Pick up the EF-S 24mm f2.8 lens?
StrugglingforLight Regular Member • Posts: 126
I don't see it mentioned often. Which of course makes sense with the EF-M 22mm f2 and EF 24mm f2.8 IS in play. I eliminated the native EF-M 22mm because I prefer closer to the 40mm to 50mm equivalent. The EF IS version is still an option but think I'd prefer the smaller size of the EF-S on my M200.
What are some pros and cons of this lens compared to the more popular EF 24mm F2.8 IS? Well other than the obvious lack of IS.
Thank you.
thunder storm Forum Pro • Posts: 10,139
Re: Pick up the EF-S 24mm f2.8 lens?
Thank you.
On a crop sensor the ef-s lens has more contrast wide open and maybe even a tad more sharpness. The EF lens has faster AF.
Another obvious difference: the EF lens is a full frame lens covering a full frame sensor with not a whole lot of distortion. There's no RF lens providing this. This could be valuable when adding a full frame camera to the kit, especially because some RF zooms don't cover the 24mm focal length very well.
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
wlderdude Junior Member • Posts: 28
5
I'm sorry, but on an M200 sized body, I can't think of any reason to run that lens.  The 22mm is faster, focuses better, ought to be at least as sharp, and is much more compact.  The only thing the M200 does better than other camera bodies is be small, and it does it extremely well.  The 22mm pancake is what makes that body awesome.
The little 24mm that is nearly the size of a camera body cap only works with that clunky and heavy EF-M adapter that undoes its smallness.
Perhaps it would be a good fit for an M6 ii that is being run primarily with EF and EF-S lenses.  But the M200 would not fit that role well as it is really too small to wield bigger glass.
If you haven't tried the EF-M 22mm pancake or the 32mm 1.4, you really should.
The ef-s 24mm on my M100 works fine. The 22mm is smaller, but that doesn't make the 24mm big. The T-stop of the 22mm is really poor. The vignetting is crazy heavy wide open. The 24mm is also better for landscapes, as there's sharpness across the frame at f/5.6.
MyM6II Senior Member • Posts: 2,424
+1 . I have two copies of that lens. One of them is "glued" to my M200. The other one is always with me if I take one of my M6II's. It is either mounted or in my pocket.  It is so small and light, so no reason to not have it with me. 😀
+2
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
OP StrugglingforLight Regular Member • Posts: 126
Thank you.
Your post makes the decision even harder. It has me leaning slightly towards the EF now though. How good is the IS on the EF?
For the other replies like I mentioned the EF-M 22mm is already ruled out.
Sittatunga Veteran Member • Posts: 5,406
Thank you.
Have you seen the 28mm f/2.8 IS macro? Slightly shorter and 100g lighter than the EF-S lens if you include the adapter, 45mm full-frame equivalent, very sharp with up to 1.2x life size macro. It's about the only non-L lens to come with a lens hood, and if you unscrew that it uncovers the built in lighting that lets you get in close enough to use that magnification ratio.  Definitely worth a look.
Thank you.
Sorry
It has me leaning more towards the EF now though. How good is the IS on the EF?
1/10th of a second is doable on a 24Mp crop sensor.
Thank you.
that one is f/3.5
Thank you.
that one is f/3.5
It is, I blame the autocorrupt.  Still a fine standard lens though.
nnowak Veteran Member • Posts: 9,074
If you prefer the 40-50mm equivalent field of view, is there a particular reason you are excluding the Sigma 30mm f/1.4 and Canon 32mm f/1.4 from your consideration?  A 24mm lens only gets you to 38mm equivalent.
Thank you.
The EF adapter adds 100 grams (with tripod foot removed) and 26mm to the length of a lens.  Even with the tiny EF-S 24mm, the EF adapter adds a considerable amount of bulk to the overall package and saves nothing over the much better 30mm f/1.4 and 32mm f/1.4.  If your budget is tight, you could also consider the similarly sized Viltrox 33mm f/1.4 in EF-M mount.
MAC Forum Pro • Posts: 18,487
Thank you.
I have both the 24 IS and 24 stm
I think you will be better off with a combo of 11-22 + 32
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
geru Senior Member • Posts: 1,409
I have both of those lenses: Samples from my gallery. They produce a decent photograph but I must say I haven't used either since these were taken. In fact I haven't used any EF or EF-s lenses in over a year. I'm getting ready to sell these and others locally. All the lenses I use are EF-M  mount, Sigma 30mm, Sigma 56 mm, EF-M 15-45, EF-M f/2 22mm, and EF-M 55-200 which I don't use much. I got tired of having to mount the lens to the adapter and then to the camera, I was always hunting for the adapter in my bag. I always felt that the EF glass and lens made the camera unbalanced and often heavy.
24mm
40mm
 geru's gear list:geru's gear list
Canon EF 85mm F1.8 USM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EOS M50 Canon EOS M6 II Canon EF 40mm f/2.8 STM +5 more
trungtran Senior Member • Posts: 1,747
It's only 100 bucks at Canon Direct for a refurb. Personally I wouldn't buy any more M gear.
Like the 40mm 2.8, it doesn't have a bayonet mount for a hood. You have to rely on filter threads.
The EF lens will give you options to use on FF in future. EF-S you be limited to crop sensors.
 trungtran's gear list:trungtran's gear list
Olympus OM-D E-M10 Sony a7 II Canon EOS M6
