The Fujifilm X-H2 High ISO Noise vs the X-T2
Yidahoo
Yidahoo Regular Member • Posts: 468
I have put together an entirely unscientific comparison of high ISO noise on the Fuji X-H2 vs the much older X-T2.
Check out my Youtube Channel for photography/travel based videos.
https://www.youtube.com/JasonRowPhotography
'Travel is the antidote to racism, bigotry and prejudice' Mark Twain
 Yidahoo's gear list:Yidahoo's gear list
Panasonic Lumix DMC-G7 Fujifilm X-T2 Fujifilm X-T4 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +5 more
Fujifilm X-H2 Fujifilm X-T2
Nebell
Nebell Regular Member • Posts: 425
Re: The Fujifilm X-H2 High ISO Noise vs the X-T2
I'm too early to the party, it's in 360p. Gotta wait for HD processing.
Anyway, while it's informative, if ISO performance is important, then FF is an option. There are plenty of FF cameras that are at the same price as X-H2.
It's not the same in case of FF cameras. If you want to go up your option is medium format which is both a lot more expensive and limiting.
 Nebell's gear list:Nebell's gear list
Sony a7R IV Fujifilm X-H2S Fujifilm XF 50-140mm F2.8 Sony FE 135mm F1.8 GM Sigma 24-70 F2.8 DG DN
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
Before selling, try this...
It's easy for someone to recommend changing or upgrading cameras, and that might solve the problem, but at a significant expense. Before taking that route, I would recommend that the OP try something like Topaz DeNoise (one of a number of good NR solutions out there). I've had really great results in reducing noise while still retaining fine detail. I would certainly recommend taking that route first rather than simply selling existing gear at a loss and then reinvesting in expensive (and likely more bulky) gear. If that doesn't meet the OP's needs, then selling gear and upgrading always remains as an alternative.
Jerry-Astro
Fuji Forum co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
casey1823
casey1823 Senior Member • Posts: 1,858
9
I find all these threads about non-scientific noise comparisons funny. Most of today's cameras, full frame, or crop sensors produce some of the best high-ISO photos. Add the noise reduction software available and IMO noise is a non-issue.
Again, just my opinion.
 casey1823's gear list:casey1823's gear list
Fujifilm XF 200mm F2 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 50-140mm F2.8 Fujifilm XF 16mm F1.4 R WR +6 more
Jared Willson Senior Member • Posts: 1,504
Thanks for posting the video. I know that comparisons of this type can be more time consuming than one expects, and they are very difficult to make “fare”. That being said, I do have a few concerns:
  • If you are correct that the X-T2 is applying noise reduction at higher ISO’s even to raw files, then the comparison loses most of its usefulness at those ISO’s.
  • Since the two cameras have different megapixel counts, each pixel in the X-H2 file will necessarily receive less light for a given exposure, and will therefore be noisier even if read noise is as well controlled or better controlled in the new sensor. I’d be more interested, just for comparison purposes, in how the two look if you “trade” the higher resolution in the X-H2 for improved SNR by down-sampling to the same image size. That would seem like a better starting point for this comparison. Instead of the X-H2 files being more detailed and also more noisy, they would have similar detail. What would the noise look like then? Just zooming in farther on the X-T2 files isn’t the same.
Again, thanks for posting this. Always interesting to see how camera performance evolves over generations.
 Jared Willson's gear list:Jared Willson's gear list
Leica Q2 Hasselblad X1D II 50C Leica SL2 Leica SL 90-280mm F2.8–4 Hasselblad XCD 30mm F3.5 +8 more
Night Pixel
Night Pixel Contributing Member • Posts: 976
DxO PhotoLab 6 Elite Deep Prime takes care of any unwanted noise in the X-H2. Soon DxO will make Deep Prime XD available for Fujifilm cameras and noise elimination will go to a new level.
I use Deep Prime XD on my "1-inch sensor" Sony RX10M4 with really amazing results. I am sure DxO will do the same with X-Trans.
**** REDACTED ****
 Night Pixel's gear list:Night Pixel's gear list
Sony RX10 IV Fujifilm X100V Fujifilm X-H2 Fujifilm XF 80mm F2.8 Macro Tamron 150-500mm F5-6.7 Di III VC VXD +4 more
yomimoi Forum Member • Posts: 50
Re: Before selling, try this...
I tried Topaz Denoise on the 6400 ISO RAW files from the XH2 in the studio comparison scene here and, while it made the image better, I couldn't for the life of me make it look as clean or detailed as the non-processed file from the A7III. If anyone can do it and post the results here and, more importantly, explain how they did it, that'd be awesome.
Maybe I'm not proficient with the denoising tools yet, but I think people are putting too much hope in their ability to make high ISO files from this new sensor much better. From what I've seen so far, anything above ISO 4000-5000 is worse than what the X-T2 produced, let alone the A7III. And these are 5-6 years old sensors. I can't help but think these new sensors are rather disappointing for low-light photography.
Jerry-astro
If you are seriously expecting a crop format sensor to provide equivalent IQ or noise as compared to a FF sensor, then you’re probably kidding yourself. While well applied NR can be a huge help in cleaning up a noisy image, while retaining decent detail, I would expect the results from a larger sensor to offer a better results… it’s simply a matter of physics. That said, I’ve used Topaz deNoise on some pretty noisy images and have found detail retention and NR to be excellent and more than usable, even for reasonably sized enlargements. However, your own criteria for “good enough” may be vastly different from mine or others.
Jerry-Astro
Fuji Forum co-Mod
Yidahoo
OP Yidahoo Regular Member • Posts: 468
Thanks for the comments. Personally high ISO noise is not an issue for me as I generally use longer shutter speed and a tripid. However, I had seen comment about people unhappy with Xh2's higher ISO so I thought it would be interesting to compared to an older and lower resolution sensor. Even ignoring the comparison, hopefully it does show potential purchasers what they can expect from higher ISOs on the X-H2
JNR
JNR Veteran Member • Posts: 4,652
Not my experience at all... But then again the fellow who made the video admits to not having a lot of experience with raw files, and he's using LR alone apparently.
I was a bit concerned initially with the XT-5 that high ISO noise pattern looked unusual and inconsistent (I don't shoot beyond 6400 ISO ever... and try to limit the setting to 3200 when possible). Once I knew how to re-arrange the NR, Threshold and Sharpening settings from default in Capture One, I found DR, detail and even noise was slightly better at high ISO - at least one-third of a stop improvement. From 125 to 500 ISO the difference is stark - probably close to a full stop better than the XT-2.
You do have to work a bit harder to get the best image quality just right with the 40mp sensors, and the ISO variables are somewhat greater shooting raw. For those shooting JPEG only, I'm also finding that the JPEG in-camera processing is far more capable with much less smearing. On the XT-2, even at max -4 NR (least amount possible), images from very good lenses showed softness. The XT-5 is much better - and I can back off the NR to -3 at 6400 and see good detail and proper NR you don't get with the XT-2.
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
I'm not, seriously or jokingly, but I keep reading that here from some people: "negligible difference", "you have to look very closely"... well, no.
I think the X-T2 at ISO 6400 was good enough in many (not all) circumstances. X-H2/X-T5 both look worse to me in every single high ISO sample I've been able to find. And there's not even that much more detail to make up for the increased noise. The only advantage is cropping ability. Not a minor one, but I think most users would have been happier with a better high ISO performance.
Of course in many cases an X-T2 sample is not available for comparison, as in DPR's studio scene, but after 6 years shooting with the X-T2 I think I have a pretty good grasp of its capabilities.
Then again, as you say, others may have vastly different criteria.
Interesting. I see from your signature that you still have your X-T2. Would you consider posting a couple of low-light, ISO 6400 comparison shots with the same lens mounted on both cameras?
MOD BobsYourUncle Veteran Member • Posts: 8,945
Bob aka BobsYourUncle
DPR Co-MOD - Fuji X Forum
 BobsYourUncle's gear list:BobsYourUncle's gear list
Fujifilm X-T30 Fujifilm GFX 50S II Fujifilm X-H2 Fujifilm GFX 100S Sony a1
Jerry-astro
As I mentioned, I’ve had plenty of success with NR on my X-H2s using Topaz deNoise.  Detail retention is excellent and the workflow is simple and very straightforward.  I can jump directly from LR into deNoise, then back to LR for any further editing.  If the end result or workflow doesn’t meet your own criteria, then you may have little choice but to move to FF or find another lower noise solution.
Jerry-Astro
Fuji Forum co-Mod
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
If I am going to do available light it will be with my Lecia Q2M.  I would not use an XH2.  After I got my Q2M, I would not even use my Pro3 for available light.  However, up to ISO 1600 to 3200, my wife's XH2 is better than my XPro3 for noise performance.  It is significantly better when I down sample the XH2 file down to the size of the XPro3 in the processed image.  The read noise it todays cameras has practically eliminated by the current state of the art in the CMOS circuits in Sony's chips.  The limiting factor in SNR is shot noise - not read noise.  There are plenty of charts on the Internet that documents this.
While it pains me to admit it - Jerry is absolutely right.    The current smart noise reduction SW be it Topaz or DXO do an incredible job of integrating out noise while maintaining high frequency details.  If I do pick up a XPro4 and I will pick up a version of the latest DXO Pure Raw in case I takes some available light shots in case I want to address noise, although I like my available light shots pretty raw and emotional in which case I might just add grain to the noise.
One of the issues I see with most of the comparisons is they are apples to oranges. You can't compare a 26 MP at 100% crop on an emissive display with a 100% crop of a 40 MP sensor.  If you do the same scene of the 40 MP sensor is magnified by a factor or 116%.  So there is an enlargement ratio of the 100% crop of the 40 MP over the 26.  That is if the linear length of the 26 MP is 1 unit, the 40 MP is 1.16 units.  In order to make a valid comparison, the 40 MP image should be down sampled to the 26 MP size using a low pass filter.  This of course would not only help eliminate noise it would eliminate the details at spacial frequencies above the capability of the 26 MP sensor to capture.
"The winds of heaven is that which blows between a horse's ears," Bedouin Proverb
__
Truman
www.tprevattimages.com
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
Jerry-astro
I may have to get your comment above etched into a plaque.  I can only conclude you’re getting a bit soft, Truman.
Jerry-Astro
Fuji Forum co-Mod
sticks and stones
sticks and stones Veteran Member • Posts: 4,098
If I listened to the "expert" opinions on this forum ...
... I would've sold or thrown my X-H2 into a river a long time ago. I'd never even consider a Fuji camera either lol.
Base ISO is where I live so ISO 6400+ comparisons are useless to me. I crack ISO 3200 on my X-H2 occasionally (without any drama - using PS and ACR). ISO 200 on the X-T2 is better than the X-H2 (as it's base ISO for the X-T2) - but the X-H2 is way better at my use case ISOs of 125, 64 and 500. Check out the Bob the Mod's graph of ISO vs. noise.
The X-H2 outperforms my X-T3s ... that replaced my XT-2s ... that replaced my X-P1 - so you're pushing edge case behavior that doesn't live in my real world of photography - shrug.
Each Fuji sensor iteration has pushed me to change my shooting and processing strategies and I'm cool with the X-H2. Obviously, you're not - so my advice is to find a camera that works best for you. That's my advice to anyone choosing a modern digital camera. If ISO 6400 behavior is your jam, then you should find the best cam behavior at that light level.
Good light and good pics to you!
Ed
“L’exactitude n’est pas la vérité”
H. Matisse
Did you have to say that!!!!!  It's hard enough dealing with him as a co-MOD......now it's going to be impossible!!!! 🤣🤣🤣
Jerry-astro
… searching for the “Ban the co-Mod button.” It’s gotta be here somewhere…….
Jerry-Astro
Fuji Forum co-Mod
sticks and stones
If only - lol
H. Matisse
