Re: What features do you never use?
8
PhotoMac503 wrote:
-Custom modes (copying someone else's settings might as well use Automatic)
That's not what custom modes are for. Custom modes are for fixing YOUR settings into memory. Settings such as button assignments, focus settings, file size and types, how memory cards are used, and a whole bunch more. That way, if you change settings during a shoot, you can reset the camera to your defaults (or one of your defaults if you use more than just C1) without having to manually change each setting back. This is especially important if you shoot genres that require different mixes of settings.
For example, on my E-M1.3, C1 is where I keep my default settings. I did watch a few videos and read a book or two for advice, but every setting I chose I selected myself. No matter how I change camera settings during the day, I can always get it back to my defaults by selecting C1. That way, when I pick up the camera I know how it will be set up and there are no surprises.
My C2 is just like C1 except that I have the camera set for Monochrome (with my preferred sub-settings), which gives me a quick way to go from one to the other, which I do quite often.
I reserve C3 and C4 for special occasions, and I set them up beforehand. Usually, I copy C1 to C3, make the necessary changes, then copy C3 to C4 and switch from Natural to Monochrome. I like have two matched pairs of settings.
My C1 and C2 do a good job for family pics, travel pics, hiking, etc. For macro, astro, etc., they don't work as well, so they get the C3/C4 treatment. When I take photos for work (I am a civil engineer, so project site photos and construction photos), I set up C3 for lower resolution JPGs instead of RAW+JPG and I ignore C4.
Most of the time, I use aperture priority. Some of the time (like the photos I took during our church service this morning for the church website), I shoot manual. So, early this morning, I copied C1 to PASM, switched to M, made a few setting changes, then copied these settings to C3 and C4. Finally, I changed C4 to Monochrome and I was good to go.
Frankly, I would like the ability to save 8 to 12 sets of settings, then recall the ones I want to C1/C2/C3/C4.
'Is it the only lesson of history that mankind is unteachable?'
…Winston S. Churchill
