The Fujifilm X-H2 High ISO Noise vs the X-T2
baobob
baobob Forum Pro • Posts: 18,248
Re: The Fujifilm X-H2 High ISO Noise vs the X-T2
Agree
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
baobob
Noise with the XH2 ?
yes the XH2 can be noisy. And can be not noisy
In brilliant light there is no issue at all
BUT
The 40 mpx sensor does need more light than the  26 Mpx. So in dim light it is essential first to set exposure to get aperfectly centred histogram, then push exposure with +2/3 to 1 EV(ETTR) and control the position of histogram on the right. In RAW recovering highlights is easy and you have prevented noise in shadows
After a debut of controversy about this question I have conducted trials indoors with ETTR and got excellent JPEGS where the moderate noise was easily mastered with NeatImage. If ypu use DPR studio scene files you will see that the difference in noise between XH2s and XH2 is really moderate till 6400. After 6400 the denoising process starts to smear very fine details in XH2 files but photos are perfectly usable up to A4
Again using DPR studio scene files up to 3200 ISO the difference in IQ is minimal between XH2 and aFF with the same  res. After 3200, of course the FF is really better.
Below read noise comparison showing the very moderate diff between XH2 and some FF
BackToNature1 Senior Member • Posts: 1,787
Yidahoo wrote:
Thanks everyone for making this a very interesting discussion. I would like to point out that nowhere in the video have I claimed to be inexperienced with RAW files. I have been shooting and processing RAW for nearly 20 years.
The idea for this video was simply to compare like for like with absolutely no processing. I plan to do another video where I take the same files and process them into usable images in Lightroom, using exactly the same editing settings and applying the same amount of LR noise reduction in order to see how they stack up.
I don't own any third party noise reduction software as I don't shoot high ISO very often.
There is another thread where certain folks are claiming Noise doesn't matter. Well it certainly does, regardless of which Brand or Sensor one is using. Some are claiming it doesn't matter because of modern noise reduction software. Some are claiming many things about it.
With so many folks with claims how Noise doesn't matter, it's real funny how so many do indeed own, third party noise reduction software.
Most times that I do shoot at high ISO is mostly for testing reasons. To see just how far I can push the camera for my tolerance levels. I normal try to stay as close to base ISO, as humanly possible given what gear I am using an or the subject matter. The current conversations about Noise is mostly centered around the higher MP cameras, be that cropped or FF.
baobob
There is a difference between it does not matter and it is not an issue. IMO it does matter but it is not an issue with the XH2 sensor provided in dim light you ETTR, AF is perfect, and use a lens with a good contrast to have a high SNR. The 40mpx sensor is not forgiving approximate settings. As usual with new specs there is a learning curve to obtain optimal results.
When needed very high ISO will allow to catch the scene at the cost of some loss in IQ Denoising programs are just to help to maintain usability of the shot. It is clear that it is better to set camera in order to minimize the level of noise.
When I got my XH2 alongside the XH2s I fouynd it very noisy. Fortunately there are here participants who had already experience with the camera and there comments and advices helped me to obtain optimal results with the XH2.
At the end it is now for me no longer an issue.
Erik Baumgartner Senior Member • Posts: 6,894
  1. The point here is that these are not the same sensors and they will absolutely require different settings for optimal results. You can’t just go and do the same old thing to the 40MP files and say, hey, these is noisier, that’s not how it works. Competing files must be treated independently and must be processed to the same standard - the least noise possible while retaining the most detail possible and with same resulting brightness, color, and contrast.
Maybe you aren’t the guy who should making videos about processing high ISO files?
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Storare Regular Member • Posts: 268
“The most critical roll in determining noise is the photon flux. In reality all comparisons should be scaled to a standard photon flux to make a valid comparison”
Broadcast video cameras are spcified this way. Snr is measured with a stadard target illuminated at 2000 lux
T.Storare
Clearly the differences are personnel to each individual. That I am perfectly okay with. The issue I have is when anyone wants to tell anyone else what levels of comfort they should have with their own images.
I don't care how sharp, what noise levels anyone wants with their own results. But I have a huge problem anyone telling me what levels don't matter or isn't a issue for me.
By the way, I totally didn't agree with the yTuber Omar about the difference in IQ between the 2 sensors, 40MP and 26MP. I don't like yTubers doing those types of tests, then spreading it around as the Golden Goose that laid a Golden Egg.
I also believe that for the most part, Higher MP camera give more detail at the cost of more noise. All things else being equal. So I lean towards higher count MP cameras moving forward.
baobob
Agree. It took me some time before I realized that my XH2 files should not be treated the same than the XH2s files
And this is true at the shoot step. There is definitly with a new tool a learning curve. It is worth to put some emphasis in low light to use a lens with a good contrast, IMO more important than resolution. Perfect focus, exposure adapted to the situation (ETTR or not), correct SS, adapted ISO lead to optimal result. Clear the 40 mpx is not forgiving approximation.
Phil1 Senior Member • Posts: 2,307
Thank you for a very interesting and useful video link. The follow-up on processed photos will be even more interesting and I eagerly await it as it is the processed images which are critical in practice.
However, the key to the whole problem is to find a solution which gives more than acceptable results with the minimum of expenditure and if you can find a way to make any image look up to your standards at the size you print or view without upgrading to FF or MF then this should be thoroughly explored first in my view.
Jerry has mentioned Topaz Denoise AI and this is a really excellent approach which gives better results than LR.
There are other avenues well worth exploring and I’ve found that Deep Prime, as used in DxO’s Photolab 6 (as a LR plugin), produces outstanding results as it maintains sharpness and can virtually banish noise, especially on very high ISO images such as ISO 3200 and 6400. (The cheaper version, DxO pure RAW) doesn’t have the important flexibility of changing the amount noise reduction applied at different ISOs and, while worthwhile, it isn’t as good as the more flexible version in PL6 which I reckon can give up to an extra 2 stops!
DxO often has free trials and it is really well worth trying it out. It’s not dirt cheap but it is hugely less expensive than upgrading a camera or a whole system (as is Topaz).
Perhaps as important though is the need to maximise S/N by exposing to the right!
However, I regret to say that giving in to GAS is often far more exciting in the short term than upgrading the S/W!
Disclaimer: I have no relationship of any sort with DxO but you’ll have gathered I find it invaluable.
Phil
Re: X-H2 vs. A7III
Because it is a dam sight cheaper than upgrading to FF and is often more than good enough – what more would you want?
Phil
baobob
having both cameras XH2(x) IMO the real interest in the 40mpx for me is its ability for cropping. In term of res  the difference is finally quite small. I shoot often birds and looking carefully at feather details I do not find a big difference. I also checked in veri fine foliage, yes abit more details but not night and day. yes it allows bigger prints as well
IMO this mpx race is partly a marketing initiative. (allowing also higher price tags ....)
JNR
JNR Veteran Member • Posts: 4,652
Your efforts are appreciated, but I think drawing firm conclusions from the exercise would be unwarranted. The problem is if you don't use any of those 20 years of RAW processing experience and simply show what happens based on the default settings - it is as though you are showing what happens if you are entirely inexperienced.
I don't know about LR default settings for the new sensor, but with Capture One the default settings are pretty far off from optimal. As I'm getting closer to finding those optimal settings compared to the X-T2, I'm finding detail to be at least as good with more DR at 3200-6400 when the NR is at a comparable amount of smoothing to the older sensor at optimal settings. Not surprisingly, the new sensor is considerably more detailed at the lower ISO settings - especially so up to ISO 500.
To be entirely clear, you have to apply settings to see a RAW image - and that requires processing. If you are saying that you haven't output from the default settings, that would be the correct nomenclature. Of course viewing output is more helpful, especially properly NR optimized output.
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
baobob
In ACR PS this is what I get as default
far from optimal as you stated ..... WHazt I often do is to open the RAF in default an if needed process the TIFF in neatImage to chack for noise and master it if needed. IXT read and demosaics XH2 RAF files very well and there are much more parameters to set to improve the final result.
yomimoi Forum Member • Posts: 50
Re: X-H2 vs. A7III
Phil
I want better than "more than good enough".
As to it being that much cheaper as you suggest, I don't think so. It totally depends on your shooting needs, but some FF options provide many affordable, quality third-party lenses. Plus some very good FF cameras currently cost the same or less than the X-T5/XH2.
Re: Before selling, try this...
Kaoticphoto wrote:
Maybe I'm not proficient with the denoising tools yet, but I think people are putting too much hope in their ability to make high ISO files from this new sensor much better. From what I've seen so far, anything above ISO 4000-5000 is worse than what the X-T2 produced, let alone the A7III. And these are 5-6 years old sensors. I can't help but think these new sensors are rather disappointing for low-light photography.
`these are 6400 iso, processed in same way, resized at same size, X-H2 and A7III
https://www.kaotic.it/trash/A7III_6400.jpg
https://www.kaotic.it/trash/XH2_6400.jpg
Thanks for these, I had missed your reply. Whatever you did to the A7III file, it made it slightly worse in several of the areas where it looked to retain more detail. However, note that it's the unprocessed RAW (and resulting JPG) looks noticeably better than that on my settings.
The XH2 looks pretty much like what I get from processing in Lr and Topaz Denoise.
All in all, fairly close, but that's my point. The A7III, despite being a much older, and, right now, cheaper camera (at least where I live) produces at least equal (in my view slightly better) results without any additional processing.
Anyway, each of us knows what is good enough for them, and whether the trade off is worth it.
sw88 Forum Member • Posts: 56
Tbh, Fuji IQ hasn't changed much since the first X-Trans sensor. My XE-1 gives the same IQ, even the noise, as my XT-2 and XH-2 at least up to ISO 6400. Maybe only the dynamic range is better in the newer sensors.
