XH2 Exposure Compensation Button
Steph Kimball
Steph Kimball Senior Member • Posts: 1,321
I enjoy using the front dial on my XT and X100 cameras and I'm considering the purchase of a XH2. Using EC on my cameras is a one button solution. From what I see, it's necessary to push the EC button on the top of the camera and then dial in EC using the rear command dial. Is there a way to map the EC directly to the front command dial?
Fujifilm FinePix X100
Night Pixel
Night Pixel Contributing Member • Posts: 976
Re: XH2 Exposure Compensation Button
You can switch if the rear of the front dial is EC.
**** REDACTED ****
 Night Pixel's gear list:Night Pixel's gear list
Sony RX10 IV Fujifilm X100V Fujifilm X-H2 Fujifilm XF 80mm F2.8 Macro Tamron 150-500mm F5-6.7 Di III VC VXD +4 more
Steph Kimball
OP Steph Kimball Senior Member • Posts: 1,321
thank you!
pama123 Forum Member • Posts: 61
Night Pixel's answer is it.
I'll just add a bit to it based on how I've used this on the X-H2 and other cameras.
In program, aperture priortiy and shutter priority - I've got it set up so the rear dial acts as the esposure compensation. Great, it works just like my old X-T2 and I don't need to think about it.
However, if I am in Manual Mode to keep a fixed aperture and shutter speed for artistic reasons, I can use Auto-ISO to maintain the right exposure.
In this situation, exposure compensation will require me to press a button to toggle the command dial used for shutter speed to exposure compensation and back.
I wish it could be separated, but for now, it is not.
Paul
Morris0
Morris0 Forum Pro • Posts: 32,181
In aperture priority, the rear command dial is EC.  A very convent way to work.  Aperture will be on the front dial.  You can also set this up for shutter priority as well as swap shutter speed and aperture to make everything consistent no matter what exposure mode you are in.
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Steph Kimball
Morris
Thank you !
Steph Kimball
Paul
Thanks!
