Olympus 14-42 f3.5-5.6 sometimes under exposing.
Meterman-Can New Member • Posts: 2
This lens is paired with my E-M1 Mk2. Body is firmware v3.6, lens is v1.1
When the camera is turned on when the lens is extended, sometimes, there is a buzz and the image is very dark and will underexpose. This seems to happen if zoomed between 16 and 35mm. When the camera is turned on when the lens is locked then unlocked after "Lens is locked, please extend the lens" is shown, it exposes properly.
Anybody else had this issue?
Olympus E-M1 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R
Stephen Strangways
Stephen Strangways Contributing Member • Posts: 984
Re: Olympus 14-42 f3.5-5.6 sometimes under exposing.
Sounds like the flex cable is on its way out. Sometimes it bends the right way to still make contact, sometimes it bends the wrong way and contact is broken. It just wears out from zooming and collapsing in and out. It will keep getting worse until the lens stops working entirely. The labour costs of fixing it will be more than the lens is worth.
OP Meterman-Can New Member • Posts: 2
Thanks. Sounds like it. I may throw $20 for a DIY cable repair.
It's had a good run, original kit lens from my pen e-pl2. Time to upgrade to a used 12-40mm F2.8
tedolf
tedolf Forum Pro • Posts: 29,548
Easy repair.....
It's a fairly easy repair to do and there are some YouTube video's to walk you through it.
Tedolph
 tedolf's gear list:tedolf's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Samyang 7.5mm F3.5 Fisheye +9 more
