Amaryllis
Started 1 month ago | Photos
grsnovi Veteran Member • Posts: 3,030
Amaryllis
Well, this surely counts as "still" life since the blossoming is like waiting for paint to dry. At this point there are two 15" tall stalks. The one in the front will have four blooms when it finally opens. I suspect the fact that there is a second stalk is contributing to the slow progress - maybe I should have chopped the second stalk off weeks ago?
 grsnovi's gear list:grsnovi's gear list
Panasonic Lumix DMC-GX85 Sony SLT-A65 Sony a7R III Panasonic Lumix DC-GX9 OM-1 +11 more
jim mij Senior Member • Posts: 1,027
Re: Amaryllis
Try some miracle grow (plant food)?, but don’t forget to check twice a day or you might miss them opening 👍
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
macrouser
macrouser Senior Member • Posts: 3,979
Re: Amaryllis
There are some really spectacular colors and size.  Most of them will grow a second stalk of flowers.  I think commercial growers must select for plants with 4 flowers per stalk.
I have grown some from seed and they have from 4 to 6 flowers per stalk.
The other thing I learned from growing seed is that they do not like growing next to each other.  The bulbs you buy are clones of one plant.  It you grow from seed or have more than one color, do not put them near each other.  They will stunt the growth of each other.
I got flowers in just one year growing from seed but only in pots that did not have competition from other seedlings.
 macrouser's gear list:macrouser's gear list
Sony SLT-A77 Sony a7R III Sigma 150mm F2.8 EX DG Macro HSM Sony FE 90mm F2.8 macro Sony FE 70-300mm F4.5-5.6 G OSS +2 more
OP grsnovi Veteran Member • Posts: 3,030
This year v. last year
This year the bulb needed to be planted. Last year the bulb was coated in wax and it seemed to grow like crazy. Last year there was only one stalk out of the bulb. I suspect the four blooms will be fully open by Saturday or Sunday. I suppose I'm concerned that both of this year's stalks are 15" tall. This is a sequence of last year:
Wingspan...
...10" over the tips of the horizontal blooms.
19" from the bulb to the top of the bloom opening on the rear stalk.
This guy is kinda crazy compared to last year.
macrouser
Re: Wingspan...
I have never seen a bulb coated in wax.  It would flower the first year because the flower is already in the bulb.
Joseph S Wisniewski Forum Pro • Posts: 35,461
Very nice
Great composition and colors.
But now I'm hearing Falco singing:
Amaryllis, Amaryllis, Amaryllis
Amaryllis, Amaryllis, oh, oh, oh Amaryllis
Come and rock me, Amaryllis
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
Falco...
Did he ever do anything else? Would that song have broken through without MTV? And how can I possibly twist this to have any relevance to photography?
...maybe he is mentioned in the great PBS limited series ICONS Through the Lens which I've been watching for the last week or so (streaming).
vinturius
vinturius Regular Member • Posts: 127
Re: Amaryllis
These are always spectacular.
Don't chop anything off, such a pity! A somewhat higher temperature will speed them up.
Jaap Meiresonne
 vinturius's gear list:vinturius's gear list
Nikon Z7 Nikon Z9 Nikon AF Micro-Nikkor 200mm f/4D ED-IF Nikon PC-E Nikkor 24mm f/3.5D ED Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR +18 more
Re: Amaryllis
Thanks Jaap! The two larger blooms opened last night. I'll probably set up the macro rail this afternoon and shoot the stamen.
Amaryllis - Stamen/Pollen
Not real happy with this stack of 15. Seems that more of the pollen should be sharp. Also there seemed to be halos around some of the larger stamen heads (cropped out of this view). Stacked in Affinity Photo 2.
The 2 large blooms opened last night.
2 more and done!
The whole thing as of today.
Just the main bloom.
Re: Amaryllis - Stamen/Pollen
I never seem to get pollen looking like i think it should either (despite taking multiple stacks and messing with lighting)
stacking can be hit & miss, I think a camera that does it internally would be useful so i can see results immediately (and then adjust and try again)
Jim
Hi Jim,
My 2 Lumix bodies will stack internally but (so far) my limited testing of their capabilities with the 30/2.8 Macro suggest that manually stacking from the APS-C Sony with the 100/2.8 Macro yields better results.
I was using the focus rail and had focus peaking set to the color red. Maybe I should use another color against a red flower? I thought I walked the focus peaking back in depth in tiny increments - maybe not small enough?
- Gary
Hi Jim,
hi, I don’t think I’m surprised, I found helicon a bit better than canon dpp, so I assume if my canon camera did internal stacks it’d be a tad worse too, however I sure it’d give a guide, and then you could use the actual photos in a software based stack later
it’s a black art for the patient, I’d try smaller and also larger, and then manually clone and stamp all the best bits, something for a rainy day perhaps ?
- Gary
Jim
I hate to say...
Jim,
I usually post-process the raw's and then stack the results. This time I just stacked the jpg's. When I was done I tossed everything except the result.
I probably should have kept the raw's.
- Gary
