Crystal "headdress" on the head of a small LED
Started 1 month ago | Discussions
3D Gunner Senior Member • Posts: 1,025
11
I applied a thin film of colored varnish to the top of a small LED and then grew a crystal "headdress" around it.
I want to repeat the experience on a more powerful LED capable of sending light through a thicker layer of long, acicular crystals.
~23mm FOV, 90mm Macro lens on Sony a6300
Sony a6300
Joseph S Wisniewski Forum Pro • Posts: 35,461
Long exposures? Exposure stacking?
Fun. I love internally lit, additive processes.
But... no time lapse of the growing crystal?
Have you considered playing with very long exposures. I've photographed things that would normally be considered "opaque" with exposures in the minutes, hours, or days. Seriously. Couple of thousand 1 minute exposures, averaged.
Same technique for very low fluorescence. I have this lovely triple-pyramid deep purple fluorite that usually needs hour long exposures to capture its fluorescence at 365nm with a woods filter on the light source and a 415nm high pass on the camera.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
OP 3D Gunner Senior Member • Posts: 1,025
Re: Long exposures? Exposure stacking?
Thanks! 🙂
I planned a time-lapse scene in stereoscopic 3D mode several years ago, but I was lazy to prepare the scene, because it requires some special conditions to be provided over a longer period of time. 3D is "the thing" for something kike this. 🙂
The biggest problem is that in the first phase the solution is cloudy, just when the first crystals appear. That's when the fastest growth occurs.
If the crystallization process for the desired subject is triggered in a clear solution stabilized in terms of concentration and temperature conditions, the process evolves much more slowly and can take several days for a specimen with some decent size.
Can give a try. 😀
3D crystals are fun...
Thanks! 🙂
Have you ever shot and processed for lenticular prints?
I've done some 6 and 10 viewpoint lenticulars with a semicircular track rig. The end results can be quite stunning.
Hmm... Electrodes and a bit of a charge to clear the solution just when you see that initial growth?
Or is that a silly thought?
Can give a try. 😀
It never hurts to try.
I'm picturing a setup with 10 different tanks and a camera on a track sliding back and fourth grabbing shots of all of them. Or maybe the tanks on a turntable...
Ciao! Joseph
Re: 3D crystals are fun...
Can give a try. 😀
Yes, I have been collected images for lenticular prints with themes inside caves. I used a linear slider and collected 20 images (viewpoints) for each subject.
For large prints (up to 50x75cm) I used all 20 viewpoints (for a more fluid effect), for postcards, pocket calendars or others, I used 16 viewpoints for each subject. They were very much appreciated by the customers. 🙂
I have almost everything ready for the time-lapse, I still need a container with quality glass walls and a technical solution to get a variable temperature in the darkroom. I want to reduce a process of a few days to a few hours, even if the result will not be identical.
