... Comparison #1- DP2S vs DP2X vs DP2M
Started 1 month ago | Discussions
Iain G Foulds
OP Iain G Foulds Veteran Member • Posts: 5,647
Re: ... Comparison #1- DP2S vs DP2X vs DP2M
… Very good request. Lessens the occasion of operator error. Though, would have to be at 100 ISO because the Merrill does not do 50 ISO. Look forward to the results myself!
... “Be serious. Bring the tripod”
 Iain G Foulds's gear list:Iain G Foulds's gear list
Sigma DP1s Sigma DP2s Panasonic Lumix DMC-LX5
Brev00
Brev00 Forum Pro • Posts: 11,854
Reprocessed from Tiffs
interesting to see the differences between your jpegs and the tiffs. Then I processed the tiffs with various adjustments first to set white balance to the snow and second to get the tones out closer to 0 and 255 in each. I did not touch saturation. Curiously enough, The 2x had much less of a magenta tint in the tiff. A -9 correction instead of a -30. The two Merrills were very similar. The tiff needed a bit of warmth while the jpeg was spot on. The DP2s tiff was considerably greener needing a +16 tint correcftion. Same wb. I would say you did a good job evening out the DP2s (reducing the green cast) while going the wrong way with the D2x (adding even more magenta) and missing the magenta cast on the Merrill. Perhaps you are more sensitive to green than you are magenta. Or your software let you down.
I cropped the 2s and 2x to the proportions of the Merrill. A lot is lost in the supposedly 4mm difference (in 35mm terms). So, after going through various steps, I found the 2x to be the flattest (though I added a heap of clarity and contrast and brightened it considerably). It did have the disadvantage of being the most underexposed. It was my least favorite:
The D2S has the most contrast of the three. A nice bump in the mid highs and mid lows. A good deal more colorful though it benefited from having a nice section of open sky.
The Merrill now falls to second behind the DP2s. The Merrill has some contrast but smaller bumps more at the dark and light extremes. The Merrill's sensor did receive one stop less light.
You pretty much nailed the exposure of the DP2s. A variable favoring it. I think in terms of another shoot, it would be good to have an unchanging scene. A clear blue sky, for example. I think that would better equalize the colors presented to the sensors. Part of what we may be seeing is a function of how much the sky is cloud covered. The 2X sky is entirely white, the Merrill's has a tinge of color, and the 2s has some actual clear sky. Another variable favoring the 2s. It does benefit from reducing the green cast. Then, also good to shoot one of your dark, indoor scenes. and give a good indication of the quality of the shadows. Shoot all at the same iso. So, for now, I have changed my vote.
 Brev00's gear list:Brev00's gear list
Nikon D90 Nikon D610 Nikon D500 Nikon AF Nikkor 50mm f/1.8D Tamron AF 28-300mm F/3.5-6.3 XR Di LD Aspherical (IF) Macro +11 more
Iain G Foulds
Re: Reprocessed from Tiffs
... Brev: A tremendous contribution from a superiour processor. The subjective balance and beauty of the DP2S is even clearer on a fairer playing field. The other two are still fine Foveon images, but literally pale in comparison.
... I believe that the clouds were consistently patchy that day, the light therefore likely changing steadily. However, they were taken as quickly as I could mount the cameras on the tripod, and I believe that there was roughly the same amount of open sky in each. Believe that the DP2S simply handled the subtle colour hues the best. Whereas the other two simplified the sky into "light grey".
... I suppose a clear blue sky would be the fairest. But, clear blue skies are boring. It is the subtle hues I am interested in.
... Again, tremendous processing. If not (yet) an official member of the Sigma clan, you are definitely an enthusiastic, professional contributer!
Hulyss Bowman
Hulyss Bowman Junior Member • Posts: 46
What leaded more photographers into SIGMA gear was, apart the lenses, the first dp series. In fact, ppl shooting with SD9/10 weren't legion but more an American core especially on Dpreview.
The SD14 was a hit, America centered too, then the first two Dp, the Dp1 and Dp2 with sensors from the SD14 but with a special addition: the True 1 color processor.
The True 1 color processor combined with the foveon F13 sensor was very good. The Dp1 and the Dp2 were the firsts of their generation with colors more accurate than the Sigma dslr ! They were also the smallest's APCS compact cameras ever made.
The problem on those firsts units was often the lenses and/or the micro lenses because it was the first time sigma mated a lens so close to the sensor. So It was possible some units were showing some greeny vigneting if the lenses were not aligned perfectly. The speed of operation was kind of slow and the AF too. But the democratization of sigma camera started right here, internationally. The OG Dp2 was sometimes dubbed as "the poor man leica".
Then came the DP1s and DP2s. Same camera, same sensor but new processor : the True 2. More speedy, superb colors, ISO50 again (very useful), not that expensive all metal and more reliable. Sigma fame started to climb on those ones just because of the price, the size, the exotic rendering and the IQ. For me, the pinacle of the Sigma imagery realm.
After that our (not so) friend AFE came in the way and the end. No more iso 50, wb off, pictures had less .. soul (more cold or whatever). I remember how much I payed for my brand new SD15, 50 and 85 f1.4 ... and I remember sending it back to, again, buy a DP2s. DSLR world come with some other compromise like hazardous AF, lenses alignement and overall price...
After that ? Guess what ... Sigma, this respectable Japanese compagnie, upped the world wide electricity bill by four thousand percent !
So ok. It was cool to have a landsat satellite in your pocket. What a blast !! A true spy camera, mind-blowing details especially for the price of the DP merrils. But, the time we consumed on computer waiting SPP to process those huge RAW into even more huge Tiff who also needed time into PS or whatever to get it right... The number of HDD we bought to store this massive amount of informations. And the pictures ? you would say... Personally the pictures was not as poetic or organic as the venerable DP2s. At all.
It was the Pixelozoïc era. The humans back in those days were very excited on their computer screen scrutinizing every pixels and sub pixels. Completely and blindly hypnotized, deeply matrixed into the digital world. It is mostly because it started to tinkle medium format photographers and sigma got a lot of attention because of it.
At a technological level it was awesome but at an artistic and poetic level, not so much. Of course all of this is my opinion, some might differ on it.
Cheers.
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
Hulyss Bowman wrote:
... snip...
It was the Pixelozoïc age. The humans back in those days were very excited on their computer screen scrutinizing every pixels and sub pixels. ...xnip...
Excellent !!!
what you got is not what you saw ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Iain G Foulds
… Brilliant.
Stillton Regular Member • Posts: 170
Iain G Foulds wrote:
… Brilliant.
I have dp1m and dp2m but in the initial rendition of those 3 images I would say dp2s was the most "right"-feeling image to me, contrast and color wise.
 Stillton's gear list:Stillton's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill
Hulyss Bowman
Yes !!
Every body who has a long enough experience in photography, let say from the end of film and start of digital, will identify the dp2s as the most close to the scene, just by experience and knowledge of colors, like the sky and all. On top of that the sensor add some « magic » to the scene, what I call « organicness ». We can surely link this effect to a certain type of film, between ectar 100 and ektachrome 64…
Jhnns Forum Member • Posts: 54
Thank you for this very informative comparison! It would be interesting to have such a comparison between the three classic models DP2, DP2s and DP2x. Maybe someone has all three models and could make such a comparison? Best regards!
 Jhnns's gear list:Jhnns's gear list
Sigma DP2 Canon PowerShot G1 X
xpatUSA
Yes, and all at 100 ISO, same aperture/shutter/EC with default internal JPEG settings and no messing around with the images afterwards - in other words, a CAMERA comparison ...
Hulyss Bowman
To be Franck, the major difference between the DP2 and the DP2s is : the processing speed (new processor aka TRUE 2) and less « green » vignerons or hue because of better micro lenses/TRUE2/Spp sauce.
Where you’ll see a difference is between those two and the DP2x. Analog front end, iso range changed and somehow more « neutral/Zeiss » colors.
some might like one or the others it depend.
cheers.
Iain G Foulds
… A difference a month can make…
… Hard to believe that the images were taken only a month ago. Since then have decided that the DP2S (with a serious tripod) is my choice, sold my DP2X, and the DP2M is for sale.
... “Beginner photographers handhold, more experienced use tripods, but serious photographers use serious tripods.”
allineedislight Senior Member • Posts: 1,309
DP2 vs DP2s vs DP2x
7
https://www.flickr.com/photos/-fs-/galleries/72157664297050855/
Have a look at this gallery! It contains images taken with all three DP2 classic models. As is evident all three models are capable of delivering outstanding images in the right hands.
I believe the secret is actually the lens - and this is shared by all three models. It just has the right amount of sharpness but it also has very nice bokeh. In contrast, in the later DP2M the bokeh often is very busy and harsh.
In any case with regard to differences here is my take (I used to own all three models, but I kept the "s"):
DP2s and DP2x both have coloured buttons whereas in the DP2 they are all black. They both have an option to conserve batteries by switching off power to the sensor automatically ( not available in the DP2) and DPx and DP2s both also have a better LCD compared to the original DP2.
DP2x has in addition a jpg+raw option and AFE which is both good and bad ( it is easy to burn highlights but it has cleaner shadows at iso 400 but shows banding in b&w at iso 1600). As a result of AFE you need to use SPP 4.2.2 with the DP2x but with DP2 and DP2s you can use the earlier SPP 3.5.2 which has a better b&w mode (with no or little noise reduction in high iso).
Auto WB in DPx has a tendency towards pink, in the DP2s there is a general tendency towards cyan whereas the DP2 images often have a blueish cast with green corners. This is likely due to different hardware (IR cut off filters).
For best results you will need to adjust colours in SPP or elsewhere slightly for all models (and preferably a calibrated monitor to do this!)
Metering is slightly different for all three models, with DP2 asking for a bit more light than DP2s which in turn is less conservative than DP2x. I think this is to prevent burning highlights in the DP2x whereas for DP2 and DP2s this implies ISO 100 is defined slightly differently ( in the DP2 it seems to act more like ISO 70).
Hope this helps!
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
Re: DP2 vs DP2s vs DP2x
Yes, thank you very much for this interesting information! Best regards!
Iain G Foulds
… Appreciate your good information and experience. All three models are excellent. I only know that I had to work much more in post, and less successfully, with the original model and the X. Whereas, I was mostly delighted with the S Raw image immediately. Which was very possibly simply an indication of my poor processing skills.
xpatUSA
A long time ago I asked Sigma which of the several calculation methods allowed by I.S.O. is used to define their Exposure Index (known here as "the ISO") - I think I asked about the SD1 Merrill.
I was told that the Recommended Exposure Method (REI) is used.
In simple English, this allows manufacturers to estimate the REI - a.k.a.
"ISO" value - based on a series of test images. No actual calculation published, unlike the other I.S.O. methods.
A bit like here where many prefer to assess Quality based on looks rather than actual accountable values ... LOL
Long gone are the days of "ISO Speed" determined by the I.S.O. Saturation-based method, where the Photographer actually got half a stop of highlight headroom thrown in - useful for DP2x, SD15 and Quattros, I would think. That headroom disappeared with I.S.O.'s introduction of the Japanese Standard Output Sensitivity method, thereby allowing manufacturers to increase the "ISO" by over 40% for the same sensor!
http://dougkerr.net/Pumpkin/articles/SOS_REI.pdf
That's very interesting!
I tried spot metering a grey card with both the DP2 and DP2s and these two cameras were consistently always 1/3 stop apart (with the DP2 requiring more exposure). So the DP2 and DP2s are definitely differently calibrated.
For the DP2x it is slightly different. if I recall correctly spot metering gave the same result as the DP2s but matrix metering was tuned towards protecting highlights, so in contrasty scenes the DP2x is reducing exposure compared to the DP2s (and also the DP2).
