Event photography
Lmendy Contributing Member • Posts: 819
Event photography
I volunteered to shoot an indoor event.  About 100 guests in a large room.  I will use xt1 with xe2 back up, several primes, 2 manual flashes for bounce and several types of diffusers.  I shoot jpeg (Fuji does a better job then my partial color blind eyes).  My question is whether I should dial up NR to smooth out skin and diminish noise?
 Lmendy's gear list:Lmendy's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm XF 27mm F2.8
dccberry Senior Member • Posts: 1,239
Re: Event photography
If your exposures are good, you should not need to use any noise reduction. Ideally, you can keep your ISO to 400-800 or so, so images should be fine.
 dccberry's gear list:dccberry's gear list
Ricoh GR Nikon D810 Nikon D850 Fujifilm X-T3 Fujifilm X-T4 +10 more
Phil BH Senior Member • Posts: 1,043
I wouldn't, but I would shoot RAW. You will be able to do more if necessary. Shoot RAW plus jpeg and have the best of both worlds. Anytime I shoot an even or wedding, it is RAW.
Phil
baobob
baobob Forum Pro • Posts: 18,248
Leave NR at default, same for skin The Fuji does an excellent job in JPEG with default values I use  Provia below an example with one Godox on the body
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
GMacF Contributing Member • Posts: 999
‘Absolutely not’ would be my advice. The in-camera NR is the one thing that Fuji have yet to master and it can really ruin a shot - skin/hair and foliage are chief among those things affected.
The first setting I dial in on every Fuji camera I’ve had is the NR back to -4 (or as low as it can go on whichever model).
If your final use case is only a digital screen or small prints you will never notice the noise - even at ISO6400.
But that smeary waxy look that the in-camera NR produces is hideous IMO.
 GMacF's gear list:GMacF's gear list
Fujifilm X-E3 Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +9 more
Jared Willson Senior Member • Posts: 1,504
Since you are using strobes, presumably your ISO won't be particularly high, so no need for noise reduction. I would leave that turned off. What you might consider is using one of the film simulation modes that has lower contrast. That will reduce the unevenness in skin tones without reducing detail. I would play around a little bit before the event starts to see if you like the look of, for example, "Pro Negative Standard". Don't worry too much about the label--choose whichever one you think looks best with your lighting conditions. There is some variability in what film simulations are available in which cameras, but definitely worth taking a look.
As others have mentioned, definitely worthwhile to shoot RAW and JPG together. That way, if you get it "right" in camera you will be good to go with the JPG's and won't need any heavy editing. But if you find when you get back to the camera that you have messed up the white balance, or that the film simulation you chose really didn't work well, you'll have tons of latitude to make adjustments since you'll have 16 bit files.
Best of luck!
 Jared Willson's gear list:Jared Willson's gear list
Leica Q2 Hasselblad X1D II 50C Leica SL2 Leica SL 90-280mm F2.8–4 Hasselblad XCD 30mm F3.5 +8 more
Erik Baumgartner Senior Member • Posts: 6,893
GMacF wrote:
I second this. I would absolutely shoot RAW here but, for jpegs, I’m at -4 NR, always. -4 is still plenty of NR in most cases, and you can always add a bit of NR in post if necessary. If the overzealous camera NR smears the fine detail and plasticizes the skin texture, there’s no undoing that later.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
