Electronic or mechanical shutter? Locked
Started 1 month ago | Discussions
This thread is locked.
John Sheehy Forum Pro • Posts: 26,688
Re: Electronic or mechanical shutter?
MarshallG wrote:
Nikon and Canon’s most expensive cameras have sensor readout that’s so fast that there is no rolling shutter. Nikon’s is so fast that they don’t even have a mechanical shutter.
So I agree it’s a very safe bet that the R5 and R6-level cameras will not have rolling shutter issues in 5 years or less. Of course, someone will inevitably find a corner case, like the shape of bokeh balls when the lens is wide open and the shutter speed is super high, something like that.
Real issue, but wrong mode.  It is EFCS that has that potential problem; not e-shutter.  Not many people are complaining about the rolling shutter speed of EFCS or full-mechanical shutter on their camera.
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Edymagno wrote:
Alastair Norcross wrote:
Rafavox wrote:
Do you guys mostly use electronic shutter instead of mechanical, I can see advantages like avoiding wear and tear of the shutter mechanism. What is the general rule for that? electronic 99% of the time and for fast moving objects like cars, birds, planes etc mechanical
I use e-shutter whenever I can. That's the vast majority of the time with my R and M6II. I would use it more on my R7, if there were an 8fps option. For a lot of sports, I find 15fps to be overkill (not for all sports), so I use EFCS for that reason. Most of my shooting is unaffected by rolling shutter, so I don't often have to use mechanical (EFCS or full mechanical) to avoid that. I love e-shutter for event shooting indoors, and only use mechanical when the lighting causes banding with e-shutter, which doesn't happen often (luckily).
Hello Alastair:
How do you determine in situ you're getting banding or not?
TiA
Edu
I take a test shot and review it on the LCD. It's very easy to see banding when it occurs.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Distinctly Average Senior Member • Posts: 2,527
Ephemeris wrote:
Distinctly Average wrote:
Ephemeris wrote:
MarshallG wrote:
Ephemeris wrote:
I've seen some software that automatically tires to correct for e shutter creates problems in videos.
Do we think some (maybe not all) could be repaired automatically either with an external tool or in camera?
Personally I doubt rolling shutter could be corrected that way. Capture is at a different moment, so any correction via AI would really be a false representation of the scene.
Given it is done for Video would it not be plausible?
False/not false - isn't that a little bit of a moving definition?
Just enjoying photography
https://www.distinctlyaverage.co.uk/
https://www.flickr.com/photos/distinctly_average/
How would you re-construct missing dragonfly wing parts for instance? In a stills shot you want all the detail but you n video you can get away with parts that are less than accurate. It is also probably easier in video as there are multiple frames to get data from.
I think before deciding if something is impossible we could have a try at making the problem less so.
Let's say I take an image of a vehicle and it has crooked light posts in the background then I can correct it. So it must be possible.
As for missing parts well AI tools do some pretty darn good things with that also. We can see that even with Google Pixel phones.
Less than accurate? Isn't that the majority of our images? If you happen to have to photograph geometric like objects frequently they often need a bit of nudging back into shape.
I know we don't have the ability to do it and it's not something that has ever been asked of us but surely those Nvidia, Google like boffins could give it a whirl?
Some snazzy software to improve rolling shutter so that we don't need extremely expensive global shutters or the like?
Not suggesting it is impossible, just very difficult compared to video. Obviously that depends on the image. The AI model would need a lot of training for each and every subject and getting the image sets required is going to be a legal minefield that is yet to play out, It will almost certainly be possible one day, but by then will we actually have to deal with rolling shutter anyway? I personally don’t think that in 5 years it will be something we will be worrying about.
We started with doubt it could be done, to a 5 year requirement.
Can the rolling shutter issue be negated now? Maybe but I've not seen it at high frame rates (so can it be done at say 240fps).
Cost is a factor here and market places. The market places include mobile phones, security cameras and automotive vehicles as well.
Could we make improvements to the system now? Given it sounds plausible I'd think so.
Can I do anything about it? Very unlikely to be a big contributor Vs the might of the Googles.
I'm glad we do have the Google's and the Musk's becuase can't doesn't seem to be at the forefront.
Can we build a low cost camera, with reasonable resolution, frame rate that has multiple exposures across a frame? Absolutely and it's already in a luxury vehicle brand. I remember being told it couldn't be done - Panasonic told us that.
Anyhow, I'm absolutely not disagreeing with you as we are both just thinking in the wind. I also hope in 5 years this problem isn't one (however it's acheived).
There are unwanted side effects to Nikon's solution and Canon is a tad pixel light. So more side effects.
However the market is a lot bigger than the R1/3/5 world and maybe some of the side effects are really quite tough to fix.
The R3 still doesn't manage to take images of rotating fan blades without problems so even it could benefit of my pipedream 🤗
That is probably the biggest hurdle, cost. The companies that could do it would need quite an investment. The return on that investment would be doubtful especially given rapid advances in technology that will inevitably remove the problem. At the moment the tech for fast readout already exists, but is probably a little too expensive for the lower models. But we all know how quickly this kind of technology comes down in price as volumes increase.
I am sure big investors could see this and therefore a specific AI would not be on their radar.
Your logic is a little odd. Given this exists already, commercially for video and yourself talk of 5 yearsj, too expensive etc.
Could it be possible this already exists within mobile phones at some level?
Why would improving an image due to an effect that is an inheritant part of the pipeline not be something being developed?
How would you then speak of the Topaz system which can make improvements to images due to camera shake or out of focus? And does it well (we use it).
Would you have said the same about AI noise reduction?
It it was a side effect of image recognition or the line then we have a maybe
All very different things. What we are talking here is temporal correction. Think of that reflection image from Duane Paton with the bird in a very different position in the reflection than the bird in the air. Noise reduction and minor distortion is not too hard. But when you looke at how AI performs with making people smile etc and it looks very weird in a still. Less so in video as the brain corrects for certain things. It can still be done very poorly, look as superman’s mouth in that justice league film for a prime example, the worst moustache removal in the history of film.
I don't think I can agree in sorry.
If we have a 30fps, or even faster 40 it doesn't matter so much becuase we are using ES. What we have is a series of frames taken in time. Each frame itself also has a time component which is what we are saying is rolling shutter.
Sounds a great place for a computer to fix or at least improve the image.
It depends on the image. Sloping uprights are probably not too hard. If a birds wing is dragged through a frame then that is not easy. Only way to do it is compare to a database of similar shots and create a replacement. Then the background has to be considered. It is a lot more challenging.
So it is done in some ways already by Topaz on stills.
Different thing. Sharpening, Noise reduction are relatively trivial
It is done by multiple vendors on video.
Partly. You don’t need a high level of correction in a moving image. It is done quite differently.
I manually correct if needed.
That suggests we have growing evidence for it being plausible.
I have not suggested it not being plausible. Just very difficult and expensive. The kind of investment needed would probably not come as we are getting to the point where rolling shutter will no longer be an issue anyway.
Further more we have images created without a camera in the first place (well I suppose it does need images in the pipeline at some point in the process).
Why do I say expensive? From the point of view of an investor, what would my long term return be and would it grow? I think it would be a hard sell.
Same as the growing range of image improvement software vendors. Let say Adobe, DxO, Topaz etc. They seem to be able to make a living from image enhancement and find it relatively easy to have a large user base (two of them take our money yearly).
José B
José B Forum Pro • Posts: 20,482
I just got the R6MKII. I intend to shoot some sports with it mainly outdoor tennis and indoor volleyball. I've seen the samples of tennis shots using ES.  The rolling shutter looks well controlled as concluded by the ones who tried it out at the launch.
From my experience of using ES with the Sony A6600 for tennis, it's really not too bad. Yes there are some images where the racquets looks elongated and or the balls are egg-shaped. However, most of it happens on tennis serves. So with the R6MKII I plan to use high speed bursts via mechanical shutter for serves and ES for everything else like ground strokes. Also, I assume that the read out speed of the R6MKII is a lot faster than the Sony A6600.
 José B's gear list:José B's gear list
Canon EOS R6 Mark II Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5DS Sony a6500 +16 more
Wouldn't it be nice to have two shutter buttons, where the 2nd one had alternate settings?  Just choose them in real time, like the way one moves their right foot between the brakes and the accelerator in a car.
John
MarshallG
MarshallG Veteran Member • Posts: 8,951
John, I think the future is just global shutters and mechanical shutters will be gone for good.
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
Yes, but there are also other things that could be assigned to a second shutter button.  It's much easier than fumbling with menus and back buttons.
John
Ephemeris
Ephemeris Senior Member • Posts: 1,186
Do you think that may depend on any advantages that the current system has Vs a global shutter?
For example doesn't our Canon R3 come with limitations as well as the Nikon concept?
Edymagno Veteran Member • Posts: 3,694
Hello Alastair:
TiA
Edu
Just what I needed to now.
 Edymagno's gear list:Edymagno's gear list
Sony RX100 III Sony a6000 Canon EOS R5 Sony E 30mm F3.5 Macro Sony E 50mm F1.8 OSS +6 more
José B
[text snipped]
Yeah John I wish.
BTW, I see no difference in the bokeh. Maybe because the background is almost unreadable?
Electronic
EFCS
Mechanical
Sittatunga Veteran Member • Posts: 5,406
José B wrote:
[text snipped]
Yeah John I wish.
More likely because they were only taken at f/1.8.  That's an impressively curved racquet in the first picture though.
Electronic
EFCS
Mechanical
Not sure why you would expect the bokeh to change at 1/160th either. It's the combination of a very wide aperture, a very narrow slit, no shadow from the electronic front curtain and the shadow of the physical rear curtain that can make smaller bokeh balls look odd.
José B
Sittatunga wrote:
José B wrote:
[text snipped]
Yeah John I wish.
Sorry my above (bokeh) comments should really be for the following three images
Electronic
EFCS
Mechanical
Ephemeris
What is your aperture and focal length for these images?
José B
Hi the exif is there but if for some reason it's not appearing---the tennis are 135mm @ f/1.8 and the orchids are 85mm @ f/1.2.
Ephemeris
Thanks Jose.
I am on a mobile so I don't normally see it anyway.
Aside from the slightly curved racket (you maybe able to fix it) the bokeh images look identical to my eyes.
Most appreciated
José B
Ephemeris wrote:
Thanks Jose.
Most appreciated
You're welcome!
José
Alastair Norcross
On both my R7 and R6II I have the movie record button set to toggle silent shooting on and off. I find this to be a really quick way to access e-shutter, and preferable to having a second shutter button, which I would be more likely to accidentally press.
Alastair
It is certainly easier that way than going into the menus, but it still isn't as fast and immediate as choosing between two shutter buttons, IMO.
How often do you step on the brake when the light turns green, or the accelerator when the light turns red?  I haven't done anything like that since I first was learning to drive in the 1970s.
John
José B
Great idea!!!
Mako2011
MOD Mako2011 Forum Pro • Posts: 28,706
Locked...
...as the posts become just uncivil replies and no real valuable discussion
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
