First prime: XF 33mm f/1.4 R LM WR or XF 30mm f/2.8 R LM WR Macro Lens ?
ntldbg New Member • Posts: 6
I have an X-T2 and the 18-55 and want to get a prime lens.
Primarily it would be for daytime and nighttime street photography around NYC.
The macro is a bit wider and adds some close-focusing versatility, but the 33mm gives me the versatility of 2 more stops. It's hard to decide what to prioritize, and even harder now that the 33 just went on sale.
Any wisdom is appreciated.
Dave
Fujifilm X-T2
pifilos Regular Member • Posts: 343
Re: First prime: XF 33mm f/1.4 R LM WR or XF 30mm f/2.8 R LM WR Macro Lens ?
Dave
Since you mention street photography and nighttime I would say go for the 33mm 1.4 . It is phenomenal for that purpose. You can always use a macro tube if you want to do some more close - focusing (albeit annoying to use and not true macro) but you cannot shoot at 1.4 with the 30mm. Make your choice while considering how important is close - focusing to you. If it is just "nice to have" go for the 33mm
https://www.instagram.com/filippos.drylerakis/
flickr.com/photos/194737069@N06
 pifilos's gear list:pifilos's gear list
Fujifilm X-T2 Fujifilm X-T20 Fujifilm 50-230mm II Fujifilm XF 10-24mm F4 R OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
Flying Fijian Senior Member • Posts: 1,623
33mm f1.4 or even the older 35mm f1.4...
 Flying Fijian's gear list:Flying Fijian's gear list
Ricoh GR III Fujifilm X-E3 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R +13 more
Arjun_R_1
Arjun_R_1 Forum Member • Posts: 76
Seems like quite an expensive choice, no?
There are other options too, depending on how much you want to spend. For a first prime I’m not sure I’d spend that much, but then again you can eliminate the “what if” questions by getting the most expensive choice (and, if you’re happy, why not?).
Budget:
Viltrox 33mm F1.4 (doesn’t seem great but it’s cheap)
Sigma 30mm F1.4 (slightly better than viltrox but wider)
Mid:
XF 35 F2 (fast AF and WR)
XF 35mm F1.4 (great for low light shots with character)
High:
XF 30mm F2.8 (price wise it’s fairly high since it’s new)
XF 33mm F1.4 (the best, but you pay in price and size Vs the other Fujis)
I own the two Fuji 35mm primes and for low light I’d recommend getting a used XF 35mm F1.4 from MPB or KEH or somewhere with a returns policy. Plus you could sell it for similar to what you paid if you don’t like it, but you probably will
 Arjun_R_1's gear list:Arjun_R_1's gear list
Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 16-55mm F2.8R LM WR Fujifilm 50-230mm II +2 more
Rod McD Veteran Member • Posts: 8,589
Dave
Hi,
Two very different lenses......  I have the 30/2.8 Macro and like it, but it's the last lens I'd choose for street - not that I do street.  Do you think you'd be using it's macro capabilities in your street work?  It isn't a genre associated with close-ups.  And close-up work is very difficult in low light.
I suspect I'd choose the 33/1.4 or more likely the 23/1.4, but both are large and expensive options.  If you wanted a more economic and more discreet choice, how about the 23/2 or the 27/2.8, though it's no faster than the XF30 Macro, or the old 35/1.4?
Regards, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
biza43 Forum Pro • Posts: 15,074
Only you can decide what is more important to you: 2 stops or close-focus.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
BklynBill Contributing Member • Posts: 753
I have the 30mm, I like it but my "street" photography would be flowers, food, door knobs or wine labels and even then it's a bit of a niche lens but it's very light and no bother to carry.
So, I'd say get the 33 or 35mm f1.4(with the 33 being on sale I'd go that way). It's not just the low light capabilities but what you can creatively do with depth of field which will help you get unique perspectives for meaningful photos, especially for portraits.
 BklynBill's gear list:BklynBill's gear list
Fujifilm X-E3 Fujifilm X-H1 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +9 more
Oscar Richard
Oscar Richard Regular Member • Posts: 111
Really almost 3 stops, because the 18-55 is like 3.6 at 35mm.. 1.4 opens up a world of possibilities for shooting in MUCH lower light and MUCH shallower depth of field. Unless you're doing a lot of macro I don't see the advantage of the 30 2.8 when you already have the 18-55
I shoot a Viltrox 33 on my X-T2.. I'm super happy with it, probably my most used lens. They can be had for about $200 on Ebay, a quarter the price of the new Fuji. Really you could get the Viltrox 33 AND the 30 2.8 macro for the price of the Fuji 33.
I have no doubt the Fuji is better, so if money is no object to you, or you want the newest latest, by all means, go for the Fuji
oscar.richard7777 is my instagram my last 3 posts were shot entirely (or mostly) with the Viltrox 33 and X-T2
Good Luck
 Oscar Richard's gear list:Oscar Richard's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm XF 18mm F2 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +3 more
gdanmitchell
gdanmitchell Veteran Member • Posts: 7,991
Dave
If I were doing nighttime street photography in NYC (which I do), the excellent 30mm f/2.8 would not be my first choice. It is a very nice lens if you do a lot of macro and like the relatively short 30mm focal length, but it isn't ideal for your purposes.
I have used the 35mm f/1.4 lens for more or less the purpose you describe since I first got into Fujifilm x-trans cameras for my street and travel photography a decade ago. Despite what you may hear — often from folks who aren't aware of how well this older lens works — it is an excellent lens. It is also relatively small (and inexpensive!) for a f/1.4 lens, and that small size is important, in my view, for street photography.
If someone offered me the 33mm f/1.4, even knowing that it is a fine lens, but required me to give up my 35mm f/1.4... I'd keep the 35mm lens.
The only possible downside here is that 35mm (angle-of-view equivalent to a full frame focal length of about 52.5mm) is a bit long for street photography, at least if it is your only prime.
If cost is an issue and you like the idea of a smaller lenses for street, I'd also look at the 35mm f/2. Contrary to expectations, most often you won't shoot at f/1.4 at night, since the very narrow depth-of-field (DOF) is often not your friend. And in the urban environment of NYC there is often plenty of light at night to get by at f/2... or even f/2.8 in a lot of cases.
For daytime street photography, there's little question about the appeal of the f/2 lens — or even f/2.8 lenses- — over the larger aperture lenses.
Speaking of which... my favorite prime for street photography of the sort you are thinking of is... the 27mm f/2.8 pancake lens. It is great in optical terms and it is really small — in my view, a distinct advantage for street. (You cold get this lens AND the 35mm f/1.4 for the price of the 33mm f/1.4...)
As to focal length, while this is subjective, if I had only one prime for street I would prefer a short lens than 35mm on APS-C. That's partly why I like the 27mm, and the 23mm focal length might be a better bet. Here you also have options. There is a fine 23mm f/1.4, though it is even larger than the 35mm f/1. 4. There's also an excellent and small 23mm f/2.
If you are really new to this and still trying to figure out what meets your needs the best, I have some recommendations. First, to the extent possible, shoot with that excellent 18-55mm zoom a lot before you guess what primes might work.That experience will make you a lot smarter when it comes time to shop for primes. Second, think about starting with the smaller and less expensive f/2 and f/2.8 primes once you get an idea about focal length.
Good luck,
Dan
When in doubt, doubt.
www.gdanmitchell.com
