EF 135mm f/2 L in 2023
AbuMahendra Regular Member • Posts: 108
Own a 6D. If there is one 'legacy' EF lens to keep, this one (or the 100L) is probably it. What do you think?
Canon EOS 6D
Photobygms
Photobygms Regular Member • Posts: 296
Re: EF 135mm f/2 L in 2023
Keep it,  I love it but not use it that much but, I'll keep it as long I'm still using the EF mount.
That will still be for a long time, also still shoot with analog Canon Eos gear:-D
.....Of course I'm out of my mind. It's dark and scary in there.....
Mostly analog at: https://www.flickr.com/photos/photobygms
Digital and some analog at: https://www.instagram.com/photobygms/
 Photobygms's gear list:Photobygms's gear list
Canon PowerShot SX740 HS Canon EOS 5D Mark IV Canon 6D Mark II Canon EOS R Canon EOS RP +46 more
tdbmd Senior Member • Posts: 1,547
This lens is on my wish list
 tdbmd's gear list:tdbmd's gear list
Canon EOS 7D Mark II Canon EOS Rebel T8i (EOS 850D) Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +11 more
dmartin92
dmartin92 Senior Member • Posts: 2,562
Over in the R forum I see people are getting their R 135mm, and I am sure that this is a fine lens. But I won’t be able to afford any new lens soon.
But I have my EF/R adapter, and I have my EF 135mm f/2 L.
And I was thinking … as far as extra weight, what percentage is the adapter ?  Both the R and EF 135 are big lenses, not entirely lightweight either. The adapter doesn’t really add in that much as far as the total amount. Yes, it’s more, but not a lot more.
By selling the EF and getting a « R version », you don’t get a huge benefit.
But if there ever is a « R 40mm pancake », that would be more worth it. In that case the adapter and the lens are almost the same size. So by getting an R version of the 40mm pancake, you would drop your size and weight (not counting the body) by 50%.
 dmartin92's gear list:dmartin92's gear list
Canon 6D Mark II Canon EOS R6 Mark II Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM Canon EF 40mm f/2.8 STM +1 more
Trevor Sowers
Trevor Sowers Senior Member • Posts: 1,605
I'm not selling mine but the ef 200mm f/2.8ii is even more impressive IMO, I own both
 Trevor Sowers's gear list:Trevor Sowers's gear list
Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EOS Rebel SL2 Canon EF 24mm f/1.4L II USM Canon EF 35mm F1.4L USM +21 more
John Crowe
John Crowe Veteran Member • Posts: 3,476
There are many.
There are actually many.  Especially since the EF RF adapters work seamlessly.  Far too many to list.
The only caveat is that with many of the legacy lenses the RF bodies will not achieve their highest frame rates.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
Damoo Senior Member • Posts: 1,102
Yup. Very much.
The 135mm f2 L is magical. I had moved to a Zeiss 135mm f2.
 Damoo's gear list:Damoo's gear list
Leica M Monochrom (Typ 246) Olympus OM-D E-M5 Canon EOS 6D Sony a7S Canon EOS 5D Mark IV +16 more
I have rented the EF 200L II f2.8 and I agree, it is a really nice lens
KevinRA Senior Member • Posts: 1,466
It is.  Only downside I noted was purple fringing wide open on a demanding 5DSR - so suspect worse on a R7 or 90D
 KevinRA's gear list:KevinRA's gear list
Canon EOS M6 II Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon EF-S 60mm f/2.8 Macro USM +14 more
I had only used it on the R6 and 7DII so not so many MP
Steve Balcombe Forum Pro • Posts: 15,582
"Legacy lens to keep" implies that it has some quality which newer alternatives don't have. I doubt very much if that's the case.
But the wonderful thing about EF lenses is that they don't just perform as well as the day you bought them, they perform even better on today's (i.e. mirrorless) bodies! You can't say that of many things you bought 25 years ago!
If you want to keep it because it's still useful and you don't see any compelling reason to replace it, yep, can't argue with that. I still have my EF 100L Macro for exactly that reason.
Canon_Guy
Canon_Guy Senior Member • Posts: 1,489
For its current price (used) it is a stunning lens. Technically not perfect but it has its huge magic. If you use it then it is definetely worth to keep. There are optically better lenses like Sigma and Canon 135/1.8 or Sigma 105/1.4 but they are bigger / heavier / much more expensive.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
Tom59 Senior Member • Posts: 1,651
Unless you need the cash from selling it, another vote to keep it.  That and the 200 2.8 make a nice pair. Both are very good medium focal length telephotos. They dont stand out in a crowd like the bigger white teles. Both take the 1.4 tc very well, with very good IQ. On the mirrorless cameras they work excellent!!! Use them both in an R6.
 Tom59's gear list:Tom59's gear list
Canon EOS 6D Canon EOS 7D Mark II Canon EOS 80D Canon EOS 5D Mark IV Canon EF 70-200mm F2.8L IS II USM +3 more
Sittatunga Veteran Member • Posts: 5,413
The RF 50mm f/1.8 is exactly ⅔ the weight of the EF 40mm + adapter and 6mm shorter.  But an RF pancake lens much longer than about 24mm would have to be of telephoto construction (like that of the original Olympus mju), so not a great deal lighter than the 50mm.
dmartin92
These sort of issues are what I am thinking about these days. I think, for me, there are three variables:
1) how good the lens is (Image Quality) ?
2) how small is the total size (less is better) ?
3) how close is the setup to 40mm ?
Scoring less on one or two points is not enough to "sink the boat" (make me not like it), as long as it does well in another one or two points.
The RF 50mm f/1.8 does score some points, but even the EF 35mm f/2 IS with the adapter scores some points too. IQ, the EF 35mm f/2 does really well.
The big question for me is: when will Canon make an RF 40mm pancake ? Is it coming out in 2 months ? Two years ? Or four years ?
But it's all minor stuff. I am happy enough with all the choices I have today.  I can just wait.
gaul Senior Member • Posts: 1,511
Will not sell my 6D and my EF 135 F2 if and when I move to RF..
5
The EF 135 F2 is the best lens in EF mount that I have .. the one lens that produces pictures so artistic it does not require post-processing to look good
 gaul's gear list:gaul's gear list
Canon PowerShot S30 Canon PowerShot G1 X Canon EOS 6D Panasonic Lumix DMC-GM5 Canon EF 50mm F1.4 USM +7 more
EF 135 F2 takes the x2 converter very well
irm Veteran Member • Posts: 3,105
7
Here is an example of why I like my 135 f2. A new cat photo. An 8 month old kitten.
my 2 exposed flashcubes worth.
Ian the pbase supporter.
http://pbase.com/ianm_au
Please check my profile for equipment list.
An amateur with dreams of being a good to excellent photographer.
 irm's gear list:irm's gear list
Canon EOS 10D Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 50mm F1.8 II Canon EF 135mm F2L USM +9 more
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,601
I think you can get a mint one from Japan for 650 - 750 ish on Ebay
When a seller basedin Japan says mint - its basically brand new still in the box
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
Rodger in Edmonton
we had a big group homage to the 135 a few weeks a go - as Irm shows with the cat - the 135/2 is one of those charmers - great optics, great pop, great palette.
Quaecumque vera
