Firmware Version History??
Started 1 month ago | Discussions
Pete Regular Member • Posts: 230
Hi,
I've been searching the WEB and have written to Samsung Support about this question - all without any luck.
Does anyone know if there is a place on the WEB where I can find Samsung Camera Firmware Version History - a list of a specific camera model's firmware history from first to last that includes a description of what each update did?
I have two NX-Minis - one at 1.03 - the other at 1.04 and I see the last update was 1.10. It would be nice to know if what the update does is worth the risk of bricking the camera.
I am particularly cautious about updates - I just went through some pain with two Samsung Note 4s. Samsung's Smart Switch tool detected the need for an update - downloaded it, but failed to transfer the update to the camera - after several attempts - the transfer started and then stalled for hours at 3% - and this bricked the phone. After weeks, I have not been able to get any help from Samsung, or Verizon Support. Although Smart Switch was supposed to download the drivers it needed - it always appeared this was a driver issue as the phone was no longer a connected device on the PC after the download was complete and transfer was supposed to start.
I'd like to avoid the same pain with the the NX Minis.
I've been advised that the best way is to download the udate to the camera's micro SD card (probably a clean formatted one is best). I also read you can update directly from the camera via the camera's built in wi-fi, or via connection to a PC using i-link. Samsung is not in the camera busines - are all these three methods still available?
Thanks!
Pete
 Pete's gear list:Pete's gear list
Samsung NX mini
kypfer Contributing Member • Posts: 985
Re: Firmware Version History??
Samsung data is getting a bit thin on the ground.
You might try the WayBack Machine web.archive.org and see if there's anything historic stored there.
FWIW, I've updated both my NX-5 and my NX-11 (and my only NX lens) to the latest firmware I could find by transferring the update file to an SD card and working from there, but I've no experience with the NX Mini.
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
ArendjeF Junior Member • Posts: 28
LS,
Here is a link to the NX and Mini cameras:
https://matteverglade.com/cameras/nx-firmware/
You may find this helpful.
OP Pete Regular Member • Posts: 230
THANKS!!
I'd been to that page last week - but the history links didn't work. I tried again from your link and the history was there! I think the difference was last week I used an old PC with an old browser - this time a windows 10 PC with up to date Chrome.
Pete
Samsung NX mini
NXfiles
NXfiles New Member • Posts: 6
Hi,
I have used wayback machine and found many old firmware files and manuals. I collect them now at https://nxfiles.nx.tc/
Write me a DM if you can provide more files to complete collection.
 NXfiles's gear list:NXfiles's gear list
Samsung NX mini Samsung NX1 Samsung NX500
markyboy81 Veteran Member • Posts: 4,778
That website is still there but the files are no longer stored. If you're lucky they may be stored via the wayback machine. I had some luck finding files there.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
