Tutankhamum
Rodger in Edmonton
Rodger in Edmonton Veteran Member • Posts: 4,599
Tutankhamum
8
One of the most fascinating and enthralling stories of discovery.
A composite of five shots with alternate side lighting.
I took the red down 15 % but the compression wonks them up again
Best Regards, Rodger
Save Lives - Be an Organ or Stem Cell Donor.
Quaecumque vera
jim mij Senior Member • Posts: 1,027
Re: Tutankhamum
thats a nice pic and approach Roger, thanks for the idea, i'll be on the lookout for something to try it on
Jim
 jim mij's gear list:jim mij's gear list
Canon EOS M6 II Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF-S 60mm f/2.8 Macro USM Kenko Teleplus Pro 300 AF 1.4x Canon EF-M 22mm f/2 STM
Rodger in Edmonton
OP Rodger in Edmonton Veteran Member • Posts: 4,599
Re: Tutankhamum
Thanks Jim, I bought a product turntable for Christmas and used it for this.
It works like a charm with no stutter- you can set it for exact step rotations or slew it with the button - for example it will rotate 1/8, stop for 4 s and proceed etc or continuous .
I find it almost silent- i
Also the Lume Cube Panel Pro is an unbelievable little light rig for still life - you can dial the white balance so here I kept it warm to burnish the gold.
The still life works wonders to fil the fall - winter dip in Photography .
Quaecumque vera
Jim B (MSP) Forum Pro • Posts: 11,959
Re: Tutankhamum
What a great idea to show a piece of art like this.
I will give you credit when I use it.
Jim
"It's all about the light"
 Jim B (MSP)'s gear list:Jim B (MSP)'s gear list
Canon EOS 90D
Re: Tutankhamum
Thanks for the tips Rodger, Ive been thinking of an led light, but an automated lazy Susan, I’m sure there’s something apt there..
Jim
Rodger in Edmonton
Re: Tutankhamum
Thanks Jim - there used to be a store in Seattle called Eleganza and that's where i picked him up in the early 2000s, he is about 10" h x8 w x 7 d.
he is not bronze - just plaster at $ 120 ( fittingly plaster ha ha ) but they did a great job with the paint and he is still hangin' in there with no issue.
Since boyhood mass amounts of buried treasure have held a particular charm for me.
Quaecumque vera
Rodger in Edmonton
Re: Tutankhamum
It ensures  pretty good symmetry to the shots, you could make it perfect by placement but a slight deviation IMHO gives a more dynamic feel sincee each side is lit close but not identical.
Quaecumque vera
Re: Tutankhamum
Roger,
I was thinking about using your approach to showing the art, not the art itself.
I have a clay decorated pot I may try it with.
Jim
Jim
Canon EOS 90D
Rodger in Edmonton
Re: Tutankhamum
Roger,
Jim
I understand, a sharp light angle mimics natural drama... the crawl is  just a demo of using  script  - pottery should look great play with the white balance - it can  give a very different look.
Quaecumque vera
Re: Tutankhamum
Roger,
Jim
I have a Lume Cube as well. I will play with that, both angles and color temps.
Jim
Canon EOS 90D
