Upgrade from E-PL1 and 17/2.8?
bluevellet Veteran Member • Posts: 4,172
tedolph not the only one goofin...
Funkmon wrote:
Context: tedolf strongly dislikes the newer Olympus cameras since they removed useful, albeit fringe features, like the EVF port and the ability to autofocus four thirds lenses, which will almost definitely not affect you.
Why not use the auto-lens cap from Olympus? The one made for the 14-42 EZ pancake lens. It fit the Lumix 12-32 and is a lot less bulky than the one you are using.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
Funkmon
Funkmon Contributing Member • Posts: 602
It moves with the zoom ring.
No text.
 Funkmon's gear list:Funkmon's gear list
Olympus E-M1 III Olympus PEN E-P7 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus 25mm F1.2 +17 more
my issue is that it moves outwards like petals
Funkmon wrote:
... so the lens become much bigger.
The Olympus accessory open inwards, so the accessory remains the same size.
Funkmon
When the zoom is out, size is irrelevant.
No text.
Stephen Strangways
Stephen Strangways Contributing Member • Posts: 984
Re: tedolph not the only one goofin...
Two reasons not to use it:
1) It vignettes at the wide end. You can cut away some of the inside edges, or just use the JJC clone that does not vignette.
2) The zoom ring on the 12-32 is very poorly made, the outer part is attached to the inner plastic part using just double-sided tape, and it's prone to detaching. The extra force required to retract the lens with LC-37C caps, Oly or JJC, make this more likely to happen.
That being said, this earlier push-on petal-style JJC cap with the flaps is known to also cause problems where it pushes on to the lens.
Funkmon
Well goddammit nobody told me that. Haha. It's okay though. If this lens borks I can get a new one.
