Going from DSLR to R... does the lack of a top deck LCD bother you?
Started 2 months ago | Questions
jumpthesnark Forum Member • Posts: 67
Hi all, I have a question for those of you who have switched from a DSLR to an R6/R6 MkII, an R7, an R10, etc.
About the only issue I have with the design of those cameras is the missing LCD screen on the right side of the top deck. I am so used to checking important settings by just glancing at the LCD on my Canon DSLRs.
My question is how long did it take for you R owners to get the muscle memory of hitting the Q button and looking at the back screen or looking through the eyepiece to check your camera's status instead? And is it, in general, an annoyance to not have that little LCD screen on the top deck any more? I'm someone who usually has the back screen closed on my 6D MkII, so it's convenient to be able to just give the shutter button a half-press and glance down at my camera to check the battery level, drive, ISO, etc.
Canon's good DSLR design has spoiled me. First-world problem, I know.
Thank you in advance for your thoughts on this!
Canon 6D Mark II Canon EOS R10 Canon EOS R6 Canon EOS R6 Mark II Canon EOS R7
BobKnDP Senior Member • Posts: 3,140
Re: Going from DSLR to R... does the lack of a top deck LCD bother you?
You're unprepared to buy an R5 or an R3?
Both have top right LCDs. Both cost more than the R series models you list.
I have an R5. I use all 3 displays, but the EVF the most. That's partly because I have lost visual accommodation with age, and have slight farsightedness.
KiloHotelphoto Contributing Member • Posts: 770
I had an R6 a couple years ago and never noticed not having it coming from a 1DX2 and 5dsr and on my R5 and R3 now I never look at it either.
 KiloHotelphoto's gear list:KiloHotelphoto's gear list
Canon RF 600mm F4L Canon EOS R5 Canon EOS R3 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +4 more
OP jumpthesnark Forum Member • Posts: 67
Looking at an R6 MkII. Not interested in the R5 or R3, which is why I was asking folks who had the other models, which have a similar top deck design.
Good info on the EVF reasoning, thanks.
Distinctly Average Senior Member • Posts: 2,527
14
I thought I would miss it but turns out I don’t in the slightest. The top LCD is a bit of a throwback to the days before a rear screen and a plethora of information in the viewfinder. It is so easy to access that the top screen has for me become redundant.
Zeee Forum Pro • Posts: 25,627
No very long. You adapt quickly. However coming from the R5 I do miss not being able to map the MF-n, button to switch C1-3 modes on the R6II and R7 quite a bit. You have to manually turn the dial.
Don't Look Up.
 Zeee's gear list:Zeee's gear list
Canon EOS R7 Canon EOS R6 Mark II Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +1 more
drsnoopy Senior Member • Posts: 1,216
On the R5 you need the top LCD in order to change modes…a mode dial might have been easier.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
catastrophe Regular Member • Posts: 161
That is strange, on the R you can press the mode button and the options appear in the evf and you select what you want.
davel33 Senior Member • Posts: 2,974
I moved to the R from a 7DII and never used the top display while shooting. I added the R6 last year and love it even without the top display.  Some might say its just something else to break.
"Just one more Lens, I promise....."
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
I miss having that option. I shot a model airplane show and just press the MF-n to switch between fast (jets) and slow (props) fps and still keep my eye on the EVF.
Don't Look Up.
I have a 6D, an R and an R6mII. The 6D and R have a top display. I do not use the top display on the R. The R has a mode button while the R6mII has a rotary selector, this is a step backwards. The mode button would work perfectly well without a top display
When you press the Mode button, the mode choices are also displayed on the screen and in the EVF. There's is no need to look at the top LCD. (But I usually do it that way, anyway.)
1cb
1cb Regular Member • Posts: 398
nope, never really used it anyway. that what the rear screen or in viewfinder is for.
 1cb's gear list:1cb's gear list
Canon EOS R7 Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM Canon EF 100-400mm F4.5-5.6L IS II Canon RF 35mm F1.8 IS STM Macro +5 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
I shoot the R and the R7 roughly equally. The R has the top screen, the R7 doesn't. It doesn't bother me at all.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Bramble9 Regular Member • Posts: 211
I totally agree with DA above and would even go a step further and say that IMHO, a top screen is a waste of space that could be used for such things as a dedicated exposure comp dial, dedicated ISO dial-- or other stuff.  My R5 has one of course but I basically ignore it.  My R7 is without it, and I prefer it that way.
Bramble9
 Bramble9's gear list:Bramble9's gear list
Canon EOS R5 Canon EOS R7 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM +1 more
John Crowe
John Crowe Veteran Member • Posts: 3,476
Lack of a top LCD is inexcusable in this price range.
Thank-you, I had no idea this was the case.  What are these, Rebels?
For several years I had one camera with, and one without.  The one without drove me nuts.
I shoot in manual mode 100% of the time, I do a lot of tripod mounted shifting/stitching and focus stacking, so I rely on quickly checking the top screen.  I have been using a top screen since 1986, so I am not about to change 37 years later!
I have been thinking about an R7 but even for sports shooting that is likely a deal breaker.  At least the other cameras that I used without top panels were less than $300 USD each.  Every Canon camera over $1500 should have them.  It was Canon who started them in the first place back in the late 80's.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
R2D2 Forum Pro • Posts: 26,530
Re: Lack of a top LCD is inexcusable in this price range.
I really like having a top LCD for a quick settings check as I’m bringing the camera up to my eye (I shoot full Manual too).  I miss not having one, but it hasn’t been a deal breaker with my other bodies.
R2
Alastair Norcross
Well, that’s one point of view. Not one widely shared, apparently, and it would be a pity to miss out on the best crop camera Canon has ever made because of an inability/unwillingness to adapt. But you do you. We’ll enjoy our R7s.
Alastair
ZX11
ZX11 Veteran Member • Posts: 6,156
My R has a top screen but
No.
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
mohdya Senior Member • Posts: 1,265
No issue with me as we all know there is less available space with the smaller body depth of most mirrorless. I'd rather have more control buttons than to have a small display lighted display which is easily covered by both eVF and the rear screen display.
I only wish some or all of the buttons are auto-illuminated (like what you have in your car these days) for '"pitch-black" environmental conditions, with options to turn them off, and better battery life comparable to DSLRs....best-in-performance mirrorless cameras are only around 60% or less of the CIPA of a DSLR.
Yus.
'Photography is the Art or Process of Producing Images,
The Art of Photography is Another Story.'
 mohdya's gear list:mohdya's gear list
Panasonic Lumix DMC-TS5 Canon EOS 70D Canon EF-S 18-135mm F3.5-5.6 IS STM
