R8 predicted specs: Full frame at $1499
Started 1 month ago | Discussions
Fat Nerd Forum Member • Posts: 66
With new information on the upcoming full frame camera, what's your expectations/predictions on its specs
https://www.canonrumors.com/canon-will-soon-announce-the-canon-eos-r8-and-canon-eos-r50-along-with-two-new-kit-lenses/
Canon EOS R8
  • Will be body only or kitted with the Canon RF 24-50mm f/4.5-6.3 IS STM
  • Pricing: $1499 Body Only (USD)
  • Pricing: $1699 Canon EOS R8 with RF 24-50 IS STM (USD)
It's most direct competitor from Sony seems like the A7C/III
My guess is:
  • 24mp sensor from R6II (unless they decide to develop another sensor)
  • Between 7-10fps max mechanical burst rate (probably would be closer to the lower end of that range)
  • 4K30p full from 6k readout, IPB only (no All-I), C-log3
  • Possibly 4K60p cropped
  • No IBIS
  • EOS RP/R10 style control layout, no top screen, has twin dials, no joystick but has a D-pad
  • LP-E6NH battery if Canon is generous
  • 2.36M viewfinder
  • Weight around 600-650g: this is a result of the additional bulk needed for both the housing of and the weight of the LP-E6NH battery
  • None of the gimping from the RP (we get silent shutter, focusing aids, in camera manual HDR)
Basically a full frame R10 with an LP-E6NH battery and better video specs
My justifications:
  • Canon doesn't mind existing R users not upgrading if only for photo features, if they want a higher megapixel sensor, they should upgrade to the R5. On the other hand, they wish to capture any R users who want to upgrade because of new video features as Canon has shown a trickle of advanced video features and 4K down to the more economical models
  • The lower max mechanical fps should leave a sufficient gap between it and the R6II
  • The R10/RP style controls, sufficiently functional with the touchscreen, but lacking the joystick which has always been reserved for more pro models
  • Clog-3 is still in question, though it is very likely since their target market includes content creators
  • 2.36M viewfinder to keep costs in check. This camera is released at $200 more than the RP, so cost should come as a consideration for some components
  • No IBIS: the majority of the R system's lens have optical IS, moreover, all inexpensive RF zooms have IS. The upcoming 24-50mm RF STM IS shows their commitment to this strategy
They will probably stop production of EOS RPs (I think they stopped EOS R at this stage?).
Even if one or two of the specs I mentioned are gimped, this camera is going to sell like hot cakes. I am really excited for its launch!
 Fat Nerd's gear list:Fat Nerd's gear list
Panasonic LX100 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-G7 Canon EOS RP Canon EOS R6 Mark II +9 more
Canon EOS R10 Canon EOS R5 Ricoh Caplio R8
dmartin92
dmartin92 Senior Member • Posts: 2,557
Re: No Av mode in video ?
With my R6 mk 2, for the first time in my life, I have Av mode when I am shooting video.
With my 6D mk 2, there wasn't any. But I think the 5D mk iv, had it.
It's a feature that they hold back to differentiate the pricing, I think.
So no Av mode in video on the R8 ?
 dmartin92's gear list:dmartin92's gear list
Canon 6D Mark II Canon EOS R6 Mark II Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM Canon EF 40mm f/2.8 STM +1 more
cnyphotoguy Contributing Member • Posts: 817
Re: R8 predicted specs: Full frame at $1499
5
Make an RP with upgraded sensor, IBIS, and 5-7fps and it should be great.  I have no issues with the smaller batteries to keep the size down.
 cnyphotoguy's gear list:cnyphotoguy's gear list
Canon EOS Rebel T6i Canon EOS RP Canon EOS 90D Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM +15 more
OP Fat Nerd Forum Member • Posts: 66
I think this makes a lot of sense, for the camera to have a stronger appeal to the casual crowd, the lighter LP-E17 might be used. Hopefully we get battery better tech in that form factor from this release
I'd also like to revise my prediction, I think 4K60p cropped might be unlikely too. Just like the way they removed dual pixel from the RP's 4K cropped, they could want to reduce the feature set and not provide 4K60p in any form
Gam3r01 Contributing Member • Posts: 572
Honestly the way canon has done things this far the least likely inclusion would be the LPE6NH battery. I would be shocked to find anything that large in this model.
I also wouldn't be surprised if they use the R6 I sensor, not the R6II. With the R6 likely leaving production it's either a result of the 1DXIII sensors also leaving production and stocks are low, OR they moved to the 24mp sensor for the R6II to make room for sensors to be used in the R8.
That said, it would also be very economical to use the same sensor. I say 50/50 guess right now.
 Gam3r01's gear list:Gam3r01's gear list
Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 16mm F2.8 STM
mpb002 New Member • Posts: 5
6
If it doesn’t have IBIS it’s dead in the water to me.  Even a 2 year old Nikon Z5 has IBIS.   I am a Canon dslr user but Canon is behind the curve in this market segment and will lag further without IBIS
Marximus
Marximus Regular Member • Posts: 474
I understand it kind of being a lower tier model, but I think it'd be really lame to not have a joystick on the R8. The R10 has one and it's about $600 cheaper.
 Marximus's gear list:Marximus's gear list
Canon EOS R5 Canon EOS R6 Canon EF-S 60mm f/2.8 Macro USM Canon Extender EF 1.4x III Canon Extender EF 2x III +10 more
6
I guess I'm an outlier here, but IBIS means basically nothing for me.
I almost never shoot at a shutter speed low enough for IBIS to make a difference, even regular IS is hardly noticed, if at all.
J.K.T. Contributing Member • Posts: 512
I certainly do. I'm completely fed up of the RP battery life.
 J.K.T.'s gear list:J.K.T.'s gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS R7 Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM +15 more
thunder storm Forum Pro • Posts: 10,139
The main question:  If it has fast AF (unlike the R and RP) and it's 24Mp or more, what's Canon going to do (what will be cr*ppled) to protect R6II sales.
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
Nunataks
Nunataks Regular Member • Posts: 229
I hope it's the same size as the RP at least, but less ugly (recent Canon models haven't looked horrible so that's one good thing).
The obvious choices would be smaller battery, lower FPS continuous, single card slot, and no IBIS.
Other considerations, no weather sealing, lower spec EVF/Screen, more plastic construction, less control options (dials, buttons, wheels), slower sensor readout (elec. Rolling shutter), and I'm sure the list could go on.
That might not be enough.
that's somewhat protecting R6II sales
less wheels, that will protect R6II sales very well
O yeah, Canon is pretty creative in lowering value of entry level stuff. I'm really exited what they will invent this time.
Llop Forum Member • Posts: 50
Maybe same body as R7 as well?
Nunataks
Personally I'd love this and probably pick one up but then Canon wouldn't really sell any R7.
Somehow I am guessing they'll make this thing without an EVF, because Canon.
PhotoKhan Forum Pro • Posts: 11,930
8
I find these statements as strange as if I heard a driver say he/she does not drive in a way that makes traction control something worth having.
To each their own, they say...
PK
“Loose praise may feed my ego but constructive criticism advances my skills”
https://www.instagram.com/lisboa_ao_voo_do_passaro/
http://www.humbertoborgesfotografia.com/
http://www.pbase.com/photokhan
(PBase Supporter)
PK
Considering I shoot almost exclusively moving subjects (friends and family "in the moment"), having the shutter speed low enough for IBIS to matter would bring in motion blur of my subjects.
Unrelated, but in my line of work (forestry) traction control screws things up more than it helps too!
Interesting, several hours of use in a day and I'm down 50-75% of battery with a lot of EVF and screen usage and shot review.  I always have another on me and hardly ever use it.
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
That could be a good thing. I love the M6II, with the detachable EVF. I carry the EVF a lot, but hardly ever use it. But that's OK, because it's so small and light. I suspect it will have an EVF, though, because people seem to love their humps! But I would be pleasantly surprised if this camera has the same form factor as the M6II.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
BackToNature1 Senior Member • Posts: 1,770
Re: Full frame at $1499 Must have IBIS.
Well at this price point and specs, it got to have IBIS.
