I've not tried one in the last year) or aftersales support. Sonys feel to me like the results of various compartmentalised departments all stuck together, Canons feel like there's an integrated approach. Now of course YMMV, others might disagree with all of that, and that's fine - it's user experience either way.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
