Problem wiht last X-T3 FWs
Started 2 months ago | Questions
miroshi Contributing Member • Posts: 690
Since few of the last X-T3 upgrades I can not download the images over USB. I am Linux (KDE) user, but keep and s Windows 7 installation for Raw Edit Fujifilm software.
In both OSs I can not reach the images on any of my cards.
Anyone with same experience who solved the problem?
Regards!
PS - usually the file manager shows the camera, but not the images. I got IO error or message lie - folder is empty. On Linux I see both SDs, on Windows only single external, empty storage.
"It isn’t the camera that makes the pictures great, it’s you." - Dan Bailey
phototravels-bg.com
 miroshi's gear list:miroshi's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 16-50mm F3.5-5.6 II Fujifilm 50-230mm II Fujifilm XF 23mm F2 R WR +1 more
Fujifilm X-T3
gsz Regular Member • Posts: 170
Re: Problem wiht last X-T3 FWs
I assume you have already checked the connection mode in camera settings menu.
Can you see the images using a card reader?
OP miroshi Contributing Member • Posts: 690
My settings are correct - card reader, and yes I use card reader now. It was so easy just to connect the camera with a cable.
phototravels-bg.com
OK, it may be coincidence, but after I tried with few different cables finally I connected the camera.
Regards!
phototravels-bg.com
Regards!
My next idea would have been “try a different cable/USB port” 😀😀😀
gsz wrote:
Regards!
I tried with two Baseus cables - red and black (must be same except the color), and a JBL cable. Looks like only the red Baseus works fine.
phototravels-bg.com
