Pix for the Week Ending February 10th to 12th, 2023
Started 1 month ago | Photos
OP larryj Forum Pro • Posts: 13,086
Re: An old pano
Thanks David the quick response.  That DP3 M work wonders in your hands.   I have not used the PTGui software for a few years, may have to take another look.
larryj
If you can see the light, you can photograph it
Quote from Myron Woods
 larryj's gear list:larryj's gear list
Sigma SD1 Merrill Sigma 24-70mm F2.8 EX DG HSM Sigma 150-500mm F5-6.3 DG OS HSM Sigma 105mm F2.8 EX DG OS HSM Sigma 18-35mm F1.8 DC HSM Art +1 more
furtle
furtle Senior Member • Posts: 1,572
Re: Pix for the Week Ending February 10th to 12th, 2023
5
This is a home made sourdough loaf using home milled Spelt grain and shop bought organic strong white wheat flour. I added Linseed, Nigella seeds and olive oil. The rest is sea salt flakes and water. That's it. I thought it worthy of a bit of food photography. Shot with the dp0Q wide open using SFD.
Best, Steve
 furtle's gear list:furtle's gear list
Ricoh GR Digital III Sigma DP2 Merrill Sigma dp3 Quattro Sigma dp0 Quattro Sigma sd Quattro H +2 more
left eye Veteran Member • Posts: 3,032
Trees, Two Ways
sdQ-H + 28mm Art
Jack D. Senior Member • Posts: 2,708
Flood Water
5
 Jack D.'s gear list:Jack D.'s gear list
Sigma DP1x Sigma DP2 Merrill Sony a7 II
SigmaChrome Forum Pro • Posts: 15,728
Redo - from the vault
5
From December 2015.
The Glasshouse Mountains in Queensland. I came back to this image and had another crack at it. It was one of those shot that should never have be made using Auto WB -- the bane of the Merrill sensor. It looks better now.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sigma SD14 +42 more
Re: An old pano
Nice pano, David.
Vitée
DavidWright2010 Veteran Member • Posts: 3,733
Re: Redo - from the vault
SigmaChrome wrote:
From December 2015.
Looks like an interesting area. These peaks looked volcanic to me, so I looked it up and they are.
Do you have any pix in better light?
It almost looks like 'the eye of Sauron' on that rightmost peak.
David
 DavidWright2010's gear list:DavidWright2010's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Merrill Pentax K-1 +1 more
Beautiful image Vitee, thanks for sharing.
larryj
DavidWright2010 wrote:
SigmaChrome wrote:
From December 2015.
Yep, they certainly are, but it's been quite a while since there's been any volcanic activity in Australia. Although there are plenty of extinct ruins and they are some of the best locations to shoot. The Warrumbungles are another example of a massive volcanic crater. I visited them on the way home and did so again in 2021.
Warrumbungle NP
Nope. I was there with my mother and didn't want keep her waiting, otherwise I would have hung around...
It sure does.
Vitée
Thank you, Larry!
Vitée
D Cox Forum Pro • Posts: 32,979
SigmaChrome wrote:
From December 2015.
I think you rescued it -- the colours look fine to me.
Auto WB is a menace. Best to leave the camera set to Daylight.
Don
Sigma fp
D Cox wrote:
SigmaChrome wrote:
From December 2015.
Thanks Don.
That's what I've been doing since my SD14 days. This was an oversight on my part.
Vitée
Iain G Foulds
Iain G Foulds Veteran Member • Posts: 5,647
… It is a magnificent image. Perfect weather with the clouds and mist. A “sunny day, blue skies” image would not be nearly as interesting.
… Thinking that this would be a good crop, with light vignette, and without the bright green patch on the bottom left.
... “Be serious. Bring the tripod”
 Iain G Foulds's gear list:Iain G Foulds's gear list
Sigma DP1s Sigma DP2s Panasonic Lumix DMC-LX5
Thank you, Iain.
True.
No. I consider the foreground too important to this image -- for a many reasons.
Vitée
