negative EC
stevet1 Senior Member • Posts: 1,300
negative EC
I read an article last night where the guy said you should always dial in 1/3 to 2/3  stops of negative exposure compensation. He said it brings put the colors more.
I was wondering how you guys felt about that.
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
mocha123 Senior Member • Posts: 2,497
Re: negative EC
Hi stevet1,
When I first came onto these forums and posted on 'Show Your Snaps' I regularly walked the canals around where I lived, the Victorian dark brickwork of the bridges and infrastucture etc. would cause the camera to brighten up the pictures to compensate. For that reason I used to set my AV to negative 1/3 or 2/3 in many instances.
You can always check your rear viewer combined with the histogram to see the effect you're getting in real time.
 mocha123's gear list:mocha123's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EF 100mm f/2.0 USM Tamron SP 70-300mm F4-5.6 Di VC USD Sigma 17-50mm F2.8 EX DC OS HSM +3 more
Dunlin Senior Member • Posts: 2,611
ETTR
Steve Thomas
Steve,
It's not something I do, but the idea makes sense to me.
There is a technique for RAW shooters, that you may have heard of, called exposing-to the-right. Basically the shooter over-exposes the photo (shot in RAW, without clipping any highlights) then darkens the photo in post-processing, which gives the best detail. The books I have that describe this technique say that the photo will look washed out, lacking colour, before the photo is darkened in post - which, inversely matches the article you read.
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
AshleyMC Senior Member • Posts: 2,228
Re: negative EC
That “trick” is a tool in my photographic toolbox.
When used thoughtfully, it makes the image subtly and calmly dramatic — “the mood.”
Also, when Multi (Averaging) metering mode is being used, it makes the dark background darker and prevents the subject from looking too bright.
I use it when an artistic expression calls for it. For weddings, I use it for all scenes.
OP stevet1 Senior Member • Posts: 1,300
Re: negative EC
I know Dig uses it a lot in his photographs, and I was hoping he might weigh in.
I have always found his photographs to be most excellent.
Steve Thomas
Re: negative EC
Ashley,
I know that the author of the article I was reading said that you can use it as a possible alternative to spot metering in a strongly backlit scene.
Which sort of goes along with what Mocha was saying about bringing out the dark wood in his Victorian bridges.
Steve Thomas
Digirame Forum Pro • Posts: 41,857
Re: negative EC
Basically, I want what appears to be best.  I don't spend a lot of time reading about what others do, only what seems to work well for me.  I "chimp" a lot...a whole lot...so I don't have to spend as much time on the computer with post processing.  Sometimes I'll use negative EC at dusk, even though logic might tell us to brighten the photo.  But I often want the photo to look like what I saw it to be, which might be a darken scene.
guinness2
guinness2 Veteran Member • Posts: 4,617
Re: ETTR
Steve Thomas
Steve,
By any chance , ETTR means +EV , the negative exp compensation means -EV , doesn’t it ?
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
Re: ETTR
guinness2 wrote:
Steve Thomas
Steve,
That is correct.
Exposure To The Right means the histogram is being shifted To The Right.
I guess thistechnique could be called ETTL.
Ontarian Veteran Member • Posts: 3,860
Re: negative EC
Steve Thomas
I keep the EV set at minus 2/3 pretty well constantly. In dark shade or when it is night, dusk, or dawn I will change it to plus 1/3 up to plus 1 or more. It is easy in post to adjust the exposure up, or down, but blown highlights are there forever.
Don
 Ontarian's gear list:Ontarian's gear list
Sony RX10 IV
guinness2
Re: negative EC
Steve Thomas
Don
Did you consider exposure bracketing ? Any cons ?
Canon EOS Rebel SL3
Re: negative EC
I've only tinkered with it.  Don
Sony RX10 IV
