... Comparison #1- DP2S vs DP2X vs DP2M
Started 1 month ago | Discussions
Iain G Foulds
Iain G Foulds Veteran Member • Posts: 5,647
... DP2S arrived today. Interested to see the difference in images between these three cameras. Tried to take them as close together as possible. Spent quite a while trying to balance WB, saturation, exposure.
... Appreciate any thoughts or comments.
... #1 DP2S  #2 DP2X  #3 DP2M
... “Be serious. Bring the tripod”
 Iain G Foulds's gear list:Iain G Foulds's gear list
Sigma DP1s Sigma DP2s Panasonic Lumix DMC-LX5
Sigma DP2 Merrill Sigma DP2s Sigma DP2x
Brev00
Brev00 Forum Pro • Posts: 11,854
Re: ... Comparison #1- DP2S vs DP2X vs DP2M
My first reaction was that the DP2S seemed to have bit of a turquoise/cyan tint, the DP2X skewed magenta, and the Merrill seemed more natural. The Merrill clearly outresolves the other two by a country and city mile combined.  Right off the bat the winner without question was the Merrill.
I brought them into my ACR for further study.  Checking white balance with the dropper on the snow, both the dP2S and Merrill were close to neutral.  The DP2x took a -30 tint correction confirming my impression that it had a magenta cast.  Correcting it made the building look odd though.  You said you worked on correcting the white balance so I don't know if this is something you did to the DP2X or if it is just more off key to begin with.  Might have been good to shoot each in auto or daylight and let the result be.  Don't we want to see the camera's output?  Maybe just convert using the same default settings.  You did get the exposures very close.
Regardless of any further experimentation, I take the Merrill.  It is straightforward and clear with excellent detail and a natural feel (for me).
 Brev00's gear list:Brev00's gear list
Nikon D90 Nikon D610 Nikon D500 Nikon AF Nikkor 50mm f/1.8D Tamron AF 28-300mm F/3.5-6.3 XR Di LD Aspherical (IF) Macro +11 more
Iain G Foulds
OP Iain G Foulds Veteran Member • Posts: 5,647
... Brev: Good observations, and appreciate your choice.
... To be fair, and at the risk of revealing my own poor processing skills, here are the converted originals.
DP2S
DP2X
DP2M
... Slight tint aside, I immediately prefered the "S" image. It seemed a much wider, more pleasing, and more subtle colour palette. It was by far the easiest to work with, and I did almost nothing to it. (To be fair, it takes a long time to learn to get the best from a new sensor).
... Spent far too long on the X and M. Just don't like their colouring. Back and forth with the WB and HSL- really trying to bring them up to the S. (Reconsidering, they were probably best left alone).
... Time to learn the S. If it comes down to a decision between resolution and colour, colour will win almost every time.
paulsch
paulsch Regular Member • Posts: 276
Spontaneously I prefer picture #1 (DP2s). It may be a bit green but I like the overall impression best.
But the light and the clouds are different from picture to picture so the comparison is not easy to make.
The Merrill has the advantage of higher resolution but seems a bit too contrasty for my taste. But maybe with different raw processing this could change.
Generally I find it interesting to see the moiré on the fence. I would be curious to see how a high resolution bayer camera would cope with that motive.
Thanks, Iain, for this interesting comparison.
 paulsch's gear list:paulsch's gear list
Sigma DP2s Ricoh GR II Sigma SD14
Hulyss Bowman
Hulyss Bowman Junior Member • Posts: 46
Hello there !
Of all 3 photos, color wise, only the DP2s render the scene as natural as possible. Just look at the sky. The slight hue of the DP2s is the most easy to fix... if needed.
The other two are simply off in the red channel by a large margin and resolution doesn't matter since it is foveon. For reminder a DP2s picture can be printed as large as A0 without real problem at normal viewing distance.
As an another reminder, the race for pixel in foveon is kind of useless since it just print better and the approche is different . Back in the day I exposed photos from DP2s and D3x and the most pleasing to see was the DP2s, for visitors (A3 and A0). The human eye do not jump in evolution every 10 years. Someone sensitive to acutance, contrast and color will be as sensitive in the coming millenium, at least. And this is the strong point of the foveon.
A simple 15 or 20 MP FF foveon ala DP2s sauce would absolutely please every photographers in 2023 or even 2028. It will not really please absolute units of pixels peepers but for them, in bayer land, there is 64 or 100 MP affordable cameras who are easier to use also (if they can also finance the computer and storage behind that too).
Cheers.
Iain G Foulds
… Grateful to have the confirmation of you both in preferring the DP2S. My processing time was spent trying to bring the other two up to the quality of image in the earlier model.
… Hulyss: And appreciate your explanation of the sufficiency of the resolution of the earlier Foveons- particularly with today’s excellent upscaling software. (One thing I did learn from the experiment is that the DP2S can easily take a bit of sharpening and contrast to increase the apparent resolution.)
Hulyss Bowman
Yes exactly. One thing also to take in consideration is that all printed photos are processed by a printer and many photographers absolutely do not print at all.
Whatever the resolution of your camera (in a certain limit) you will always be limited anyway by the size of the ink dot of your printer which is not equivalent at all of the sensor pixel size.
The foveon render each pixels (with no real bleeding) in a way which is more pleasing for a printer. The command to the printer is more clear for each dot and avoid informations who lead to smudges or heavy mixing of color  in bayer.
To be honest, for printing, my printer do a superior internal magic for upsizing. Just churn the raw to tif in the spool, select A3 and A0 and let the thing do his thing.
I wasted soooo much time with various softwares to sharpen/upscale ... that when I tried to simply let the printer do the job I bumped my head on a wall, by shame.
allineedislight Senior Member • Posts: 1,309
Another vote for the DP2s.
You really don't need to do much with this camera to get great output.
I normally leave the camera in sun/daylight WB and typically add +2M in the colour wheel to reduce the slight cyan cast.
Skin tones come out fantastic (similarly like in the older Fuji cameras), and the colours are most pleasing (but not realistic - for that you do need the DP2 Merrill).
I never liked the output of the DP2x which I owned only very briefly. This camera is quite famous for its magenta cast in auto WB and also for the AFE issues..
DP2 Merrill has very realistic colours but its overall rendering is not nearly as pleasing as the DP2s IMHO.
The DP2 classic has cooler colours than the DP2s, so with the DP2s you do have the best of the bunch.
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
Iain G Foulds
… An excellent and important comment.
Iain G Foulds
… Great comments… and appreciate the WB tip.
… Though, you will never get it past the technicians that the DP2S is simply “more pleasing”. Which is fine.
… I suspected, from the comments of others at this forum, that the DP2S would be my “most pleasing” camera, and early trials have confirmed this. Rushing off to work this morning, but couldn’t resist the rising light on the fresh snow. I know for certain that the DP2X and DP2M would have made a mess of it.
DP2S
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
.... Slight tint aside, I immediately prefered the "S" image. It seemed a much wider, more pleasing, and more subtle colour palette. It was by far the easiest to work with, and I did almost nothing to it. (To be fair, it takes a long time to learn to get the best from a new sensor).
Not sure that I understand, Iain. All of your non-Merrills have the same sensor.
what you got is not what you saw ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Iain G Foulds
… Ted: Right. But tuned slightly differently, affecting WB and processing…?
xpatUSA
Can't say for the DP2s.
The SD9 has "ImagerSettings":
BEGIN: CAMF property meta data (ImagerSettings)
"SFVdd_DAC" = "1.5"
"SFVddExp_DAC" = "0"
"PixVccRst_RED_DAC" = "1.3"
"PixVccRst_GRN_DAC" = "1.3"
"PixVccRst_BLU_DAC" = "1.3"
"PixVccExp_RED_DAC" = "1.3"
"PixVccExp_GRN_DAC" = "1.3"
"PixVccExp_BLU_DAC" = "1.3"
"PixVccLo_RED_DAC" = "0"
"PixVccLo_GRN_DAC" = "0"
"PixVccLo_BLU_DAC" = "0"
"VRstLo_DAC" = "0.3"
"VRstLoExp_DAC" = "1.3"
"VRstHi_DAC" = "1.4"
"BiasSettleTime" = "1000"
"PixVccLoTime" = "20000"
"ShutterDelayTime" = "0"
"ReadoutDelayRegister" = "136"
"ReadoutISM0" = "1"
"ReadoutISM1" = "2423847168"
"ReadoutISM1D" = "2423847424"
"ReadoutISM2" = "0"
"ReadoutISM3" = "0"
"ReadoutVDR0" = "0"
"ReadoutCols" = "2304"
"ReadoutRows" = "1536"
"GarbageRows" = "0"
"ReadoutStartCol" = "0"
"ReadoutStartRow" = "0"
"ReadoutStepCol" = "1"
"ReadoutStepRow" = "1"
"VPSCols" = "1"
"VPSRows" = "1"
"ResetStart" = "1700"
"ResetStep" = "0"
"MovieRowsPerFrame" = "0"
"ReadoutFormat" = "RGB36"
"ReadoutMode" = "SNAPSHOT"
"MinFrameTime" = "0"
END: CAMF property meta data
but no such for  the DPs ...
digi2ap Contributing Member • Posts: 887
Interesting magenta tint to the DP2X which I don’t remember seeing from my camera or my SD15.  I have some snow photos in the archive that I’ll take a look at.
 digi2ap's gear list:digi2ap's gear list
Sigma SD15 Panasonic Lumix DMC-GH3 Sigma 10-20mm F3.5 EX DC HSM Sigma 18-35mm F1.8 DC HSM Art Sigma 50-100mm F1.8 DC HSM Art
I don't recall the SD15 showing the magenta cast in auto wb, but the DP2x has it in spades. You can check the old reviews and this forum.
For example:
https://www.ephotozine.com/article/sigma-dp2x-x3-foveon-camera-review-16766
The crazy thing is that this happens also within SPP when the wb is set to auto.
Furthermore, due to AFE you can easily blow highlights with the DP2x. SPP versions 4 and later cover this up by imputing (i.e. guessing) the missing values, but when you use SPP 3.5.2 you see the full amount of the damage done. You can use SPP 3.5.2 perfectly fine with the DP2 and DP2s, and those two cameras do capture highlights much better.
quma
quma Forum Member • Posts: 67
The Merrill got only half of the exposure compared to the other models.
In this flat light conditions you could "over expose" the Merrill quiet a bit and then bring the brightness down in Sigma Photo Pro.
This would help to preserve colours in the shadows, especially if you turn off color noise reduction in SPP.
https://www.flickr.com/photos/136653525@N08/
 quma's gear list:quma's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Canon EOS R +9 more
Iain G Foulds
… Appreciate all the good thoughts and suggestions. Making notes to get the best from the models. Apologies for my own inexperience causing any unfair bias against any models.
I beleive the various DP models have different IR filters. I am pretty sure I've read something about that the IR filter has changed from DP1 to DP1s.  Most likely the filter also changed from the DP2 to the DP2s.
That would accounts for some of the colour differences that can be observed.
Another difference is the metering, e.g the DP2s meters a bit more conservatively (protecting highlights) than the DP2.
xpatUSA
I didn't know that!
So, different Exposure Indices for a given ISO setting ...
k_db Junior Member • Posts: 33
nice test. i like the dp2s colors especially next to the other two. i really like the dp2x colors after i've seen it by itself for a while. it sorta feels like the colors from the brochure! in a deep magenta zone...
if you're taking requests...program mode, auto wb, iso 50 taken close together...with spp handling it all on auto!
