XT 20 Travel set up.
LAH50 Forum Member • Posts: 73
I'm traveling to Portugal the first part of April with my grandson and am trying to put together my travel camera set up. I have a X100f but I've just never warmed up to that camera. So I purchased a like new XT20. So far I like its similarity to my XT3 and love its size. I tried it with each of my Fuji lenses, and it works great with all. So now I'm trying to narrow things down a bit lens wise and thought I'd get some input from the knowledgeable travelers here. I have available the 18-55 2.8-4, 16-55 2.8, a Zeiss 50 2.8 macro, 90mm f2 and Sigma 30mm 1.4.
If I take one of the zooms do I need a longer lens? Or do I need a fast lens for low light? Or just go with one zoom and call it good?
Thoughts?
 LAH50's gear list:LAH50's gear list
Fujifilm X30 Fujifilm X100F Nikon D750 Nikon D7200 Nikon D500 +11 more
Fujifilm 16-55mm F2.8R LM WR Fujifilm X100F Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm X-T20
Jeff Biscuits Senior Member • Posts: 1,166
Re: XT 20 Travel set up.
5
If I had those lens options I’d take the 18-55 and the 30. But I’m not you 🙂
 Jeff Biscuits's gear list:Jeff Biscuits's gear list
Ricoh GR Digital II Ricoh GR Digital IV Fujifilm X20 Fujifilm XF10 Ricoh GR IIIx +14 more
Erik Baumgartner Senior Member • Posts: 6,893
Thoughts?
I very much like shooting with the 16-55 on my X-T20 (with the Meike handgrip). If I wanted to keep things simple and compact (easily fits in the petite Peak Design 3L sling bag), that’s what I’d go with. The 16-55 is greater for almost anything, day or night.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Kyle Logan Senior Member • Posts: 1,276
Ditto
 Kyle Logan's gear list:Kyle Logan's gear list
Fujifilm X-T10 Fujifilm X-T30 II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +3 more
Artur Darulewski Senior Member • Posts: 1,209
On my last (business) trip to Spain I took X-T20 (due to small size) plus 10-24, 18-55, 55-200 and 35/1.4. To my surprise 18-55 was used hardly ever while 10-24 was my most used lens. But If I were you,I'd pick 16-55 and 90/2.
Artur
 Artur Darulewski's gear list:Artur Darulewski's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +16 more
Felice62 Veteran Member • Posts: 5,072
If lugging the 16-55 all day around does not bother you, I would definitely count on it. I would look into a 23mil 1.4 lens for night walks.
Have a great trip
If only closed minds came with closed mouths..
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
a_c_skinner Forum Pro • Posts: 13,047
"do I need..."
Only you can decide. I'd take the 16-55 and If you are into wild flowers the Zeiss.  Nothing else.  You could take the 90mm too if you use it a lot at home.  Is this a trip with photos or a trip to take photos?
I'd not worry about carrying more stuff for an extra stop of light, modern higher ISOs are so good and that sensor is just as good at high isos as the current ones.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
max2331 Regular Member • Posts: 101
Thats what I had on my trips to Madrid and London (Fujifilm 35mm f1.4 instead of Sigma).
Was a great combo.
The 16-55 f2.8 for me would be to heavy. Than you can also use the X-T3 instead
 max2331's gear list:max2331's gear list
Fujifilm X-S10 Fujifilm XF 23mm F2 R WR Fujifilm XF 16-80mm F4
Draganski New Member • Posts: 10
Sigma 30mm, fuji 90mm and fuji 16mm (sell a zoom and buy this cheap but very good wide angle). Great travel combo
OP LAH50 Forum Member • Posts: 73
a_c_skinner wrote:
"do I need..."
This is a trip with photos. Hence the reason I want to keep it a little on the light side.
rmcdonough Regular Member • Posts: 143
Thoughts?
I have an X-T2 and the 18-55 2.8-4, 16-55 2.8, 55-200, 35 /f2 and the 10-24 f/4. I went to Lisbon back in November. I didn't take the 16-55 since it's both heavy and no IS. I ended up taking the 18-55, 10-24, and the 55-200. I could have just taken the 18-55 and the 10-24 as I rarely used the 55-200. However, the long zoom was handy a long the river. I midly regret not taking the 35 f/2.
The 18-55 held up better than I thought and I used this and the 10-24 the most. Even at night along the streets of Lisbon.  The 16-55 is amazing, but it's heavy and attracts attention. The 10-24 was handy for a lot of architecture shots, but I only ended up using it about 20% of the time. I would strongly recommend the 18-55, 90mm f/2 and the Sigma 30 f/4. Here's some examples:
Optically, the 16-55 is better than the 18-55, but the addition of IS on the lens came in handy in the dark.
Ryan-
 rmcdonough's gear list:rmcdonough's gear list
Fujifilm X-T2 Leica APO-Summicron-M 50mm f/2 ASPH Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +2 more
