Canon EOS in WeMacro rail.
Started 1 month ago | Questions
sjubussen
sjubussen New Member • Posts: 6
I have recently purchased a Wemacro rail and tried it for the first. The problem is that i get some photos in picture style Portrait even though the camera picture style is set to Landscape. Anyone who can tell me how to fix this problem?
 sjubussen's gear list:sjubussen's gear list
Panasonic FZ80/FZ82 Nikon Coolpix P1000 Canon EOS RP
drsnoopy Senior Member • Posts: 1,216
Re: Canon EOS in WeMacro rail.
As far as I can see the Wemacro rail is just a powered macro rail. It appears that the only connection to the camera is via a shutter release cable. That should have no effect on Picture Style, which is something you set in the Shoot menu, and allows you set Sharpness, Saturation, Contrast etc - and once set, all images should have the same setting. Which camera are you using? Are you specifically choosing a Picture Style?  Does it affect all the images in a series, of just some?
(…I assume you’re taking about Portrait and Landscape in those terms, not vertical and horizontal orientation)
Also what software are you using to stack the resulting images? I think only Canon’s DPP4 allows you to adjust the Picture Style (as set on the camera) during RAW conversion, so I would be looking at whether there is something happening in DPP to explain your problem.
Though I can’t directly explain the issue you are having, if you are using DPP, you should be able to re-set the Picture Style so that all the images use the same chosen style. Perhaps try that and let us know how you get on.
Hope this helps.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
sjubussen
OP sjubussen New Member • Posts: 6
I might have misunderstood something here, and i know that the rail is not part of the problem. I think of Portrait and Landscape as in a printer setup instead of horizontal and vertical. So my problem is that some of the pictures are horizontal and others are vertical and this will not give a beautiful stacked image.  My setup is Canon RP and i use Lightroom/Photoshop for stacking.
J.K.T. Contributing Member • Posts: 512
Now that problem is much easier to solve.
In camera settings you have a choice to let the camera choose the orientation automatically. That is a BIG problem if you are shooting in vertical orientation. The choice becomes pretty much random. So the solution is to turn off the automatic rotation. I don't recall where that setting was, so look it up from the manual.
 J.K.T.'s gear list:J.K.T.'s gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS R7 Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM +15 more
Turn off Auto Rotate
Ah ha - I did ask if you were confusing “Picture Style” with orientation. On the RP it’s the yellow wrench menu, tab 1, Auto rotate - turn it Off.
