Go-to lenses for event photography
dwmcreative Forum Member • Posts: 73
Hey everyone,
After years of taking photos for both fun and at my job (I do marketing at a private school), I finally am succumbing to a request of a friend to take photos at a parents 70th birthday party. It's at a restaurant in a smaller party room so it's low stakes (I wouldn't have said yes to a wedding at this point in my photography career!)
My question. I have a Fuji XH2s. I own a 90mm f2, 23mm f2, 18-55 f2.8.
I'm debating buying a newer Fuji lens for this event to capture moments better in low light, what should I be considering?
FUJIFILM XF 56mm f/1.2 R WR Lens
FUJIFILM XF 35mm f/1.4 R WR Lens
Also for group family shots what should I be using?
Finally, do event photographers use an external flash? I always hate the look of it but I'm thinking of getting one just in case of extreme low light.
Thanks in advance for any tips,
Sincerely,
Daniel
 dwmcreative's gear list:dwmcreative's gear list
Fujifilm X100V Fujifilm X-H2S Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 56mm F1.2 R +3 more
Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R APD Fujifilm X-H2S
Morris0
Morris0 Forum Pro • Posts: 32,181
Re: Go-to lenses for event photography
dwmcreative wrote:
Hey everyone,
Sincerely,
Daniel
Hi Daniel,
In the small amount of event photography I've done I've found the versatility of zooms to allow me to grab natural moments and for this sometimes I need reach.  I would spend most of the time with the 18-55 f2.8 and also add a 50-150 f2.8 and if possible a second body so I could change from one to the other quickly.  If you want to do some posed portraits then the 35mm f1.4 and 56mm f1.2 would come along and be chosen based on available space.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Erik Baumgartner Senior Member • Posts: 6,894
Nothing wrong with fast primes (I like a 23/56mm combo on two bodies - I hate swapping lenses), but unless it’s really dark, my go-tos are the 16-55 and 50-140 f/2.8 zooms. They’re both exceptionally sharp and excellent performers wide open at f/2.8 - which is usually plenty fast enough, and with apertures much wider than that you will often run into DOF issues in a group setting anyway.
While f/2.8 is usually fine, f4 is often not, and 18mm isn’t often wide enough for my liking either, so the 18-55 f/2.8-f/4 might “work”, but wouldn’t be my first choice.
Complementing your 23 with a 56 would be fine, but unless you have a second body, that will mean swapping lenses and significantly less versatility (IMO). FWIW, I shot my father in law’s 80th birthday party in a similar setting to yours with just my 16-55 without any issues. I hate the on-camera flash look with a passion and haven’t shot that way in over a decade now.
As far a group shot goes, I would assemble everyone in as shallow (and reasonably narrow) an arrangement as possible and back up as much as you can to minimize perspective distortion at the edges of the frame and maximize DOF.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
baobob
baobob Forum Pro • Posts: 18,248
I would add a WA.  Fo events i use also the  xf 10-24
I also use a Godox flash which can bounce plus a small soft box adapted on its head Well set the combo with the Goxo fives a rendition quite close to a studio light.
A sample :
and how it set the combo
Note that the head of the flash is turned in reverse position with the white screen in front of the subject. Adjusting  asmall softbox is even better, then setting the angle of the head a bit  downward to prevent shadow from the nose
Usinf ES no noise, easy to get candid portraits
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
photolando Veteran Member • Posts: 3,423
6
All I do is corporate event work.  And do it full time.  I use the 16-55 2.8 and the 50-140 2.8.  Like weddings, things happen pretty fast so I don't use primes.  I also use a Godox V1 flash. I's highly recommend having some type fo flash just in case.
Don't be afraid of high ISO.  Remember, this is an event.  It's not a fine portrait.  Which I also do.  However, NONE of the event photos will ever go larger than an 8x10.  And probably mostly viewed on someone's phone.  At that size, you won't even see noise.
I shoot at ISO 3200 and 6400 all the time with very high end clients.  Not one had ever complained about quality.
Mike
 photolando's gear list:photolando's gear list
Fujifilm X-H1 Fujifilm X-T3 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 +3 more
OP dwmcreative Forum Member • Posts: 73
Thanks for this. I guess it may not be necessary to buy a prime with a crazy aperture because I'll be taking a lot of group photos and f1.2 or f1.4 is too narrow!
I'm going to really need to practice with my flash though because I have a godox that I've used once!
LittleLew Regular Member • Posts: 269
Couldn't agree more.
I shot events with FF Sony 24-70 and 70=200 but always with two bodies.
Changing lenses is a losing proposition for all obvious reasons.
Lew
Always open to c/c.
(I may not agree but I will be agreeable.)
Lew Lorton
I don't have two bodies, but I have an XH2s and a x100v so I suppose I could maybe make use of the 100v in some situations
yayatosorus Senior Member • Posts: 2,021
dwmcreative wrote:
Hey everyone,
I believe you've got a great kit already, that's more than capable of delivering in this sort of scenario.
Your 23mm should work great in this scenario and I'd recommend sticking with that. You could look into renting an 18mm f/1.4. It's a gem of a lens and is especially good for social events in small venues. The 16mm f/1.4 is also great if you need to go a bit wider.
The 90mm may be a bit tight for a small party room, so perhaps you look for something around the 50mm mark. Both the 50mm f/2 and 56mm f/1.2 are great choices.
The 16-55 f/2.8 is a great choice if you're comfortable with using zooms and know your way around the various focal lengths.
I'm not sure how much experience you have at shooting social events, but if you're having doubts, I suggest resorting to primes. Makes you think more about the composition and gives you peace of mind if things get hectic.
It depends what sort of working space you will have available. The longer the better, but keep an eye on your aperture, you want to avoid blurring people out by mistake.
Yes, flash is your friend. You can just point your flash upwards towards the ceiling and you'll get great fill flash or get a bounce accessory, like a MagBounce.
The more you know about the venue beforehand, the better. Perhaps you could try to get there a bit early and have time to set a custom white balance, get a better idea of the particularities of the venue etc.
If the lighting ends up being all over the place, you can always switch your camera to Acros or Monochrome, it helps with focusing on the composition.
The X-H2s is a beast of a camera, so you'll be fine. Keep an eye on your shutter speed and your highlights. Exposure comp is your friend!
Sincerely,
Daniel
 yayatosorus's gear list:yayatosorus's gear list
Fujifilm X-H1 Fujifilm XF 35mm F2 R WR
sluggy_warrior Veteran Member • Posts: 3,204
Same here, except it's Tamron 17-70/2.8 instead of Fuji 16-55/2.8 (since I don't have IBIS).
My strategy is spray-and-pray, as I don't want to miss important moments, and thus have to be ready for them. Sometimes I got waved over suddenly for a quick group shot of the speakers without prior notice. Swapping lenses is a luxury that I can't afford. Shooting JPG is also a luxury since I need some room for errors (white balance, exposure, ...)
The 17-70 and 50-140 is the ultimate combo for most indoor and outdoor events: tournament, conference, theater, party, ... The X-T2 and X-T20 share the same sensor making it much easier to process in post.
If I have only one body, I'd go with the 17-70/2.8 or 16-55/2.8. I shot with one body for about 2 years, it works but required moving around more often (sometimes isn't possible, e.g. theater). Jumped on a really good deal on a used X-T2 on craiglist, couldn't be happier.
And yes, I have two Godox flashes (one Li-ion and one AA), paired with a Godox X1F transmitter. This allows me to move around freely while bouncing the flashes off ceiling and wall for diffused look.
For noise, nind-denoise is a very promising tool. I've been using it the past few months, ISO6400 looks like ISO200. Also don't forget the recent discussionon ISO-invariance
A few shots with the two lenses at a recent band performance.
MOD BobsYourUncle Veteran Member • Posts: 8,945
Good Advice +
My setup for the event would be very similar to photolando.  If it is a small room you probably won't need the reach the 50-140 would give.  My goto lens in that situation would be the 16-55/2.8 and not have to remove it.  In a small room an on-camera flash may be best bounced to avoid harsh light.  If I did this kind of small event I would put a diffuser (round one included in the Godox V1 or get a Stofen-like one to put on the TT-XXX) on, and experiment with angles.  Try straight up and adjust your flash EC.  If you use flash, Flash EC is best by assigning it to a function button or one of the selections in the "Q" menu.  I'm more as traditionalist and don't use Auto-ISO as much as others.
Best if you can scope the location out beforehand and have someone with you as a "model" so you can be better prepared for the kinds of images you'd be taking.  Rarely have I ever taken on a job and not spent time at the location at the approximate time during the day the event would be taking place.
Bring the X100V with you but you'll probably not need it.  BTW, and your technique may differ, but for awhile I have put my cam on AF-C at events because people and I move constantly and I want to make sure I have good focus.  Your newer cam should be able to do that quite well.
Good luck!
Bob aka BobsYourUncle
DPR Co-MOD - Fuji X Forum
 BobsYourUncle's gear list:BobsYourUncle's gear list
Fujifilm X-T30 Fujifilm GFX 50S II Fujifilm X-H2 Fujifilm GFX 100S Sony a1
baobob
For Godox see my post. Add a Pixco small soft box it is even better
and one more comment about a strobe.
Any diffuser is good...... AND,  if you do not have an X-H2S, change your shutter to mechanical or one of the combos with mechanical. If you are not "fluent" in flash, and you are in a time crunch... if your cam is in ES, the flash is greyed out for good reason.
Note:  bolded text was changed to correct an inaccuracy.
baobob
The Godox flash for event, creating a simili studio soft light
Like that
Note that I have turne the head 180° in my direction the photographer
This config implies that there is a ceiling not too far  (3-7m) from the flash if not I just shoot directly with adapetd angles in the direction of the subject
The Pixco soft box gives a wide uniform not harsh light BTW The Pixco collapses (to get completely flat) it is light and is easy to carry.
The camera is set in M mode ES adjusting SS at quite a high value if peiople (dancers) are moving fast, aperture as desired. Combining aperture, ISO and power of flash allows to combine ambiant light and flash, useful when there are colored lights.
baobob
Re: and one more comment about a strobe.
not at all with the XH2s I use ES all the time with my Godox 860 This is one great asset of the stracked sensor. I can use the flash at very very fast SS
baobob
Re: The Godox flash for event, creating a simili studio soft light
Soft light avoiding ugly shadow with my config
and combining ambiant light adjusting SS ISO aperture and power of the flash
and avoiding !
gsz Regular Member • Posts: 170
Sometimes I’m taking pictures during company events (10-80 people, meetings, receptions, small parties etc.) and the 35/1.4 and 56/1.2 combination (on X-T3) works well for me.
Yes, you will have to change lenses multiple times, but if you are not a pro but a participant who takes pictures (so there is “no pressure” to have picture of everyone/every moment) this could work very well (35/1.4 for larger groups, 56/1.2 for “candid” shots with small DOF etc.)
Indoors with low/tricky lighting I simply use manual mode, 1/125 sec,  mostly the largest aperture of the lens, auto ISO, shot in RAW, very careful with AF (mostly AF-C, sometimes eye detection, never focus lock+recompose)- yes, I need to spend time with postprocessing in C1Pro (what I really enjoy doing😀).
Flying Fijian Senior Member • Posts: 1,623
I have used the X100V with the wcl (18mm) paired with the old 35mm f1.4 in this kind of situations...great combo.
 Flying Fijian's gear list:Flying Fijian's gear list
Ricoh GR III Fujifilm X-E3 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R +13 more
I stand corrected.  Thanks
Fuji Maine Senior Member • Posts: 1,702
I'd like to take you in a completely different direction. The viltrox 13mm 1.4 is definitely worth considering if you're doing indoor stuff with groups. With regards to flash, I agree with you about regular on camera flash looking terrible. I don't even like it with a modifier to be honest with you. Off camera with a trigger and a modifier on the flash is going to give you your best result by a mile. The nice thing about going wider with the 13 mm is that you get the light intake of a fast lens without the depth of field issues. It is certainly its own look with a lens that wide but as far as utility goes and price point it's hard to beat. Also the nice thing is, if you do have to have the flash on the camera instead of off of it, that wider aspect ratio doesn't make flash look so terrible. I have finally embraced good noise reduction software as just part of the necessary workflow for APS-C cameras however I am certainly not in the "just crank up the ISO crowd". You can't escape the rule of garbage and garbage out. So because of that I would rather get as much light to the camera as I can rather than having to perform miracles in post.
