Would like to see a macro zoom lens
Started 1 month ago | Discussions
EricShaltz Forum Member • Posts: 69
something like a 50-100 f/5.6 macro 1:1
the use case is product photography in a studio with controlled lighting
I'd like to work with one of those lenses, but instead I need 3 lenses, 50, 70 and 100 macro.
feature Wishlist:
  • internal zoom for lens-mounted lighting
  • no aperture ring, it's not useful for studio
  • tripod collar for balanced mounting
  • weather sealing not required
  • absolute position focus ring and clutch (like sony 90mm macro)
  • some kind of mechanism on the focus ring to limit focus range to any point
Jack Tingle
Jack Tingle Senior Member • Posts: 1,526
Re: Would like to see a macro zoom lens
So buy a zoom lens & a bellows. Your field may not be super flat, but you can work around that.
 Jack Tingle's gear list:Jack Tingle's gear list
Canon PowerShot SX720 HS Panasonic Lumix DC-ZS70 Olympus OM-D E-M10 II Panasonic G95 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +8 more
OP EricShaltz Forum Member • Posts: 69
huge light loss, can't hand hold
mmalkin15 Regular Member • Posts: 298
Nikon made a really nice macro zoom in the film camera days. It was 70-180mm 4.5/5.6 and easy to hand hold. Excellent optically and AF I think  macro to 1:2
there were many fine specialty lenses offered in the past that never made it to the digital era.
a_c_skinner Forum Pro • Posts: 13,047
There is no light loss, it is an apparent effect an illusion. What happens is that the effective aperture falls, so to keep the same exposure you need to open the diaphragm to get the same effective aperture. This is because the aperture is the ratio of the diameter of the stop and the distance it is from the film/sensor. This latter is usually of course the focal length or so close to it that it makes no difference. All in a perfect lens of infinite thin-ness but the idea is correct.
I'd also add that zooms are unpredictable on additional extension and of course don't zoom, they are merely variable focal length so the focus goes haywire as you zoom.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Yes, I'd like a macro zoom.  The Fuji 80-300 does get fairly close, as did the Nikon AF-G 70-200 f4 (indeed there were rumours of a macro zoom before it was released).
A zoom with an achromatic close up lens would be worth considering.
Andrew Skinner
Joseph S Wisniewski Forum Pro • Posts: 35,461
Zooms cease being zooms on any type of extension
It also won't be a zoom any more. As soon as you extend a zoom lens, it ceases to be parfocal. Turn the zoom collar and instantly lose focus, often by a huge amount.
The term "mirrorless" is totally obsolete. It's time we call out EVIL for what it is. (Or, if you can't handle "Electronic Viewfinder Interchangeable Lens" then Frenchify it and call it "LIVE" for "Lens Interchangeable, Viewfinder Electronic" or "Viseur électronique").
Stanley Joseph Wisniewski 1932-2019.
Dad, so much of you is in me.
Christine Fleischer 1947-2014.
My soulmate. There are no other words.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
50mm lens and high res camera
Do you mean f/5.6 at 1:1, or an f/5.6 that ends up somewhere between f8 and f11 at 1:1? There's quite a difference.
In the latter case, you're ending up near the diffraction limited resolution of a high pixel-count digital camera, which means you'd be better off shooting with just a 50mm and cropping.
What sort of "product", and what sort of "controlled lighting"?
feature Wishlist:
In a studio?
I've been doing studio work for decades, and have always found an aperture ring useful.
Agreed.
I can picture this mechanism. No one is going to build it.
You are making a basic engineering/product design mistake. You have a problem that you have not stated, and have crafted an elaborate solution in your mind that you are now asking someone to implement. The problem with such a situation is that your situation typically ranges from non-optimal to totally impossible.
Can you describe the problem you're trying to solve, instead?
Ciao! Joseph
Woody S
Woody S Contributing Member • Posts: 742
Get an Olympus 100-400mm, it focuses to a bit over four feet as an 800mm FF equivalent. Naturally you'd need an Olympus camera to put it on.
800mm equivalent for studio product work?
And he'd also need to cut a hole in the wall into another room so he'd have the distance needed to shoot product with an 800 equivalent.
I assume EricShaltz specified 50-100mm because that's the perspective range he wanted, not 200-800mm equivalent.
And that he specified 1:1 because that's the smallest subject he needs to shoot, not the 0.29x of the Oly 100-400.
Ciao! Joseph
Re: 50mm lens and high res camera
The problem is I have 3 macro lenses 50, 70 and 100, I pick the one I want depending on the relative size of foreground and background I want, I'd like them to be one zoom lens.
I feel like large aperture macro lenses aren't very useful because you can't get anything in focus at f/2.8 anyway, so you're mostly using them at like f/8 or lower, so what's the point of having it be f/2.8?
controlled lighting as in my scene is always the same brightness, I always shoot at f/11, and with the lenses I have, that have relatively low light loss at macro ranges, I don't have to change any settings when I want to get a closer shot, most of the time. Where as a lens that has lots of light loss at macro range, I'd have to start changing settings whenever I want a closer shot, which is annoying.
"so what's the point of having it be f/2.8?"
Makes focussing easier of course.
Andrew Skinner
The point of fast macro lenses...
Yeah, I gathered all that from the original post.
And yet, somehow, I do.
Resolution. At f/8 you're bleeding out the resolution paid so much for with a 30, 40, 60mp camera.
When focus or DOF is a problem, you use focus stacking. I do a lot of work with a Zeiss 100mm f/2.0 Makro Planar.
Ah. Then I wonder what the focal lengths of your lenses actually are in the macro range. A "unit focusing" macro lens obeys the inverse square law. By the time you extend it to 1:1 you're down two stops. Floating element (internal focusing, rear focusing, etc) designs "zoom" the lens to a different focal length to reduce extension and aperture shrink, but you pay for this with shorter perspectives.
Ciao! Joseph
xlucine Contributing Member • Posts: 610
Re: Zooms cease being zooms on any type of extension
Who says a zoom lens has to be parfocal? This is product photography in a studio, you've got time to refocus
 xlucine's gear list:xlucine's gear list
Nikon Z50 Nikon Z 16-50mm F3.5-6.3 VR Nikon Z 50-250mm F4.5-6.3 VR Nikon Z 40mm F2
The bigger problem will be that a bellows almost always involves a lot of extension and so you will be constrained to either a very close up arrangement or need to use a long focal length.  I'd be very surprised if many people find this a useful solution.
Andrew Skinner
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,599
feature Wishlist:
Hi Eric, there is always interesting research on innovative optical trains . There is whole body of research in peer reviewed papers on attempts to use some of the existing optical trains in a zoom system such as catadioptric, cassegrain and petzval to name a few.
IIMU several German firms made a few small production runs of these zoom systems on a photographic scale c. 1895 - 1930 ish of the last century .
There are 406 citations for " zoom + lens " in the NIH database with many interesting scientific papers on this subject matter.
https://pubmed.ncbi.nlm.nih.gov/?term=+zoom+lens+
Here are a few individual citations:
Extended the depth of field and zoom microscope with varifocal lens
https://pubmed.ncbi.nlm.nih.gov/35773323/
Three-component zoom lens with fixed position of optical center
https://pubmed.ncbi.nlm.nih.gov/31158198/
Automated design of a slim catadioptric system combining freeform surface and zoom lens
https://pubmed.ncbi.nlm.nih.gov/35472951/
BTW You must keep your 2.8 capacity young man, photography is an art,.
LOl Don't hover at 1:1 MFD trying to play hero - back off a little and take in nature's art
May the photons be with you.
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
Beatsy
Beatsy Senior Member • Posts: 1,355
feature Wishlist:
You get everything but the focus ring or internal zoom with an adapted Canon MP-E65mm f/2.8 1x-5x. It's fixed focus at any given zoom setting so you achieve focus by moving the subject relative to the lens and camera, or vice-versa. That works fine in both studio and field settings.
There are (much) cheaper 3rd party equivalents available now, Sony mount too, but I'm happy with the MP-E and haven't looked at them - just aware they are there...
 Beatsy's gear list:Beatsy's gear list
Sony a7R II Sony a9 Sony a7R IV Sony a1 Canon MP-E 65mm f/2.5 1-5x Macro +16 more
River Photography
River Photography Senior Member • Posts: 1,413
zoom lens with filters
 River Photography's gear list:River Photography's gear list
Sony a7 IV Tamron 70-180mm F2.8 Di III VXD Tamron 28-75mm F2.8 Di III VXD G2
