Canon Eos R6 Mark II Screen problem
Started 1 month ago | Questions
Jeki New Member • Posts: 16
I received this camera a month ago and this problem has occurred twice so far, the second day after receiving the camera and yesterday when I was changing some settings. The first time this happened, the camera jumped from one menu to another on its own. I turned off the camera and removed the battery and everything worked fine after that. I also installed new firmware, but it happened again.
Does anyone have an idea what could be causing this problem?
Here is the link: (2) Canon Eos R6 Mark II Screen problem - YouTube
Canon EOS R6 Mark II
drsnoopy Senior Member • Posts: 1,216
Re: Canon Eos R6 Mark II Screen problem
Sorry, but it looks like a hardware problem to me, maybe a broken or damaged connector to the LCD screen.  If you close the screen completely (turn it over), does the same thing happen through the viewfinder?  If not, you could continue using it on EVF only.
My suggestion is take it back to the store, or return it, or send it for repair.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
OP Jeki New Member • Posts: 16
Thank you!
It happened only on two occasions. I used the camera today at a soccer game and everything was fine.
It's difficult to provoke the problem to happen again because I only used the display to make settings and nothing else, so I don't know what to do to make the problem appear again for testing...
Your suggestion that I send the camera to the service center sounds like the best and safest thing to do.
J.K.T. Contributing Member • Posts: 512
Unfortunately it likely won't help either. They'll try it, can't repeat the problem and return it. The only help is that if it gets worse later, you can prove you have reported the problem long time ago.
 J.K.T.'s gear list:J.K.T.'s gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS R7 Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM +15 more
Thank you for your reply !
Yes, such a possibility exists, unfortunately, but I still hope that they can and know how to do something that I am not aware of, and they will find out what the problem is. It's worth a try.
