Need some help in Sigma FP Color Shading corrections
Started 1 month ago | Discussions
Chris DC Contributing Member • Posts: 805
Hi All:
I also posted this thread in the "Adapted Lens" forum:
I finally got some sun around home and tried out my newly acquired Sigma FP with my old Leica M39 LTM lenses made back in the 1950's; the 3.5cm. F3.5 Summaron and the 9cm Leica Elmar M39 lens.
Overall I am pleased with the results. Both lenses give interesting looking images and are plenty sharp in the center. The Summaron 3.5cm shows significant purple coloring especially in blue skies around the extreme left and right edges of the frame. I took a picture of a white wall and set a custom color shading setting for this lens. I needed to add(?) some red and some blue to get the white wall to be monotone but the correction is not perfect.
Then when shooting with the lens (3.5cm Summaron) I choose this custom color shading profile. In my view it is only marginally better. I suppose I'll have to play around more with settings. I wish the manual was more detailed in this feature.
Here are some shots with the Summaron and the 9cm Elmar. The Elmar has no edge color problems.
Lots of purple edges on the 3.5cm Summaron
View: original size
Less purple edging when the sky is less blue
View: original size
Less purple edging when stopped down too.
View: original size
This is a white wall after selecting the custom color shading profile-Not perfect!
View: original size
And here's the 9cm Elmar's performance:
9cm Elmar-A little vignetting but no color shift.
View: original size
9cm Elmar does well on distance landscape shots.
View: original size
Overall I am having fun and that was the point of this acquisition. The camera is neat and the EVF is very helpful.
I can say that the dust on the sensor is annoying and something I am not used to seeing. I've been an Olympus mFT for nearly 20 years and never once had to clean dust off my sensors. Oh well.
Anyhow, if anyone can chime in and explain the right way to use the color shading feature on the Sigma FP I will be grateful.
CDC
D Cox Forum Pro • Posts: 32,979
Re: Need some help in Sigma FP Color Shading corrections
The examples look like ordinary vignetting to me. You could try the vignetting fix in your processing software. I may be wrong.
I have not been troubled by dust on my fp. I always give a puff with the Rocket when changing lenses.
Don
Sigma fp
zstekar Regular Member • Posts: 309
Other than with my Leica 50 f/2 on the Sigma fp l, I could never attain a pleasing color cast-free with the Leica 28 f/2.8. The green would show up more often than not, based on indoor vs outdoor for instance. I could never get rid of it fully. What helped the best was to take a picture of a monotone surface in a controlled environment.
 zstekar's gear list:zstekar's gear list
Leica M10-R Sony a7 IV Leica Summilux-M 50mm f/1.4 ASPH Sony FE 24mm F1.4 GM Tamron 28-200mm F2.8-5.6 +3 more
OP Chris DC Contributing Member • Posts: 805
Yes.  I suppose it is tough to get past the physics of light.
The old adage..."better, cheaper, faster...choose any two" applies.
Small, fast, abberation free...you can have one or two of these lens characteristics but not all three!
Perhaps I will come across a smallish sized 35mm or 28mm lens to find that will behave a little better on the FP than the tiny Summaron I have.
Till then, I will keep the Summaron set a t F8 when blue skies are in the image!
CDC
Small, fast, aberration free...you can have one or two of these lens characteristics but not all three!
CDC
I have the Sigma 24mm f/3.5 which is small and aberration free. You could consider that.
Does a 24mm need to be fast ? You can use it with a fairly slow shutter speed.
Don
Sigma fp
Thanks for the idea Don.  It looks like a great companion to the FP.  I will keep an eye out for one sometime.
On the other hand, I already have a very complete mFT system with lenses from 7-300mm.  I got the FP specifically for my vintage film lenses and plan to acquire more vintage lenses as they come across my path (cheap!).  I am quite satisfied by the optical performance on the FP overall.
I am having fun!
CDC
Chris the Novice New Member • Posts: 16
You could try the Voightlander 2.5 35mm Skopar - it's not vintage, but is very compact, good optics, and a pretty good price brand new.
I will definitely add this lens to my list to look for.  Rather than going online to buy one, I think I'll just sit back and see what I stumble across in my travels.  When I find something interesting, I'll post some samples.
CDC
Update: Re: Need some help in Sigma FP Color Shading corrections
Hi All:
Here's an update on the purple corners I have noticed when using the Sigma FP with an old 35mm rangefinder lens, the Leica 3.5cm Summaron.
It appears that perhaps the Sigma FP is a bit prone to the issue.  I took essentially the same image with both the old Summaron 35mm and the new Sigma 45mm lens.  With a vertical camera orientation, the uppermost blue sky at the edges of the frame looks purple with both lenses.
My other camera is a mFT Olympus which uses a 4:3 image format and I've never seen purple sky edging.
Here's the two images:
Taken with the Sigma FP and SIgma 45mm contemporary lens.  The top edge has a purple tint.
Taken with the Sigma FP and the old Leica 35mm Summaron.  More noticeable purple top edge.
I think I am beginning to like the unique character of this camera:)
CDC
