Profiles to make EF primes like L colours
Barry Reynolds
Barry Reynolds Regular Member • Posts: 243
Canon L has better colours than their EF primes with similar sharpness. Are their profiles to correct the EF lenses so the colours become similar to L lenses?
 Barry Reynolds's gear list:Barry Reynolds's gear list
Canon EOS M6 II Canon EF 85mm F1.8 USM Canon EF 70-200mm F4L USM Canon EF 35mm F2 IS USM Canon EF-M 11-22mm f/4-5.6 IS STM
John Crowe
John Crowe Veteran Member • Posts: 3,476
L colours same, more contrast, vibrance, flare resistance, tonal range
The colours are likely virtually the same. What the non-L lenses lack is contrast, vibrance, and high flare resistance, to name a few. L lens tonal transitions will also be better due to the increased resolution.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
J A C S
J A C S Forum Pro • Posts: 20,544
Re: Profiles to make EF primes like L colours
I have tested L vs. non-L lenses in the past but I own only one non-L lens now, the 15 fisheye, hard to test against a different lens. What I noticed was warmer colors, especially the reds. There was difference among the L's, too.
Can you replicate it with a profile? Not really but you can try to get close.
Chesapeake Imagery
Chesapeake Imagery Contributing Member • Posts: 605
Is this thread discussing SOOC jpgs? If you shoot raw, you can make your reds "warmer or cooler" or whatever you want. I only ever shoot raw, so maybe that's why this thread doesn't necessarily make any sense to me based on my workflow so that's why I ask.
 Chesapeake Imagery's gear list:Chesapeake Imagery's gear list
Canon EOS R5
J A C S
The lens color sensitivity introduces a "signature" that cannot be compensated fully for in RAW. It is a kind of a metameric "error."
Barry Reynolds
OP Barry Reynolds Regular Member • Posts: 243
I'm going to create lens profiles with a Spyder chart and see how that goes
Barry Reynolds
I bought the Spyder 24 and X-Rite Passport 2. X-Rite is much better as it creates a profile where as the Spyder24 creates a preset.
Now colour corrected, there is little difference between the L and EF lenses. If anything the L has lost saturation where as the EF have better colours and saturation.
They would probably be best to add vibrance or a preset on top of the profiles but now there is little between the prime EF and L lens..The primes are actually sharper than my L
