Is is possble ot remove Program name from EXIF of GPEGs made by DxO PhotoLab
Started Jan 30, 2023 | Questions
Pov2 Senior Member • Posts: 1,220
I use DxO PhotoLab 6 and there is an option to include none of the EXIF, IPTC, GPS coordinates etc. when saving JPEGs But when I choose "none" the file still contains "Program name" "DxO PhotoLab 6.2". I thought none meant none. Is there a way to remove that reference from the file properties. Sometime I use a very old program Exifer to strip EXIF from files but it didn't work to remove this reference. Is there an easy way to do it?
elIvarz Regular Member • Posts: 125
Re: Is is possble ot remove Program name from EXIF of GPEGs made by DxO PhotoLab
If not thousands of pictures, then you can right-click mouse on file, then > Properties > Details > Remove Properties and Personal Infomation.. There is possible choose, which one of properties info remove from file info. Also you can remove info about programm used to edit picture.
 elIvarz's gear list:elIvarz's gear list
Pentax K-50 Pentax smc D-FA 100mm F2.8 Macro WR Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 18-55mm F3.5-5.6 AL WR Pentax 55-300mm F4.5-6.3 ED PLM WR RE
sybersitizen Forum Pro • Posts: 26,812
That works, though some other minor metadata might be left in place.
Photoshop's "Save for Web ...' can also do it.
PLEASE NOTE: The system causes delays in the timing of my posts and prevents me from replying to private messages.
OP Pov2 Senior Member • Posts: 1,220
Thank you! That's it. That option has always been there. I was so used to seeing it there it never occurred to me to try it.
And it works on multiple files at the same time. Select them all, Properties, Details. This creates a copy of each file but the original file(s) can be deleted.
Is it the metadata that's not visible in Details? Can you give some examples what may be left in place?
It could depend on what type of file you work with. I exported a Nikon .NEF from DxO PL5 to JPEG with metadata 'removed'. The software name was still present, as you have stated, along with some other metadata.
* ExifTool *
ExifTool Version Number : 12.01
* File *
File Size : 6.8 MB
File Modification Date/Time : 2023:01:31 20:06:30-08:00
File Access Date/Time : 2023:01:31 22:26:36-08:00
File Creation Date/Time : 2023:01:31 20:06:29-08:00
File Permissions : rw-rw-rw-
File Type : JPEG
File Type Extension : jpg
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Image Width : 5232
Image Height : 3488
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:4:4 (1 1)
* JFIF *
JFIF Version : 1.02
Resolution Unit : inches
X Resolution : 300
Y Resolution : 300
* EXIF *
Orientation : Horizontal (normal)
X Resolution : 300
Y Resolution : 300
Software : DxO PhotoLab 5.1.3
Modify Date : 2023:01:31 20:06:29
Offset Time : -08:00
Color Space : sRGB
Exif Image Width : 5232
Exif Image Height : 3488
Compression : JPEG (old-style)
X Resolution : 72
Y Resolution : 72
Thumbnail Offset : 340
Thumbnail Length : 4356
Thumbnail Image : (Binary data 4356 bytes, use -b option to extract)
* XMP *
XMP Toolkit : XMP Core 5.5.0
Modify Date : 2023:01:31 20:06:29-08:00
Metadata Date : 2023:01:31 20:06:29-08:00
Creator Tool : DxO PhotoLab 5.1.3
* Composite *
Image Size : 5232x3488
Megapixels : 18.2
I then stripped that exported JPEG a second time with Windows File Explorer. The software name is now gone, but these items remain:
* ExifTool *
* File *
File Size : 6.8 MB
File Modification Date/Time : 2023:01:31 20:08:29-08:00
File Access Date/Time : 2023:01:31 20:10:02-08:00
File Creation Date/Time : 2023:01:31 20:08:29-08:00
File Type : JPEG
Image Width : 5232
Image Height : 3488
Bits Per Sample : 8
* JFIF *
JFIF Version : 1.02
X Resolution : 300
Y Resolution : 300
* EXIF *
X Resolution : 300
Y Resolution : 300
Color Space : sRGB
X Resolution : 72
Y Resolution : 72
* XMP *
* Composite *
Megapixels : 18.2
Stripping the exported PL5 JPEG with Photoshop's 'Save for Web...' leaves a little less behind:
* ExifTool *
* File *
File Size : 6.7 MB
File Modification Date/Time : 2023:01:31 20:16:08-08:00
File Access Date/Time : 2023:01:31 20:17:03-08:00
File Creation Date/Time : 2023:01:31 20:16:07-08:00
File Type : JPEG
Image Width : 5232
Image Height : 3488
Bits Per Sample : 8
* JFIF *
JFIF Version : 1.02
Resolution Unit : None
X Resolution : 100
Y Resolution : 100
* Ducky *
Quality : 85%
* APP14 *
DCT Encode Version : 100
APP14 Flags 0 : [14], Encoded with Blend=1 downsampling
APP14 Flags 1 : (none)
Color Transform : YCbCr
* Composite *
Megapixels : 18.2
In both cases, it's pretty generic data.
Lightbox32 New Member • Posts: 2
There is an app called EXIFTool that can update exif data in batch.
https://sourceforge.net/projects/exiftool/
Yes, I was aware of it but there is no good GUI and I need to this only occasionally for a few files, so ease of use is important.
Yes, I was aware of it but there is no good GUI ...
You think ExifToolGui isn't good? I've been using it for years. I used it to identify metadata in my earlier post. In fact, it does the best job by far of stripping metadata from my test file, leaving only this:
* ExifTool *
* File *
File Size : 6.8 MB
File Modification Date/Time : 2023:02:01 20:58:38-08:00
File Access Date/Time : 2023:02:01 21:02:58-08:00
File Creation Date/Time : 2023:02:01 20:57:56-08:00
File Type : JPEG
Image Width : 5232
Image Height : 3488
Bits Per Sample : 8
* Composite *
Megapixels : 18.2
* ExifTool *
* File *
File Size : 6.8 MB
File Type : JPEG
Image Width : 5232
Image Height : 3488
Bits Per Sample : 8
* Composite *
Megapixels : 18.2
I tried to use it long time ago but something was not right. I don't remember the details. I just downloaded the latest version and it seems fine. I will use it too. Thanks.
