Cracked Samsung NX 50-200 Lens - Is there any hope for a repair?
Started 2 months ago | Questions
Chris_R-R New Member • Posts: 8
Hey all,
Well, it happened. 6 years of owning this camera and this particular lens (50-200) and it came face to face with the concrete of our parking lot on Saturday.
I had proposed to my Girlfriend earlier in the day, and in the excitement between setting up the NX500 on a tripod, capturing the moment and then foolishly placing it wrapped up in my jacket in the trunk (rather than in the case I had with me!!!), and then forgetting it was there, whipped my jacket out, the camera goes flying and smack, the horror below:
*Sigh*
It's a great shame as obviously this line is discontinued and hard to come by at a semi-reasonable price these days. It's also got some sentimental value as it's been part of my profession to an extent. It's very much unused these days (this was the first time in about a year and a half I had used the camera) but as I said, it's a shame.
So, is there any hope for me or anyone else to be able to repair this? Or even re-selling it at a low price? It appears to just be the front element that's cracked and nothing else. Thankfully I do have a couple of other NX lenses, but nothing remotely telephoto like this one, which is tempting me to replace this with an EF lens adapter + appropriate telephoto lens replacement from that line.
Samsung NX 50-200mm F4-5.6 OIS Samsung NX500
doceyes Regular Member • Posts: 179
Re: Cracked Samsung NX 50-200 Lens - Is there any hope for a repair?
If this is your lens….https://www.ebay.com/itm/204217375587?hash=item2f8c4ddb63:g:c3UAAOSwY5ljhDHZ&amdata=enc%3AAQAHAAAAoP7KhPQf66uOJZlmfoV%2FSAG4uXg%2B60wSQN9RAFSbwuvrWRbiK03PBR1kupdXE7vn0MxWO3VCS4O0NOAW3hgMODXKAxDPKee4hrnP2MQIUJrhKTmNq%2FhPALiBHDGNXMJF5qv78nL7ey2%2FQE6fZhFN59Pch%2B91RzGKDpyabL00bUAc5egDXjN9ENIB%2FGRTgM0rlB4tykKytBRZvGZ5b8MTr7Y%3D%7Ctkp%3ABk9SR66Di8DAYQ
if that is the same one then I would just buy another used one. Congrats on the engagement. Now you have an excuse, I mean a valid reason, to either buy a new lens or a new camera, how could your fiancé possibly disagree! Al the best.
 doceyes's gear list:doceyes's gear list
Pentax 645D Samsung NX1 Samsung NX500 Pentax K-1
kypfer Contributing Member • Posts: 985
It's probably an optical illusion, but to my mind that looks like a "protection filter" fitted to the front of the lens that has done it's job … would need to see a side-on or oblique view to be sure, but it's just possible that the lens isn't damaged at all!
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
foxnoodles New Member • Posts: 11
Am I trippin or is that a lens filter?
Isola Verde
Isola Verde Forum Pro • Posts: 10,630
Indeed it does seem to be - with a blurred "52mm" showing?
There's hope for this lens yet!
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
markyboy81 Veteran Member • Posts: 4,778
Awesome, so the front element is intact?
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
OP Chris_R-R New Member • Posts: 8
I feel so foolish! It is indeed a HOYA filter!! Now for the job of trying to figure out how to get it to budge, it's locked on tight...
Sure is! I had no idea and don't even remember attaching it!
I completely glazed over that, aha! Thank goodness that there might be hope after all! Any ideas on how to coax it off? It's locked on pretty tight...
Fingers crossed! Just trying to figure out how to get it off right now, it's quite stubborn
Isola Verde
Great news, pleased for you!
Do you have a pair of rubber gloves - thicker than you'd use for doing the dishes if possible! Or an old pair of leather ones.
Peter
Peter
Rubber gloves did the trick - thank you so much Peter!!! The lens underneath is intact - just has some small dust particles on the surface!
wpstl Senior Member • Posts: 1,251
Peter
Be sure to check focus accuracy and alignment. There's a chance it suffered some damage after, what sounds like, a pretty bad fall.
 wpstl's gear list:wpstl's gear list
Samsung NX1 Sony a7R II Sony a7R III Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Lawrence Norman
Lawrence Norman Regular Member • Posts: 437
1. To remove stick filter, one can purchase a 'filter wrench'
Video of using a filter wrench: : https://www.youtube.com/watch?v=kAPdfGZK6G
52mm filter wrench: https://www.amazon.com/Camera-Lens-Filter-Wrench-Kit/dp/B093VK591N?th=1
2. One DYI I've used is a rubber band wrapped around the filter which provides  a better grip.
3. A lot of info on the web regarding this subject.
Congrats!
 Lawrence Norman's gear list:Lawrence Norman's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samyang 85mm F1.4 Aspherical IF +18 more
Don't forget to buy the new filter asap
Good point - will do!
Oh yes, a new one is already ordered and prepared to be dispatched aha!
Not half as foolish as you'd have been if it wasn't fitted
Pleased you got yourself sorted
We should start up the discussion again about whether to have a protective filter on lenses or not….because in the past the majority of posts were to have no filter on the lens!
My lens hood is practically always on so the filter is not really required but whenever I take it off I use a filter. Why risk it.
