Re: Affordable video light panel?
Magnar W wrote:
BobKo wrote:
Does it have to be a panel light? I have a variety of lights (including a small panel light that is about 8x10 inches), but the lights I use the most are softboxes. And the softboxes I use the most are really inexpensive. I got them about 3 years ago and am very gentle with them, but I have taken them to shoots and they are holding up fine. And they are so cheap -- a pair of softboxes with two crappy stands costs US$81. (Note that there is currently a $5 coupon, so the price is actually $76.) Here's what I have and I really do use them all the time: https://www.amazon.com/gp/product/B082XPZPS9
This particular light is adjustable to 3 color temperatures: 3200K, 4000K and 5000K. The 5000K mixes fine with daylight through a window. The lights run continuously without making much heat -- I did a timelapse video of a flower blossoming and used one of these lights. It was on for a couple weeks continuously.
Here is a short video I shot of me in my closet, using two of these lights: https://youtu.be/V0lMuwuyDSU There was also some daylight coming from a skylight over my head.
The stands that come with these lights are really cheap and flimsy, but they work. That said, I recommend getting a couple of decent light stands at $35-40 each.
A big enough panel light that will have soft shadows will be a fairly heavy and expensive device. I think that softboxes are a better solution for you.
Thanks a lot for responding to both of you, and for the video links. I find your comments helpful.
I should have mentioned that I am used with studio flashes and all sorts of light modifiers for indoor and outdoor stills photography, but now is looking for a pretty small light panel that can easily be carried around.
Now, as a response to my post here, a photographer closeby kindly offered me to borrow a 20x30 cm Godox panel for a few days. Brightness is up to 2200 lumen, which seems to be plenty for my use. I have to play around with this panel to find if the light qualities will fill my needs, or if the transition to shadows is too hard. 😊
Hi Magnar, I don't know if this is too small...
It recharges very quick, one can adjust white balance in seconds, lower out put etc.
My work includes a lot of table to still life and videos etc. and I love this one. It has a barn door and grid kit and comes with a diffusion panel that works very well.
There is also a stand that folds up to the size of a baton umbrella cylinder about 14 ",
at first I thought it a bit small on the footprint but then saw how they have designed it be placed on the floor, a table, a shelf etc.
I keep one on the stand and one hand held for free angle range.
Dimension are 15 cm x 8.5 cm x 1.25 ish cm depends if you have the barn doors on.
The barn doors work great and I can throw down different light schemes by moving the shutters with a finger push, so somewhat like shaving sheep, I can get the the 360 angles and ponder which suits the task best.
I have used them daily for > 3- 4 hours a day for 6 weeks and have no issues to report
This is at 3000K, I punched down the reds a bit
https://www.bhphotovideo.com/c/product/1678917-REG/lume_cube_panel_pro_kit_with.html/reviews
I have no financial relation with Lume Cube , be it direct, indirect or by access to free merchandise for product - brand promotion . Zippo.
Several reviews say the product gets " incredibly hot" but lack any specificity or follow up details with the company that one would expect. Those who did have an issue and include the follow up details say Lume Cube sent them a new one that day.
I can only say I have used them at max power at 5700K and ran them down 25 x plus and have not experienced any such heating.
I was able to figure out how t use it w/o instructions in seconds - it works like a DSLR - press the green button and it scrolls through Power, level, white balance , color etc.
I love being able to create any color light for a background or scene
Here is one on the stand - the one on the turntable is off - the DVD case gives abit of scale.
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
