EoS _ R error - digital horizontal dropout line
Started 1 month ago | Discussions
jann lipka Regular Member • Posts: 133
I got it on one of 500 images -
SanDisk SDXC Extreme Pro 64GB 300MB/s UHS-II V90
the line goes through all width of the image ( raw )
here is a crop - it is roughly 4 pixels high
is it card error or camera error  ?
( i can see the line while reviewing on camera screen so it is not card reader )
drsnoopy Senior Member • Posts: 1,216
Re: EoS _ R error - digital horizontal dropout line
Impossible to say on the basis of one single image. Easy enough to fix in Photoshop etc.
If it occurs again, you could try a different card but at 1 in 500 you may never work out where the problem lies.
However what you see on the rear screen is the embedded jpeg preview, which is a different size to the RAW image, yet written at the same time. So my suspicion is that it was more likely a camera glitch. What does it look like in your RAW processor?
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
OP jann lipka Regular Member • Posts: 133
This line is visible in very similar way on the back screen as in
Photoshop / lightroom .
full width 6720px  and  heigth is 4 px- ish.
Quarkcharmed
Quarkcharmed Senior Member • Posts: 2,713
It's a card error as long as you don't have the line in the same position in other images.
save all the images from the card and do a full format (not quick) on your PC (not in camera).
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM
It’s an interesting question, but why would a card error cause the same line to be visible in the same place on both the RAW image and in the embedded, smaller, jpeg image? That implies a camera error, written to both images at the same time.
Given the OP has only had one such image, it would be hard to be sure where the fault lies until (or if) it recurs.
Quarkcharmed
Depends on how in-camera previews are actually displayed.
Corrupted RAM in raw data (before it was written to the card) would likely result in a few corrupted pixels, not the whole row.
It could be a sensor glitch but I understand it never repeated. If this happens again, it can be a problem in the sensor.
To make sure, the OP could try and extract the actual embedded jpeg from the raw file. If both raw and jpeg are corrupted, then I was wrong and it was an in-camera glitch.
My understanding is that the review image on the LCD/EVF is the embedded jpeg.  To support this contention, the review always includes the in-camera corrections that are active, and these are only applied to jpeg, not RAW.  This leads me to the conclusion it is a camera (sensor, processor, or somewhere in the image pipeline) glitch.
A simple way of viewing the embedded jpeg is to use FastStone viewer, which opens the embedded jpeg for preview on screen.
Hopefully for the OP it won’t recur.
As it is much easier to replace the card - i put card I used on side--
5000 images later - using other card  - the problem has not showed  up again.
