mc-101 wrote:
Hello,
The original Canon EOS M, which was released in 2012, features an APS-C sized CMOS sensor with a resolution of 18 megapixels. Are you still using it?
Occasionally I do. But it's really only pulled out when I need an APS-C sensor but don't want the bulk of a DSLR... and my other EOS M (M6) is mounted to something else like a telescope rig. My main reason to take the M with me is because I might be in a location where the camera could be accidentally damaged.
The shutter mechanism and then operation speed of the original EOS M camera are a little slow compared to more recent models and it lacks the DPAF sensor. But I have had tremendous success with the original EOS M camera. The body is built like a tank. Image quality is exceptional. It's a remarkable camera.
Does the sensor have any advantages over subsequent EOS-M sensors, perhaps in terms of "look"? Is there any reason to hang onto the original M?
It makes for a great backup camera and the pictures it takes are literally identical to those from a DSLR with an APS-C sized sensor.
My original EOS M (Mk1) + EF-M 22mm f/2 STM lens.
My question is motivated by the fact that I have an original M, a 22mm lens and the kit lens. I think it might be time to move on as I've not used it in a while, but I have no idea what latter Ms are like. Thanks
If you have a original EOS M camera and a 22 mm lens, they perform well together and offer excellent image quality. As I said above, the EOS M mechanism is slower. It does benefit slightly from a faster SD card. The EF-M 22mm lens is one of the slowest lenses when powering up, even on more modern EOS M cameras. It takes a couple of seconds for this lens to be ready to shoot when you first turn the camera on. Even on my EOS M6 camera this lens takes a moment to power up yet the EF-M 32mm lens powers on instantly. But this delay is rather minor and will not affect the images produced.
The more recent EOS M model cameras make excellent work with the EF-M 22mm lens and presumably your kit lens. They have a better AF system with the DPAF sensors, allowing faster and more reliable focus-lock on a target. There's less hesitancy and delay. You may find the original EOS M colors and White Balance to be ideal for skin tones and some claim the subsequent M2 produced a little more green in the skin tones. But using the new User Preferences on latter models, you'd be fine. The EOS M series matured around the time the M6/M5/M50 were released. More recent models like the M6 II and M50 II would offer advances in the sensor and OS.
The Touchscreens on the newer models are as responsive as an iPhone now. Video is vastly better. The menu options are greatly expanded and the high ISO settings are much smoother than the original limited ISO options on the original EOS M camera. It's definitely worth upgrading if you enjoy the M series.
