Can the Canon EOS R8 be a USB-powered webcam?
Started 1 month ago | Questions
squarewave
squarewave New Member • Posts: 23
I've not heard it confirmed if the R8 can do this, obviously it's not a headliner feature that the YouTubers would focus on. But I wondered if anyone knew if the R8 can be used as a webcam being completely powered by USB from the camera to the computer or if you would need a DC-coupler thingy to supply power?
 squarewave's gear list:squarewave's gear list
Canon EOS 550D Canon EOS M50 Canon EOS R7 Canon EF 50mm F1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS II +4 more
Canon EOS R8 Ricoh Caplio R8
koenkooi Contributing Member • Posts: 920
Re: Can the Canon EOS R8 be a USB-powered webcam?
If it’s like the R5, you will still need a battery with some charge left in the camera to use USB power. So it depends on how far you want to take ‘completely’
The manual isn’t available, so there isn’t a definitive answer on that yet.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
MikeJ9116 Veteran Member • Posts: 6,955
The R8 can be powered, or charged, from its USB C connection port.
Steven Blackwood Senior Member • Posts: 2,210
I have the R50. It uses the same battery as the R8. I started to do a time lapse with the R50 plugged into the mains via USB. When I went to check on it a few hours later, the battery was half-depleted, indicating that power was Not going to the camera. Turning the camera off, however did allow the usb powered mains to charge the battery. I'm not sure if this answers your question or not. The R8 may function differently.
Steve
stevenblackwood1950@gmail.com
Milwaukee WI
 Steven Blackwood's gear list:Steven Blackwood's gear list
Canon EOS R Canon EOS R6 Sigma 100-400mm F5-6.3 Canon EF 70-200 F4 II Canon RF 35mm F1.8 IS STM Macro +2 more
Was the charger a proper USB-C PD charger? And if so, what is the wattage? On my R5 charging uses less power and voltage than powering it. It might be that your charger doesn't support the 9V/1A mode, but it does support the 5V/1.5A mode.
That assumes the R50 behaves the same as the R5, though.
