Excessive process time for Canon DPP and R6 Mark II cr3 files
Started 1 month ago | Discussions
Duane Burleson Regular Member • Posts: 128
I am using a Canon R6 Mark II, a MacBook Pro, OS X 10.15.7 (Catalina) and Digital Photo Professional 4.17. It takes 14 seconds to process a 1DX cr2 file. It takes around 3 minutes to process a R6 Mark II cr3 file.
Is anyone else getting these excessive times for R6 Mark II cr3 files??
Duane
Canon EOS R6
davel33 Senior Member • Posts: 2,974
Re: Excessive process time for Canon DPP and R6 Mark II cr3 files
Duane
Maybe you need a bit more HP.
I use a Intel I7 4 core @ 4 ghz
also defrag your drives.
I have no problems with speed.
** thats from 2014 so a bit old.
"Just one more Lens, I promise....."
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
rp2waiter Regular Member • Posts: 128
I'm shooting compressed CR3's and they are taking an awful lot longer than my 5Diii raws. Using an old Dell too, which doesn't help but still.
Lisa Horton
Lisa Horton Contributing Member • Posts: 693
I've noticed that DPP 4.17 is noticeably slower than DPP 4.10. Which is weird, I've never experienced that before that I remember.  Not sure if it makes a difference that I'm on Windows.
 Lisa Horton's gear list:Lisa Horton's gear list
Canon EOS RP Canon EOS R10 Canon EF 24-105mm f/4L IS USM Canon PowerShot SX10 IS Canon EF 85mm F1.8 USM +6 more
MarshallG
MarshallG Veteran Member • Posts: 8,951
It’s horrifically slow on Macs. I don’t think Canon recompiled for the M1processors.
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
Bionic963 Contributing Member • Posts: 743
I have one of the fastest laptops available. I9-12950HX, 64GB Ram, Raid 0 M2 SSD's, RTX 3080TI GPU, etc...
DPP is still super slow!!
In my experience no other raw converter can get the colors as accurate as DPP using the Fine Detail picture style...  I've tried custom profiles in LR but they still are not as accurate.  So I am currently stuck using DPP when I need to actually convert a photo.
I wish Canon would update DPP to be able use GPU's.
Brook
MarshallG
OR… give the doggone source code out to Adobe, DxO and other companies who suppprt their customers
Canon has to be working on doing something about DPP rendering inefficiencies!!  I can't believe that they are making all these new cameras, lenses, and raw files that support all the quality enhancing software processing tools, like DLO, ALO, Adj face lighting, Clarity, etc with out addressing the elephant in the room!  The software is super slow!!!  Any day now, they are going to be releasing DPP v 5 that will be GPU optimized, will operate 10X faster, and have even more AI tools!
I hope...
Brook
butterflyman Regular Member • Posts: 156
I have given up using DPP for anything but a superficial going over before sending them to another software to use.  I tried it, took over 1 minute to convert to a jpg and almost 2 minutes to convert to tiff.  When I used Nikon equipment and software, to convert to either jpg of tiff took all of about 10 seconds at the most.  I am running a MacBook pro with Big Sur 11.7 with an i7 chip quad core, 16GB ram.  Just cannot put up with something so poorly designed.
