Recommended lenses for a Japan trip
Started 2 months ago | Questions
dratwork New Member • Posts: 6
I don’t mind carrying some weight but I have too many options… the trip would be mostly in cities  street and landscape  no video
bodies X-H1 X-T2
lenses:
10-24
16-55
50-140
70-300
23f2
27 mk1
35f2
56 mk1
80 macro
I have a lowepro protective 450 backpack with enough space.
and 16-55 is a must.
thanks.
 dratwork's gear list:dratwork's gear list
Fujifilm X-T2 Fujifilm X-H1 Canon PowerShot D30 Nikon D40X Nikon AF-S DX Nikkor 18-135mm f/3.5-5.6G ED-IF +11 more
Fujifilm X-H1 Fujifilm X-T2
AstroVagabond
AstroVagabond Senior Member • Posts: 1,397
Re: Recommended lenses for a Japan trip
When I went to Japan in 2019 I was shooting with a Canon 6D. I just took my 35mm f/1.2 and 24-105mm f/4.0.
I was on a tour where we hit many Buddhist temples. In the evenings we hit the nightlife in the cities. The fast 35mm worked well in the temples that were often dimly lit and at night.
There was no point where I wished I had brought more reach.
Enjoy your trip!
 AstroVagabond's gear list:AstroVagabond's gear list
Fujifilm X-T1 Fujifilm X-T4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 56mm F1.2 R +3 more
wantfastcars Regular Member • Posts: 206
bodies X-H1 X-T2
lenses:
10-24
16-55
50-140
70-300
23f2
27 mk1
35f2
56 mk1
80 macro
thanks.
I live in Japan and as a hobbyist photographer the first thing I'm gonna say is you will want a wide-angle lens that's reasonably fast, but you largely won't need crazy speed - even for a lot of the big tourist spots a 23 will be too narrow, but 1.4 will be more than you need unless you specifically want to do night photography. The 23/f2, for example, will be too narrow in more situations than you think it will be, but also won't be fast enough when you want true night photography. As you said, you definitely want to bring the 16-55 2.8, perhaps also a reasonably a fast prime or two (expanded on below). I'd also suggest the 70-300 as shooting in Japan often involves shooting across bodies of water or aiming at details from the tops of vantage points such as castles and mountaintops.
What cities/areas in particular do you plan to visit? If you're hitting the big tourist spots of of Tokyo, Kyoto, Osaka/Nara, and Hiroshima, you'll want mostly fast and wide/medium-wide lenses such as the 16-55 and maybe the 35 f/2. If you plan to visit more rural areas where you might want to focus more on details, the 56/1.4 and 70-300 will also serve you well.
 wantfastcars's gear list:wantfastcars's gear list
Fujifilm X-S10 Fujifilm 50-230mm II Fujifilm 15-45mm F3.5-5.6 OIS PZ Fujifilm XF 16-80mm F4 Fujifilm XF 70-300 F4-5.6 R LM OIS WR +8 more
RobRoy22 Regular Member • Posts: 273
bodies X-H1 X-T2
lenses:
10-24
16-55
50-140
70-300
23f2
27 mk1
35f2
56 mk1
80 macro
thanks.
At the risk of plain speaking, you have a big collection of gear but evidently little idea which lenses will best serve you for your trip, and your own style of image making. Even a moderate amount of experience in use would typically lead to some preferences. It’s beyond my abilities to guess which of these is best for you to take with you. Maybe you are just seeking a chat with like minded collectors?
 RobRoy22's gear list:RobRoy22's gear list
Fujifilm X100V Fujifilm X-T5
JeffryZ Senior Member • Posts: 2,579
I went in 2019 using a Nikon D500. For lenses, 90% of the time I used a Sigma 18- 35mm f/1.8 and just a few times my Nikon 70- 200mm f/2.8. If I was to go back, I would be using my Fuji 16-55mm f/2.8 and the 50- 140 mm f/2.8. I like the flexibility of using faster zooms. It simplifies things too. I would probably also bring my Fuji 16mm f/1.4 for situations I wanted faster wide images. Gallery of images: https://pbase.com/jeffryz/japan&page=all
You miss 100% of the shots you don't take. Wayne Gretzky.
http://www.pbase.com/jeffryz/galleries
 JeffryZ's gear list:JeffryZ's gear list
Nikon D500 Fujifilm X-T4 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Tokina AT-X Pro 11-16mm f/2.8 DX +5 more
PeterLeyssens Senior Member • Posts: 1,691
I traveled Japan quite a bit in the days when I had a film SLR with primes only. I took 28-50-90 macro and bought a 200mm while there. I agree that your 23/f2 would be too wide. So I'd advise you to take 16-55 and 50-140 as well as the 23/f2 for the evenings. I don't think you need much wider or longer, except if landscape or birding are an important part of your trip.
 PeterLeyssens's gear list:PeterLeyssens's gear list
Fujifilm X-Pro2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Samyang 12mm F2.0 NCS CS Fujifilm XF 35mm F2 R WR
xtm Senior Member • Posts: 1,405
Looking at your gear, 16-55 and 23 f/2 is all I would need for that trip.
But with what *I* have, I would take my 16-55 and 18 1.4. 16-55 for general wandering around shots and 18 1.4 for night life and occasional artsy subject isolation stuff.
Whatever you do, don't bring a lot of stuff. I often found that too much gear actually hinders my travel enjoyment and just clutters the mind. Pick 2 and go.
 xtm's gear list:xtm's gear list
Nikon Df Leica M10 Fujifilm X-Pro3
raymondp1138
raymondp1138 Regular Member • Posts: 279
When I visited Japan, I had two systems - the Canon full-frame 5D Mark III with a 17-40mm f4 and a 24-105mm f4, and the X-T1 with an 18mm f2 and a 35mm f2.
The 17-40mm served the landscape job obviously, and I used it at the wide end a lot. Since you mentioned landscape, I'd bring the 10-24mm.
The 24-105mm was for general purpose, and that focal range did well for many situation, such as walking around cities, parks, and around temples. So, the 16-55mm would definitely be useful.
For night time walk-around and indoors, I used the Fuji 18 and 35mm.
I also used a small tripod for landscapes and night time cityscapes.
One lens I wished I had was the 70-200mm f/2.8 for snow monkey portraitures. I think the wider aperture with the long-ish focal range would help blur out the background nicely.
If I went again and had to use just a Fuji setup, I'd bring a 10-24mm, a 16-55mm, a 23mm f2 (in place of the 18 and 35mm), a tripod, and maybe a 90mm f2, depending on if I had something specific for it in mind.
Flicker images:
https://flic.kr/s/aHskPRHUya
https://flic.kr/s/aHsmzL8ytu
KariP
KariP Veteran Member • Posts: 6,458
Days or months in Japan ?
bodies X-H1 X-T2
lenses:
10-24
16-55
50-140
70-300
23f2
27 mk1
35f2
56 mk1
80 macro
thanks.
I do not know what is the idea / purpose of your trip … I am planning or more like dreaming a trip to Japan. My previous experiences of travelling have show’n me that i usually carry TOO much gear in the beginning….
If i some day buy the tickets it will be two lenses -  for example  from your list 10-24 + 16-55. One body and two possible ways to carry gear. Shoulder bag for  cities and possibly some insert for a comfortable backpack.
If i take Canon gear it will be FF body with 14-35  and 24-105f4.
Kari
I started SLR film photography in 1968. Now two systems: Fujifilm X-H1 + X-E3 and Canon FF gear 5dMkIV + R6
 KariP's gear list:KariP's gear list
Canon EOS 5D Mark IV Fujifilm X-E3 Fujifilm X-H1 Canon EOS R6 Canon EF 50mm F1.4 USM +13 more
Gandolphi Senior Member • Posts: 2,840
I have just returned and carried a 24 mm and 28mm (FF equiv) and these took care of all my needs. Your 16-55 could be a one lens option, f 2.8 is okay for most needs.
I have decided on a 16 and 23mm to go to Japan next time fitted to my new XT5. Weight might not worry you but bulk will when you travel on any trains or buses during rush hours.
You will enjoy yourself
bodies X-H1 X-T2
lenses:
10-24
16-55
50-140
70-300
23f2
27 mk1
35f2
56 mk1
80 macro
thanks.
 Gandolphi's gear list:Gandolphi's gear list
Leica SL (Typ 601) Hasselblad X1D II 50C Leica SL2-S Leica Super-Vario-Elmar-SL 16-35mm F3.5-4.5 ASPH Leica APO-Summicron-SL 35mm F2 ASPH +2 more
FYI, when I suggested you take the 16-55 and 50-140 lenses, that's because you already have them and I assumed you would want to take them.
Personally, I'd never take these lenses when traveling. I have used the 16-55 for an event, but I rented it for that purpose. It's a great lens. I love the image quality and the flexibility in that case. It's practical when I'm the photographer, like for that event. But when I'm traveling, I'm usually not there only for photography. My X-Pro2 with a 16-55 is just cumbersome in that case. It weighs in at 1150 grams and is more than 15cm deep.
I'm actually preparing for a trip over the Easter holidays right now as well. I've decided I'm going to sell my X-Pro2 and my 55-200. Instead, I'll get an X-E4 and an 18/f2. I'm also adding two TTArtisan lenses: 25/f2 and 35/f0.95, which I will be comparing with the XF35/f2 I already have. It's a bit extreme, but going MF helps me getting smaller lenses. The total of the X-E4 + these four primes weighs less than X-Pro2 with the 16-55. Mount any of these lenses onto the X-E4 and it weighs less than half. I can use it like a compact with a wrist wrap, instead of my shoulder belt, and it slips into my small camera bag without any effort.
I'm going to the Bodensee on the border of Germany and Switzerland. The circumstances there are much less demanding than the extreme crowdedness of Japanese cities. So for Japan, personally, I'd definitely go smaller than the 16-55 and 50-140. But that's my personal taste. You'll find many Japanese themselves carry much bigger camera-lens combos than this. Then again, there's no country in the world that has more people obsessed with small cameras, being anywhere from cheap gadgets to uber expensive Leica setups. Whatever you end up taking, don't forget to enjoy the trip. Japan is an experience.
Felice62 Veteran Member • Posts: 5,072
Don't overthink. I am heading to Japan this spring, over the golden week, I am seriously thinking to take xe-2 with the 27/2.8 in attidion to 16-80/4 and 23/1.4 with the x-s10.
That's all.
Will I miss opportunities? Yes, maybe. But I am traveling 15000 km to see Japan and photography is only part of it.
If only closed minds came with closed mouths..
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
sluggy_warrior Veteran Member • Posts: 3,204
bodies X-H1 X-T2
lenses:
10-24
16-55
50-140
70-300
23f2
27 mk1
35f2
56 mk1
80 macro
thanks.
Why do I feel like you're carrying coals to Newcastle? You can just bring the 16-55 and collect more lenses while you're there. "Made in Japan" sounds delicious
