Bird/Wildlife Photographers: RAW vs. JPEG/HEIF
jhorse Veteran Member • Posts: 5,913
Re: Bird/Wildlife Photographers: RAW vs. JPEG/HEIF
aronimages wrote:
Well, after doing lots of thinking and tweaking RAW files, I came to a sad realization: the X-H1's buffer made the decision for me. I can't count the times I missed the shot, because the camera slowed down, or became unresponsive while clearing the buffer.
In other words, a JPEG image is better than no image at all. I might give RAW files another chance if I decide to upgrade my camera, but for now, it's a no-go for me.
Hi,  similar conclusion here. I take a lot of action photos of polo matches where the run of play extends over many seconds. For the last few years my XT4 was okay,  (set to RAW = Fine), but normally slowed in capturing action towards the end of a shooting sequence.
For reasons I'll not repeat here, I preferred the XT5 over the XH2/S and was aware upon purchase of the buffer limitation. In these situations, like you I shall probably use JPEG only when the season opens here in the UK in April.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
OP aronimages Forum Member • Posts: 53
2x 64GB SanDisk Extreme Pro SDXC UHS-II 300MB/s
lengyel aron images
http://aronimages.com/
 aronimages's gear list:aronimages's gear list
Fujifilm X-M1 Fujifilm X-H1 Fujifilm XF 27mm F2.8 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +5 more
Tim van der Leeuw Senior Member • Posts: 1,364
Those should clear the buffer at a reasonable speed so if that's not fast enough, I can quite well understand your need for smaller file sizes!
(Myself I never want to give up the flexibility of RAW files anymore, so I lowered the max burst speeds to get longer bursts, before I upgraded).
 Tim van der Leeuw's gear list:Tim van der Leeuw's gear list
Canon EOS M5 Fujifilm X-H1 Fujifilm X-T3 Fujifilm X-H2S Sigma 2x EX DG Tele Converter +17 more
