X-T5 - shortcut to formatting
Started 2 months ago | Questions
Geoff Chesh
Geoff Chesh Forum Member • Posts: 56
I have only recently upgraded from my X-T2 to the X-T5.
What a difference and a great decision !!
One shortcut I am struggling to replicate though, is the one that allows for a formatting of the memory cards without having to dive into the menus.
Previously, a long press on the track button followed by a click of the rear command dial used to do the trick - directly accessing the format menu. I understand that this was still a working shortcut on the X-T4, but cannot find it on the X-T5.
Am I missing anything ?
Geoff
 Geoff Chesh's gear list:Geoff Chesh's gear list
Fujifilm X-T2 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Fujifilm XF 16mm F1.4 R WR +6 more
Fujifilm X-T2
Erik Baumgartner Senior Member • Posts: 6,894
Re: X-T5 - shortcut to formatting
Geoff
Pretty sure it's the same as before, but a longer press is required than with the X-T2.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
gsz Regular Member • Posts: 170
Just figured out it today - works, but longer press on the command dial is required.
Geoff Chesh
OP Geoff Chesh Forum Member • Posts: 56
Thanks Erik,
I guess it’s always possible that my assigning of a shortcut for the back command wheel is getting in the way. Looks like I may have to think again!
I appreciate your reply
regards
Geoff Chesh
jackhandypete New Member • Posts: 16
Hi Geof: Did you solve this?
I'm having the same problem with my new x-t5
Pete
Hoka Hey
Hoka Hey Senior Member • Posts: 2,991
Pete
I'm new to the XT5 and the XTx line. So, I fiddled with this and got it working.
Press and hold the Trash button. While holding the Trash button down, press and hold the Rear Dial down until the format menu comes up. It comes up after a short delay of a second or two.
Joe
Geoff Chesh
Hi Pete,
yes I did …..
When in shooting mode, I hold down the delete button and then give a long (longer than usual) press on the back command dial. The format option then appears.
the press on the command dial is longer than I was used to on the X-T2
Cheers
Thanks Geoff; much appreciated.
