Electronic or mechanical shutter? Locked
Started 1 month ago | Discussions
This thread is locked.
Rafavox
Rafavox Junior Member • Posts: 49
Do you guys mostly use electronic shutter instead of mechanical, I can see advantages like avoiding wear and tear of the shutter mechanism. What is the general rule for that? electronic 99% of the time and for fast moving objects like cars, birds, planes etc mechanical
 Rafavox's gear list:Rafavox's gear list
Canon EOS R Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 50mm F1.8 STM
Distinctly Average Senior Member • Posts: 2,527
Re: Electronic or mechanical shutter?
Mainly ES. I shoot lots of fast moving subjects and ES works much of the time. Depending on various factors I switch to EFSC which covers the rest of the time. I don’t shoot full mechanical on my R cameras. Hopefully in a few tears ES will be all that is needed.
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
I use e-shutter whenever I can. That's the vast majority of the time with my R and M6II. I would use it more on my R7, if there were an 8fps option. For a lot of sports, I find 15fps to be overkill (not for all sports), so I use EFCS for that reason. Most of my shooting is unaffected by rolling shutter, so I don't often have to use mechanical (EFCS or full mechanical) to avoid that. I love e-shutter for event shooting indoors, and only use mechanical when the lighting causes banding with e-shutter, which doesn't happen often (luckily).
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
DIGITAL-PURPLE
DIGITAL-PURPLE Junior Member • Posts: 39
Electronic shutter on the R3, every day all day.
Canon R3 | R5C | C70
RF 16mm 2.8 |15-35mm 2.8 | 50mm 1.2 | 85mm 1.2 | 135mm 1.8
ld_bl Forum Member • Posts: 71
I almost exclusively use EFCS. 14 bit raws and no rolling shutter artefacts. Sometimes I'll full mechanical shutter when I shoot wide open in bright light to avoid the weird bokeh issues you get in those situations with EFCS. I only use electronic shutter if I need to be silent which is extremely rare.
DIGITAL-PURPLE
What body you shoot with? I use electronic on the r3 and don't see bokeh artifacts, but now I wonder if mechanical would do it better. Who knows, the bokeh looks good tho!
cfieldgate Regular Member • Posts: 475
+1
 cfieldgate's gear list:cfieldgate's gear list
Canon EOS-1D X Mark II Canon EOS R3 Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM +6 more
axlotl Senior Member • Posts: 2,273
HI, There is no general rule. The decision to use full mechanical (MS), Electronic first curtain (EFCS) or all electronic (ES) will depend on camera body (some have a damped shutter others do not)  shutter speed (medium slow shutter speeds may be prone to shutter shock with some lenses) lighting conditions (banding with ES),  frame rates (fast rates may lead to shutter shock even when using EFCS) and camera/subject movement (rolling shutter problems with ES).
You can see that R3 owners tend to use ES because that camera has a fast scan speed.
I use the R5 in EFCS all the time which works well with that  body and also the R and RP.
The R7 and R10 require a more case specific approach as the shutter on those bodies is not the damped type.
Unfortunately there is no simple answer to your question . However if you search this forum you will find several relevant posts which may help.
Andrew
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
Bokeh artifacts with fast primes and fast shutter speeds are affected by EFSC, not the electronic.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
Canon_Guy
It is highly subject/situation/camera dependent. With my R6 fully electronic shutter reduces RAW bit depth therefore adds shadows noise and reduces dynamic range.
That is why my default setting for the best IQ is EFSC (80% of time). When shooting with f/1.4 primes at shutter speeds below 1/1000s I swich to mechanical because of the bokeh (15%). In cases when fully silent shooting is a must or when I want to use the 20fps despite the slightly reduced IQ, I swich to electronic (5%).
Leigh A. Wax Senior Member • Posts: 1,621
"Either-Or"? -- "It's gotta be this or that"--or does it?
A "Point & Shoot camera lacks any additional user controls, or "tool's." to apply as appropriate for differing shooting situations.
Current MILCH cameras have a multitude of "tool's"/ Control's to apply as appropriate to any particular shooting situation; yet so many seem to want theirs to be limited to a P&S, "one fits all" category.
ppage
ppage Senior Member • Posts: 2,589
Good and important point; a lot of people are either not aware of or don't care about the ES producing 12-bit raws rather than 14.
 ppage's gear list:ppage's gear list
It makes very little difference to the final edited pic IMO. There are times when it makes a difference but for me they are rare and I am sure they are for many who shoot the same way as I do. The advantages of the ease of tracking many subjects in ES outweighs the 12bit vs 14bit output.
ppage
True; it depends on what one is doing; I don't think everyone should be using EFCS just because it produces 14-bit raws.   I do mostly landscapes and so it matters to me; if I was shooting sports it probably wouldn't.  My point was simply that people should know about this difference between ES and EFCS and then their decision to use one or the other will be better informed.
Yep, I agree. I wish I had the time and skills to dedicate to landscape. I shoot mainly wildlife and windsurfing, compared to landscape the amount of time and effort is very low. Getting up at silly o’clock to get to a location for that magic moment, the amount of failed trips etc Many then wait it out for the sunset. I am always amazed just how much work gets put into a great landscape photograph. I too would want the best quality I could get for that amount of dedication,
gipper51 Veteran Member • Posts: 5,901
Same here.  EFCS is my default setting.  Mainly to avoid shutter shock in the 1/125 - 1/160 range.
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
Ferenc MOGOR
Ferenc MOGOR Veteran Member • Posts: 5,762
Just for the record my main setting is Electronic Shutter. Like others I'm also concerned about "tear and ware" on my R6 MK1, so 99.99% I use ES.
Cheers, Feri
'I can look at a fine photograph and sometimes I can hear music. Ansel Adams.'
 Ferenc MOGOR's gear list:Ferenc MOGOR's gear list
Canon EOS R6 Canon RF 24-240mm F4-6.3 +2 more
Duckman21 Regular Member • Posts: 273
I have been using electronic shutter on my R6 mostly for the past year but if possible I change to ECFS to maintain backgrounds from skewing. If your subject is against an "organic" (round parts of trees) or otherwise blurred background it is fine but not when I run into trees, buildings and poles.
If I really don't need to capture so many frames, I switch down to [H] mode instead of H+ because it allows for 14-bit files instead of 13-bit. H mode also allows you to take advantage of "high speed display" which means you see  some motion between shots. Nowhere as smooth like a stacked sensor (more like 15fps)  but far less choppy than H+ which shows a disorienting frameskip.
Wing warping is one thing with rolling shutter but another is jagged artifacts on the wingtips, similar to "bad deinterlacing/combing" for videos. I discussed it in this thread:
https://www.dpreview.com/forums/thread/4659188
I find that for some situations this can be somewhat fixed in post but there's no easy way outside of using a brush to smear or blur out the wingtips around. Sometimes but not always Topaz Denoise will try to denoise the wingtips and thus it greatly reduces the artifacts, while DxO DeepPRIME seems to make it worse especially if there is lens sharpness turned on (in PhotoLab, in PureRAW it is applied to some extent even if "turned off"). If possible I just mask a layer for the DxO and Topaz treatments.
Instagram @FYLegend21
500px @frankyboy5
 Duckman21's gear list:Duckman21's gear list
Canon EOS Rebel T6s Canon EOS R6 Canon EF-S 18-135mm F3.5-5.6 IS STM Tamron SP 150-600mm F5-6.3 Di VC USD G2 Canon RF 800mm F11 IS STM
oldfartwitha5d Senior Member • Posts: 1,509
I do a lot of flash work these days, so I mostly work with mechanical shutter. Also, as mentioned by many in this thread, there are a few (minor) issues with ES, with artificial lighting, bokeh, dynamic range, rolling shutter etc.  And I'm old school, so unless my R5 is on tripod, or need absurd frame rates, it just stays in mechanical mode.
 oldfartwitha5d's gear list:oldfartwitha5d's gear list
Canon EOS 5DS R Canon EOS R5 Canon EF 135mm F2L USM Canon TS-E 90mm f/2.8 Canon EF 100mm F2.8L Macro IS USM +14 more
R2D2 Forum Pro • Posts: 26,536
As has been mentioned, shutter selection is very situation-dependent (and body-dependent).  For instance owners of the R3 will find fewer restrictions than those with say an R7.
I was thrilled when the R6 Mark II was announced having a much faster readout speed than my Mark I.  It was the primary deciding factor in my decision to upgrade.  The R6(ii) is my main event/sports body.  Electronic shutter can be invaluable in many instances (IME).
The R5 is my birding/wildlife body, and the fast(er) readout speed was a big deciding factor in choosing it over the R6 when they came out.  Here again eShutter can be really useful.
The R7 IMO seemed purpose-built for my macros.  I use eShutter bursts a lot with my LEDs.  Rolling shutter is seldom an issue.
It’s nice to have choices.  Universal Shutter will come into play at some point.  Until then, we’ll still have to use our photography smarts.
R2
