Teleconverters RF vs EF
Started 1 month ago | Discussions
J.K.T. Contributing Member • Posts: 512
Re: Teleconverters RF vs EF
Shawn1519 wrote:
Asking the question a different way, take any lens/teleconverter combo (staying with the same format of EF or RF), put an extension tube between the lens and the teleconverter, and how does that effect image quality? That is in effect what Canon did with their RF 600 F4 and RF 400 F2.8 lens by incorporating the RF to EF adapter into the lens.
The answer is badly. By how much depends.
That is not what canon did with those. The distance from the lens to the sensor is still exactly the same in the RF version than it was for the EF version. It is the same whether you used "EF + DSLR", or "EF + RF2EF + R-body" or "RF + R-body". That dimension is the critical one.
If you add TC to the mix, things change. The rear of the TC must be the correct distance from the sensor. That is again a constant. The distance itself is a matter of design - in that respect EF and RF TCs differ ... as does the one embedded in RF 800 and RF 1200 as it seems to be even further away from sensor than EF TC.
Now when you put the lens in front of the TC, the lens distance is no longer the one it expects. That difference is, however, built into the TC design. It corrects the distance difference created by its own length. No more and no less than that.
So if you use "EF + EF TC + DSLR", everything is fine. If you use "EF + EF TC + RF2EF + R-body" instead, everything is still fine. It is also just as well to use "EF + RF2EF + RF TC + R-body" ... as long as you can find a fitting adapter of correct length. It is even optically OK to use "EF + EF TC + RF2EF + RF TC + R-body". The distances play still correctly as both TC:s correct the distance difference caused by their own length.
However, if you put extra extension somewhere in between, things are no longer going to play nice. The strength of the effect likely depends on how much you add compared to how much distance there is supposed to be from the last element to the sensor. That's why it is really bad idea to put extra extension on body side of TC:S ... and particularly RF TC:s.
 J.K.T.'s gear list:J.K.T.'s gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS R7 Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM +15 more
OP Shawn1519 Forum Member • Posts: 68
Thanks everyone for responding.  After thinking about this some more, examining how tele's work on DSLRs and EF lenses.  For example the EF 600 F4 lens the focal plane of the lens is the rear of the lens plus the distance from the lens to the sensor - put a tele in the mix, and the front element of the tele is much closer to the rear element of the lens than what the above described focal plane - thus the optical design of the tele must accomodate this.  The RF and EF tele's are obviously completely different optical designs, and the RF tele's are designed to accomodate the difference in focal plane distance between RF and EF lenses.
But one strange anomaly still exists (and this was pointed out by one person in this thread).  By design, a RF tele won't fit on a EF2RF adapter.  But yet the RF 600F4 and RF 400F2.8 lenses violate this design by allowing a RF tele to fit on the back of the (built in) EF2RF adapters on those 2 lenses.  This tells us that Canon modified the EF2RF adapter that they welded onto the RF 600F4 and RF 400F2.8 lenses.
Shawn
SafariBob
SafariBob Veteran Member • Posts: 3,852
don’t understand what this means.
I think your original questions show correct understanding, but I am not sure your conclusion is correct. Look into extension rings
 SafariBob's gear list:SafariBob's gear list
Sony RX1 Sony a7R II Sony a7R IV Canon EF 400mm f/2.8L IS USM Sony 70-400mm F4-5.6 G SSM +3 more
The reason the RF2EF adapter does not fit in front of the RF TC:s is not optical. It is mechanical interference between the extruding part of the TC and the light baffles in the adapter. The adapter needs the baffles in order to eliminate unwanted reflections with ALL the EF lenses. There are some sad examples with third party adapters on why that matters. I'd never use my modified adapter without TC - that would be asking for trouble.
When they made the tele lenses, they didn't have to worry about how reflections on any other lens work - they just had to avoid reflections on THAT lens. That they have been doing for decades. Sometimes there are baffles, sometimes not. They also have more freedom to design the potential baffles as the TC in those lenses seems to be yet another design and even further away from the sensor than the EF extenders are.
[It appears Steve already wrote most of this, but I missed it.]
Steve Balcombe Forum Pro • Posts: 15,571
I'm not sure that's what it tells us, or at least that's not the nub of it. Yes the built-in 'adapter' has to be different to physically accept the TC, but there's no reason I can think of why Canon couldn't have done the same with the normal adapter. But maybe the combination of an EF lens and an RF teleconverter is something Canon didn't want to support. I've been critical of several choices Canon has made regarding the RF mount (like why are there still no extension tubes???!!!) but this one does probably make sense.
Your are probably right, it probably doesnt tell us anything, but rather just an observation that they didnt allow RF teleconverters to connect to the standard EF2RF adapter, but allowed RF teleconverters to be connected to the EF2RF adapter that is permanently mounted to the RF 400 and RF 600 lenses.
Shawn
Quite simple, try to connect a RF teleconverter to the (camera side) of a EF2RF adapter - it wont fit because of the baffle that is on the end of the teleconverter is too large in diameter to fit into the EF2RF adapter.
Differently, the same RF teleconverter will connect/fit into the EF2RF adapter that is permanently connected to the RF 400 F2.8 and RF 600 F4 lenses.
Shawn
Le Kilt Senior Member • Posts: 2,527
3584mm equivalent !
Just imagine, if an RF2EF adapter becomes available that fits onto the RFx2 extender, it would be possible to mount :
RFx2 + RF2EF + EFx1.4 III + EFx2 II + 100-400 IS L II
giving zoomed at 400mm a 3584mm equivalent on an R7 !  You could shoot the man in the moon with that.  Will have to see if the AF tracking locks onto him if he's running around fast.
Ok, shooting at f/32 might be challenging, and a very stable tripod will be needed!
Sharpness?  We'll worry about that later
For a couple of dollars/pounds/euros more, an EF 600mm f/4 will even bump that up to 5376mm and gain a stop.
 Le Kilt's gear list:Le Kilt's gear list
Canon EF 16-35mm F2.8L II USM
Re: 3584mm equivalent !
Magnifying all the aberrations from EF 2x II 5.6 times...
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,242
I am not sure if eye AF works also with the helmets of the astronauts!
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS Ra Canon EOS R5 +30 more
sounds like Canon needs to get busy with updating their focus tracking to include  astronaut helmets - maybe they can add it to part of human eye tracking.
Shawn
Man in the Moon spotted !
Shawn
He doesn't appear to be wearing a helmet this evening !
Anyone else spot him too?
(ok, I might have highlighted his eyebrow a little, top right)
R7 + RF2EF + Kenko 1.4x + EF 1.4x III + EF 2x II + EF 100-400 II resized to 50%
