How to Replace the CF Door on a Nikon D3?
Gpruitt54
Gpruitt54 Regular Member • Posts: 161
I am buying a D3 body. It looks as if I may need to replace the rubber covering on the door.  However, I may just replace the Compact Flash Card door itself.  How is this done?
 Gpruitt54's gear list:Gpruitt54's gear list
Nikon D3 Nikon D700 Nikon D800 Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 85mm f/1.8D +10 more
Nikon D3
ProfHankD
ProfHankD Veteran Member • Posts: 9,146
Re: How to Replace the CF Door on a Nikon D3?
Well, you can look for replacement spare parts... but I wouldn't be too hopeful about the odds of finding exactly what you'd need for a low price. There do seem to be D3 rubber cover parts starting a bit over $20 on eBay. It's really down to finding the parts...
I'd suggest only worrying about such things if there is a opening that will let dirt and environmental stuff get into the camera.
You also should be aware that you do NOT want to use super-aggressive glue for anything like this. Thin 2-sided tape or something like rubber cement is the norm.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Gpruitt54
OP Gpruitt54 Regular Member • Posts: 161
Yes, I am considering replacing only the door cover rubber piece.  In fact, that my be the easiest route.  And the cover rubber replacements piece is really inexpensive.
Gpruitt54
However, I want to understand how to remove and replace the CF door itself.
