EOS M 22mm f2 IQ?
Started 1 month ago | Questions
Dr Hal Senior Member • Posts: 2,184
Re: EOS M 22mm f2 IQ?
It is a wonderful walk around camera and lens.  The M6II is a completely enjoyable camera.  Good user interface, good color, good everything.
 Dr Hal's gear list:Dr Hal's gear list
Canon EOS M6 II Panasonic Lumix DC-S5 Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM +3 more
wlderdude Junior Member • Posts: 28
I've had a lot of un with the 22mm pancake over the past 10 or so years.  The quality of the shots it can make is up to my standards.  Take a look at some of the image threads dedicated to that lens.
Here's one I got in Indonesia back in 2016.
When I got an M5 several years ago off a guy on Craigslist, it came with an 11-22mm.  He said that it was an amazing lens, and that I wouldn't need the little 22 anymore.
If you compare the MTF charts, the zoom should be a little sharper.  I dunno.  I do take more pictures with the zoom, and the 11-22 is a pretty serviceable walk around lens.  I just find the 22mm pancake to be more fun.
The 22mm pancake paired with the 55-200mm is a very powerful pair.  When traveling light, it is my favorite setup.
That said, since getting the 32mm prime, the 22mm hardly gets any use.
Fjzk Regular Member • Posts: 220
If you don’t mind using the detachable viewfinder this lens makes the M6II a better walkaround camera then the 100x from Fuji, and you still get to change lenses if you wish.
 Fjzk's gear list:Fjzk's gear list
Canon EOS M50 Canon EOS RP Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +8 more
R2D2 Forum Pro • Posts: 26,528
+100 you guys.  Fun is what this system is all about!
R2
AbuMahendra Regular Member • Posts: 106
From what I recall, the 11-22 was quite sharp st 22mm, but that was at f/5.6.
Yaixi
Yaixi Junior Member • Posts: 49
Speak with photos。
yaixi_,回复并经常发图。
佳能m62+canon1122+conon22+iPhone11
 Yaixi's gear list:Yaixi's gear list
Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 32mm F1.4
Check out this old thread to see the IQ of the 22/2, 15-45 and 11-22 and their field application to Travel.
Abu's "M3 goes to Mexico & Guatemala" thread: Canon EOS M Talk Forum: Digital Photography Review (dpreview.com)
Larry Rexley Senior Member • Posts: 1,238
Yaixi wrote:
Speak with photos。
Nice images!
The backlighting here does show what I found --- this lens doesn't do as well as when there's strong backlight or a light source in the frame. It tends to have some flare and washes out the contrast a bit.
The Rokinon 12mm f2 is a bit better, but the Siggy 16 f1.4 and Canon EF-M 32mm f1.4 are really outstanding at controlling flare and handling backlight (at least with the lens hood on which is how I use them).
 Larry Rexley's gear list:Larry Rexley's gear list
Canon EOS M6 II Canon EOS M200 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +21 more
Max5150 Senior Member • Posts: 1,045
Small walk-around travel kit: EOS M 22/2, M18-150, a Godox flash and a flash trigger.
I'll traveling to UK/Venice/Dolomites this summer and I'm probably taking M6mkii, M11-22, 22/2 (32/1.4 a little tight for me), M18-150, Godox AD200, a trigger, and a stand. The flash stuff isn't part of my "walk-around kit". Not sure if I'll take a point and shoot or just rely on my phone for days when I don't want to let anything around. You can find used EOSM lenses pretty cheap.
