Considering X-S10
bobnn Junior Member • Posts: 46
Considering X-S10
Currently have a Sony rx100m5. That's not bad, but if I'm in a hurry, the fiddliy button/dial menu navigation is difficult, especially in the custom Fn menu. I also would like a larger sensor.
So I'm looking at the X-S10.I like the features, especially IBIS and the touchscreen Q menu.
I have some questions:
How is the navigation of menus with the joystick? Is it easy to push when you meant to tilt?
The 18-55 f 2.8-4 lens that often comes as a kit lens seems like a very good set of specs, at least compared to typical kit lenses from other brands (which are dark as heck). How is that lens, optically speaking?
Also, how high can the ISO go before things get contrasty and colors get blotchy? I know noise is easily fixed in post these days.
Any other comments are welcome.
Fujifilm X10 Fujifilm X-S1
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Re: Considering X-S10
Navigation is easy - it would be very hard to mix up tilt and push
For both of these you are better looking at the many reviews online.
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
piphoton Junior Member • Posts: 29
The camera is a joy to use. The results are phenomenal.
I've never thought about this. So it must mean that it has never been a problem for me.
I also bought it with that kit lens. It is the lens I use the least. Not really something wrong and I have taken a lot of good photo's with it. I just prefer some other lenses more. The sigma 30 when I'm documenting life, the xc 50-230 when I'm hicking, the xf 100-400 when I'm after wildlife.
Those are preferences and preferences might change with more use in the future.
Others will be able to comment beter on the numbers. But often I lower the noise reduction in a dark environment. Just so that the photo would give a vibe. I would need to experiment more with a higher noise reduction to answer this.
It is a small camera with a very good grip. Even with the good grip, I added a smallrig bottom plate to make it a bit larger. It feels very durable. I bought mine at release and it is still in pristine condition and I use it a lot outside in the elements. I would buy it again.
 piphoton's gear list:piphoton's gear list
Fujifilm XF10 Fujifilm X-A7 Fujifilm X-S10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 16-50mm F3.5-5.6 II +7 more
a_c_skinner Forum Pro • Posts: 13,047
The S10 gets good reviews. I've not used it, but if the menus are like my Fujis are/were you can easily drop the few things you use regularly into a my menu group. The X-S20 seems just round the corner, so you may find bargains if you hang on.
The 18-55 gets good reviews. I use the 16-55 but I spent a lot of time comparing good scientifc reviews and came to the conclusion the 18-55 (and now the 16-80) are not as good but are jolly nearly. I doubt you'll be disappointed. Actually it is difficult to be disappointed with most of the Fuji lenses.
Here is dear ofd Ken's set of high ISO images, but you could equally look at X-E4, X-T3 or 4 or X-Pro3 reviews as they will all be pretty much the same.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
OP bobnn Junior Member • Posts: 46
piphoton wrote:
bobnn wrote: The 18-55 f 2.8-4 lens that often comes as a kit lens seems like a very good set of specs, at least compared to typical kit lenses from other brands (which are dark as heck). How is that lens, optically speaking?
I actually like that range if focal lenghs for what I do. Lots of cameras come with kit lenses in that range of focal lengths, but with F3.5-6.3, yuk.  The fujifilm is refreshing in that regard.
Very reassuring. Thanks!  I suspect I won't need the smallrig on this, i have hands on the small side.
MiroLx Junior Member • Posts: 33
Hello.
I have no problem with it.
I bought XS-10 with 15-45 which is not bad (if you can live with PZ), but  buying now I will choose18-55. Lens is also much cheaper as kit.
I use 1600 ISO out of camera. Higher ISO (max. 6400) need postprocessing. Colors are very good at all settings IMHO.
 MiroLx's gear list:MiroLx's gear list
Nikon D500
WeirdSheep Regular Member • Posts: 220
That can happen, more in playback in my experience, but it's not a problem in general.
I didn't get a good copy so wasn't impressed, others love it, obviously copy variation is a thing with most lenses. I wouldn't worry too much about the fact it's a bit faster than most kit lenses. The XC15-45mm maybe slower, but it's wider, very sharp wide open and I can handhold it down to 1/3 second at the wide end, and 1/6 at the long end. You're not going to get much in the way of bokeh with either of these lenses (except for close up shooting at the long end), when you do get it the 15-45mm isn't bad either, so for the price and size it's definitely worth consideration.
Because of IBIS/OIS I don't worry about high ISO with this camera, ISO 6400 is perfectly fine, much higher in black and white, it always depends on display size, but 26mp gives you plenty of wiggle room for prints.
I always say it but the X-S10 is just an intuitive and fun camera to shoot with, once you set it up to your own preferences it's a joy to use. There is a certain amount of camera snobbery around aperture rings and dials and stuff in the Fuji community IMHO, however, no camera is faster and easier to shoot with than the X-S10 in my experience, it has everything I need without being too fussy and overloaded with bells and whistles I don't need. About the only thing I'd change is the fully articulating screen, but even that has a bonus in that it protects itself, I just prefer a tilt out screen, but it's no biggie. It's basically an X-T4 without the window dressing, but with a better grip and in a smaller lighter package, what's not to like?
1000DTL Forum Member • Posts: 94
I will echo others comments.  The X-S10 really fits my hands well.  It is smaller than some mFT cameras.  I added a Smallrig L-bracket to mine. I do wish there was a function button or two but you can get by with the ISO and Q button/menu.  The joystick works well. The X-S10 has a simpler shutter than the more expensive models.  No electronic front curtain.  Some users have complained about shutter shock at certain shutter speeds.  I use it mainly in electronic shutter mode unless I need to use flash.
I have an 18-55mm but it doesn’t see much use now after I got the 16-80mm.  I keep it if I really want to go small.
You might want to wait a few months, rumors are an update to the X-S10 is coming this spring.
Alan Sh Senior Member • Posts: 2,774
Interesting. I have small hands, but I couldn't get on with the X-S10. I found using the joystick for everything very uncomfortable and, with wide lenses, there wasn't much of a gap for my fingers.
I would suggest you need to try it before you purchase.
 Alan Sh's gear list:Alan Sh's gear list
Canon EF-M 55-200mm f/4.5-6.3 IS STM Panasonic Lumix DMC-ZS40 (TZ60) Canon EOS M100 Canon EOS M50 Fujifilm X-T5 +13 more
wantfastcars Regular Member • Posts: 206
The X-S10's IBIS is truly incredible, and it's not even the best Fuji has on offer. I've managed half-second shots handheld at wider angles (<30mm equiv.) and longer focal lengths (like 30-50mm equiv.) in the 1/5-1/3 range with a bit of luck and a couple tries. I personally never use the touch screen, but I also rarely use the LCD in general.
Not really, no. I'm not sure if I've ever accidentally "clicked" when I've meant to tilt.
For this, I can't speak - I purchased a kit that came with the 15-45 and 50-230. The 50-230 is incredible for the money, and the 15-45 is a good lens but I bounced off the power zoom pretty hard and replaced it with the 16-80. The 18-55 generally seems to be regarded as a lens with pretty extreme copy variance, where if you have a good one it's shockingly good for a kit lens but just as many, if not more, soft lenses are out there.
Personally, the X-S10 is my first "real" camera - before this I had a reasonably nice Panasonic point-and-shoot, but it never really felt like it was doing much more than I'd use my smartphone for besides slightly higher resolution and much better optical zoom. You already have a real camera, so you might not see as much of a difference, but the X-S10 made me like photography for more than just the "I was here" style vacation photos. I also find it extremely comfortable to hold - much moreso than the X-T5 or X-H2 even, and I'd say I have medium-large hands for someone born male. Those two make my hands sore even after just handling them in the store for a few minutes, while I'll happily shoot all day on my X-S10 without feeling any cramps. Do try it in a store if you can, though! The camera's physical handling is just as important as the actual imaging quality if you plan to actually hold it much.
The only things I wish is that it had a slightly better EVF and weather resistance. Maybe the rumored X-S20 will improve on it... either way, the X-S10 is incredible value for money in terms of how much camera you get for how little you're paying. Heck, it even has a built-in flash! No idea if it's any good, I've literally never used it, but hey, the "higher tier" models don't have one!
 wantfastcars's gear list:wantfastcars's gear list
Fujifilm X-S10 Fujifilm 50-230mm II Fujifilm 15-45mm F3.5-5.6 OIS PZ Fujifilm XF 16-80mm F4 Fujifilm XF 70-300 F4-5.6 R LM OIS WR +8 more
Another question: do I turn off Ibis and ois if the camera is on a tripod?
Yeah, that's the idea I got after looking at a lot of cameras. That's why I'm considering this one. Looked at Sony ZV-E10, a6100, nikon z50 and zfc, some others I can't remember, some other fujis - this is where I landed.
If the Sonys had a sane user interface, I might have gone with one of them. The x-s10 is on th edge, but the touch interface of the q menu saved it, along with the other features. The IBIS pushed it up above most of the others.
I've never bothered and never noticed any difference. One other thing you'll probably like, if you like touch screens, is that you can set four different functions and swipe left/right/up and down on the screen to access them individually. I don't personally use it but it works quite well for those that like that sort of thing.
To me, IBIS/OIS makes it less likely to need high ISO. But if the issue is anything other than hand shakiness, I may still need to get to higher ISO, such as 6400. I understand you to be saying that ISO 6400 looks ok, just wanted to be sure I understand correctly. Someone else said they'd need to post-process that, and that's ok too. Everyone is different.
Yeah, it's like 4 more buttons, I'll take it.
AlexBG Forum Member • Posts: 57
I had the original rx100 and get what you mean about the fiddly menus. My XS10 I can't remember the last time I went into the actual menus. I have the buttons on the back, the few there are, customised to what I need and then the Q menu is easy to access.
Ideal one handed camera, I have the 16-80 which gives me all the reach I need, the 18-55 f2.8-4 is a lovely lens. If mine had come with that then I would have no complaints.
Only 2 negatives for me, one of the dials is not customisable, it does the film presets which I don't use and the screen I would prefer the one from the XT4 but these are personal preferences.
Someone did mention the XS20 coming out soon, you can probably work out the specs the way that Fuji works. Just up to you if you need the camera now or happy to wait and see.
 AlexBG's gear list:AlexBG's gear list
Fujifilm X-S10
xtabber Forum Member • Posts: 78
I no longer have an X-S10, but I'm guessing you are referring to the Fn dial, which defaults to Film Sims. That dial certainly can be customized to do many other things:
https://fujifilm-dsc.com/en-int/manual/x-s10/shortcuts/function_buttons/#function_dial
 xtabber's gear list:xtabber's gear list
Fujifilm X100V Fujifilm X-H2S Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 35mm F2 R WR +7 more
For me it's ok, but it always depends on your display requirements and personal taste. It also depends on the type of lighting your shooting in, the darker the environment the more noise becomes apparent. I might clean up an ISO6400 shot a bit in DXO, or I might not, it varies from image to image. I very rarely need to go that high but if I do I don't worry about it. I find the X-trans sensor maintains colour pretty well at higher ISO's. I don't find the difference between Fuji APS-C and FF high ISO enough for me to worry about for my uses. That being said, I see FF as any kind of holy grail either, I've shot both plenty and Fuji APS-C is the sweet spot for me.
It can indeed, I can also verify this.
Is this evident if you're looking through it at the shop? How do you make it more evident and recognizable? I have no experience in evaluating lenses.
